Guys,
New to Platformio here - done lots of work in the past with Arduino IDE.
I have picked up a package from Github that has been published - i wish to use this as the basis for my project going forward.
However it looks like it was a pure Arduino project and he then migrated to Platformio as he has not explicitly identified the included libraries.
This is the project in question
I have raised an issue with the Dev.
I have through trial and error worked through most of the initial build errors and found libraries (that on face value appear to work) - however the MQTT one is throwing errors - is it just a matter of trial and error to try and identify the correct library to include in my project ?
Craig
And this is exactly why global libraries and global state are poison. Libs should be declared per-project to make it clean. I don’t get the “it’s confortable” aspect at all.
Without info available in the platformio.ini
, yeah. Although looking at what obejcts are instantiated from that library, you can narrow it down. The MQTTClient
object very likely comes from the standard Arduino-MQTT library. So writing (or adding to, if there are existing libs)
256dpi/MQTT
should be tried.
Thanks - will give it a go and see how i go.
Craig
Compiles for me when I add
256dpi/MQTT
4-20ma/ModbusMaster
bblanchon/ArduinoJson
prampec/IotWebConf
joaolopesf/RemoteDebug
Thanks for that – I have included those in the platformio.ini file for the project and I get 11 problems when I compile/build – they are only warning level – did you also get this ?
My wandering blindly in the desert had gotten most of the way to what you posted – although all of mine had versions numbers on them as well (so I removed those and went with your text block)
Thanks for all the help on this
Craig
