In PlatformIO while creating a project , in the board selection there is no ESP-12F in the boards. While there is ESP-12E. I can flash ESP-12F while choosing ESP-12E from the boards without any flashing issue. But there are some runtime issues, the one that I noticed is the LED doesn’t blink when flashed from PlatformIO , but works fine, when flashed using Arduino IDE using the same code. So there may be some difference in the configurations.
C:\Users\USER.platformio\platforms\espressif8266\boards
In this directory I found the esp-12e board which is a JSON format.
"build": {
"core": "esp8266",
"extra_flags": "-DESP8266 -DARDUINO_ARCH_ESP8266 -DARDUINO_ESP8266_ESP12",
"f_cpu": "80000000L",
"f_flash": "40000000L",
"flash_mode": "dio",
"ldscript": "eagle.flash.4m1m.ld",
"mcu": "esp8266",
"variant": "nodemcu"
"connectivity": [
"wifi"
"frameworks": [
"arduino",
"simba",
"esp8266-rtos-sdk",
"esp8266-nonos-sdk"
"name": "Espressif ESP8266 ESP-12E",
"upload": {
"maximum_ram_size": 81920,
"maximum_size": 4194304,
"require_upload_port": true,
"resetmethod": "nodemcu",
"speed": 115200
"url": "http://www.esp8266.com/wiki/doku.php?id=esp8266-module-family",
"vendor": "Espressif"
How do I add ESP-12F to the PlatformIO boards and flashing without any issue.
