Hey Guys,
I’m currently working on a project where I need to initialize Platformio projects from a python script.
To make it I’m using the pio project init
command line, and I was wondering if there is any way to use this command to add stuff such as build_flags
or lib_deps
For example this command: pio project init --environment native -O="platform=native" -O="build_flags=-lpthread"
give me this platformio.ini
[env:native]
platform = native
build_flags = -lpthread
Then I would like to be able to add something in the build_flags
for example by using: pio project init --environment native -O="build_flags=-lm", the output
platformio.ini`would be:
[env:native]
platform = native
-lpthread
-lm
Alternatively, I see that it is possible to extract the platformio.ini
as Json format using the pio project config --json-output
. It would be very practical to be able to get this Json, modify it as we want, then re-inject it somewhere to regenerate the platformio.ini
file.
Is there anything existing allowing to solve this?
