I currently use the extra_scripts section of platformio.ini to run post build python scripts. It’s been working fine, but now I have a new requirement. I need to add a step at the end of the build to copy my build artifacts to Azure File Storage. I can do this in Python by installing the azure-storage-fileshare python module. However, trying to use pip to install the modules in the PlatformIo virtual environment doesn’t seem to work.
What I have been trying to do is install the modules in a pre: build step. Then use the modules in a post build step.
platformio.ini
extra_scripts =
pre:../preInstallDependencies.py ;Install python modules if not already installed.
post:../postBuild_All.py ;After the build completes, use AddPostAction to upload artifacts to Azure File Storage.
preInstallDependencies.py would look something like this…
import sys
import subprocess
import pkg_resources
import site
python = sys.executable
#c:\users\admin\.platformio\penv\scripts\python.exe
package_path = site.getsitepackages()
#['c:\\users\\admin\\.platformio\\penv'
#,'c:\\users\\admin\\.platformio\\penv\\lib\\site-packages']
installed = {pkg.key for pkg in pkg_resources.working_set}
#{ 'chardet', 'tabulate', 'pyelftools', 'marshmallow', 'click'
#, 'requests', 'certifi', 'pyserial', 'colorama', 'pip'
#, 'setuptools', 'platformio', 'semantic-version', 'wheel'
#, 'bottle', 'urllib3', 'idna'}
if 'azure-storage-fileshare' in installed:
pass
else:
subprocess.check_call([python, '-m', 'pip', '--version'])
#pip 20.2.3 from c:\users\admin\.platformio\penv\lib\site-packages\pip (python 3.7)
subprocess.check_call([python, '-m', 'pip', 'install', 'azure-storage-fileshare'])
#ERROR: Could not find a version that satisfies the requirement azure-storage-fileshare (from versions: none)
#ERROR: No matching distribution found for azure-storage-fileshare
subprocess.check_call([python, '-m', 'pip', 'install', '--user', 'azure-storage-fileshare'])
#ERROR: Can not perform a '--user' install. User site-packages are not visible in this virtualenv.
And finally, postBuild_All.py would look something like this…
from azure.storage.fileshare import ShareFileClient, ShareClient
from azure.core.exceptions import ResourceExistsError
#bla bla bla
However when I try to pip install the ‘azure-storage-fileshare’ module I get pip installation errors.
Any ideas how I can make this work?
