I used your configuration file but it printed the following result
Processing esp32-s3-n8r16 (platform: espressif32; board: esp32-s3-wroom-n8r16-build; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/esp32-s3-wroom-n8r16-build.html
PLATFORM: Espressif 32 (5.0.0) > Espressif ESP32-S3-DevKitC-1-N8R16
HARDWARE: ESP32S3 240MHz, 520KB RAM, 16MB Flash
DEBUG: Current (esp-builtin) On-board (esp-builtin) External (cmsis-dap, esp-bridge, esp-prog, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa)
- framework-arduinoespressif32 @ 3.20003.220626 (2.0.3)
- toolchain-riscv32-esp @ 8.4.0+2021r2-patch3
- toolchain-xtensa-esp32s3 @ 8.4.0+2021r2-patch3
Found 32 compatible libraries
Compiling .pio\build\esp32-s3-n8r16\src\main.cpp.o
Compiling .pio\build\esp32-s3-n8r16\FrameworkArduino\Esp.cpp.o
Compiling .pio\build\esp32-s3-n8r16\FrameworkArduino\FirmwareMSC.cpp.o
Compiling .pio\build\esp32-s3-n8r16\FrameworkArduino\FunctionalInterrupt.cpp.o
Compiling .pio\build\esp32-s3-n8r16\FrameworkArduino\HWCDC.cpp.o
Compiling .pio\build\esp32-s3-n8r16\FrameworkArduino\HardwareSerial.cpp.o
Compiling .pio\build\esp32-s3-n8r16\FrameworkArduino\IPAddress.cpp.o
Compiling .pio\build\esp32-s3-n8r16\FrameworkArduino\IPv6Address.cpp.o
Compiling .pio\build\esp32-s3-n8r16\FrameworkArduino\MD5Builder.cpp.o
Compiling .pio\build\esp32-s3-n8r16\FrameworkArduino\Print.cpp.o
In file included from c:\users\index\.platformio\packages\toolchain-xtensa-esp32s3\xtensa-esp32s3-elf\sys-include\sys\reent.h:503,
from C:/Users/index/.platformio/packages/framework-arduinoespressif32/tools/sdk/esp32s3/include/newlib/platform_include/sys/reent.h:17,
Compiling .pio\build\esp32-s3-n8r16\FrameworkArduino\Stream.cpp.o
from c:\users\index\.platformio\packages\toolchain-xtensa-esp32s3\xtensa-esp32s3-elf\sys-include\stdio.h:60,
from C:/Users/index/.platformio/packages/framework-arduinoespressif32/cores/esp32/Arduino.h:27,
from src/main.cpp:1:
C:/Users/index/.platformio/packages/framework-arduinoespressif32/tools/sdk/esp32s3/include/newlib/platform_include/assert.h:20:10: fatal error: sdkconfig.h: No such file or directory
* Looking for sdkconfig.h dependency? Check our library registry!
* CLI > platformio lib search "header:sdkconfig.h"
* Web > https://registry.platformio.org/search?q=header:sdkconfig.h
#include <sdkconfig.h>
compilation terminated.
Compiling .pio\build\esp32-s3-n8r16\FrameworkArduino\StreamString.cpp.o
Compiling .pio\build\esp32-s3-n8r16\FrameworkArduino\Tone.cpp.o
In file included from C:/Users/index/.platformio/packages/framework-arduinoespressif32/cores/esp32/HWCDC.cpp:14:
C:/Users/index/.platformio/packages/framework-arduinoespressif32/cores/esp32/USB.h:16:10: fatal error: sdkconfig.h: No such file or directory
#include "sdkconfig.h"
In file included from C:/Users/index/.platformio/packages/framework-arduinoespressif32/cores/esp32/FirmwareMSC.h:17,
from C:/Users/index/.platformio/packages/framework-arduinoespressif32/cores/esp32/FirmwareMSC.cpp:14:
C:/Users/index/.platformio/packages/framework-arduinoespressif32/cores/esp32/USBMSC.h:18:10: fatal error: sdkconfig.h: No such file or directory
Compiling .pio\build\esp32-s3-n8r16\FrameworkArduino\USB.cpp.o
Compiling .pio\build\esp32-s3-n8r16\FrameworkArduino\USBCDC.cpp.o
Compiling .pio\build\esp32-s3-n8r16\FrameworkArduino\USBMSC.cpp.o
Compiling .pio\build\esp32-s3-n8r16\FrameworkArduino\WMath.cpp.o
Compiling .pio\build\esp32-s3-n8r16\FrameworkArduino\WString.cpp.o
Compiling .pio\build\esp32-s3-n8r16\FrameworkArduino\base64.cpp.o
Compiling .pio\build\esp32-s3-n8r16\FrameworkArduino\cbuf.cpp.o
*** [.pio\build\esp32-s3-n8r16\src\main.cpp.o] Error 1
*** [.pio\build\esp32-s3-n8r16\FrameworkArduino\HWCDC.cpp.o] Error 1
*** [.pio\build\esp32-s3-n8r16\FrameworkArduino\FirmwareMSC.cpp.o] Error 1
In file included from C:/Users/index/.platformio/packages/framework-arduinoespressif32/cores/esp32/USB.cpp:14:
*** [.pio\build\esp32-s3-n8r16\FrameworkArduino\USB.cpp.o] Error 1
from C:/Users/index/.platformio/packages/framework-arduinoespressif32/cores/esp32/Esp.cpp:20:
*** [.pio\build\esp32-s3-n8r16\FrameworkArduino\Esp.cpp.o] Error 1
In file included from C:/Users/index/.platformio/packages/framework-arduinoespressif32/cores/esp32/USBCDC.cpp:14:
*** [.pio\build\esp32-s3-n8r16\FrameworkArduino\USBCDC.cpp.o] Error 1
from c:\users\index\.platformio\packages\toolchain-xtensa-esp32s3\xtensa-esp32s3-elf\sys-include\stdlib.h:18,
from c:\users\index\.platformio\packages\toolchain-xtensa-esp32s3\xtensa-esp32s3-elf\include\c++\8.4.0\cstdlib:75,
from c:\users\index\.platformio\packages\toolchain-xtensa-esp32s3\xtensa-esp32s3-elf\include\c++\8.4.0\stdlib.h:36,
from C:/Users/index/.platformio/packages/framework-arduinoespressif32/cores/esp32/HardwareSerial.cpp:1:
*** [.pio\build\esp32-s3-n8r16\FrameworkArduino\HardwareSerial.cpp.o] Error 1
In file included from C:/Users/index/.platformio/packages/framework-arduinoespressif32/cores/esp32/USBMSC.cpp:14:
*** [.pio\build\esp32-s3-n8r16\FrameworkArduino\USBMSC.cpp.o] Error 1
from C:/Users/index/.platformio/packages/framework-arduinoespressif32/cores/esp32/IPAddress.cpp:20:
*** [.pio\build\esp32-s3-n8r16\FrameworkArduino\IPAddress.cpp.o] Error 1
from C:/Users/index/.platformio/packages/framework-arduinoespressif32/cores/esp32/Print.cpp:24:
*** [.pio\build\esp32-s3-n8r16\FrameworkArduino\Print.cpp.o] Error 1
from C:/Users/index/.platformio/packages/framework-arduinoespressif32/cores/esp32/Stream.cpp:23:
*** [.pio\build\esp32-s3-n8r16\FrameworkArduino\Stream.cpp.o] Error 1
from C:/Users/index/.platformio/packages/framework-arduinoespressif32/cores/esp32/IPv6Address.cpp:20:
*** [.pio\build\esp32-s3-n8r16\FrameworkArduino\IPv6Address.cpp.o] Error 1
from C:/Users/index/.platformio/packages/framework-arduinoespressif32/cores/esp32/MD5Builder.cpp:19:
*** [.pio\build\esp32-s3-n8r16\FrameworkArduino\MD5Builder.cpp.o] Error 1
from C:/Users/index/.platformio/packages/framework-arduinoespressif32/cores/esp32/Tone.cpp:1:
from C:/Users/index/.platformio/packages/framework-arduinoespressif32/cores/esp32/StreamString.cpp:23:
*** [.pio\build\esp32-s3-n8r16\FrameworkArduino\Tone.cpp.o] Error 1
*** [.pio\build\esp32-s3-n8r16\FrameworkArduino\StreamString.cpp.o] Error 1
from C:/Users/index/.platformio/packages/framework-arduinoespressif32/cores/esp32/WMath.cpp:27:
*** [.pio\build\esp32-s3-n8r16\FrameworkArduino\WMath.cpp.o] Error 1
from c:\users\index\.platformio\packages\toolchain-xtensa-esp32s3\xtensa-esp32s3-elf\sys-include\string.h:11,
from C:/Users/index/.platformio/packages/framework-arduinoespressif32/cores/esp32/cbuf.h:26,
from C:/Users/index/.platformio/packages/framework-arduinoespressif32/cores/esp32/cbuf.cpp:21:
*** [.pio\build\esp32-s3-n8r16\FrameworkArduino\cbuf.cpp.o] Error 1
from C:/Users/index/.platformio/packages/framework-arduinoespressif32/cores/esp32/base64.cpp:25:
*** [.pio\build\esp32-s3-n8r16\FrameworkArduino\base64.cpp.o] Error 1
from C:/Users/index/.platformio/packages/framework-arduinoespressif32/cores/esp32/WString.cpp:24:
*** [.pio\build\esp32-s3-n8r16\FrameworkArduino\WString.cpp.o] Error 1
from c:\users\index\.platformio\packages\toolchain-xtensa-esp32s3\xtensa-esp32s3-elf\sys-include\wchar.h:6,
from c:\users\index\.platformio\packages\toolchain-xtensa-esp32s3\xtensa-esp32s3-elf\include\c++\8.4.0\cwchar:44,
from c:\users\index\.platformio\packages\toolchain-xtensa-esp32s3\xtensa-esp32s3-elf\include\c++\8.4.0\bits\postypes.h:40,
from c:\users\index\.platformio\packages\toolchain-xtensa-esp32s3\xtensa-esp32s3-elf\include\c++\8.4.0\bits\char_traits.h:40,
from c:\users\index\.platformio\packages\toolchain-xtensa-esp32s3\xtensa-esp32s3-elf\include\c++\8.4.0\string:40,
from c:\users\index\.platformio\packages\toolchain-xtensa-esp32s3\xtensa-esp32s3-elf\include\c++\8.4.0\stdexcept:39,
from c:\users\index\.platformio\packages\toolchain-xtensa-esp32s3\xtensa-esp32s3-elf\include\c++\8.4.0\array:39,
from c:\users\index\.platformio\packages\toolchain-xtensa-esp32s3\xtensa-esp32s3-elf\include\c++\8.4.0\tuple:39,
from c:\users\index\.platformio\packages\toolchain-xtensa-esp32s3\xtensa-esp32s3-elf\include\c++\8.4.0\functional:54,
from C:/Users/index/.platformio/packages/framework-arduinoespressif32/cores/esp32/FunctionalInterrupt.h:11,
from C:/Users/index/.platformio/packages/framework-arduinoespressif32/cores/esp32/FunctionalInterrupt.cpp:8:
*** [.pio\build\esp32-s3-n8r16\FrameworkArduino\FunctionalInterrupt.cpp.o] Error 1
============================================================================= [FAILED] Took 2.31 seconds =============================================================================
