Im confused on how to use this in platorm.io
Which library are you referring to.
Also which platform, board and framework do you use?
Arduino Uno and im trying to power a buzzer
Example of the pitches.h here: https://docs.arduino.cc/built-in-examples/digital/toneMelody/
“pitches.h
” is not a library on it’s own.
It is just a part of the source code for the example.
So, there is no way to “install” this.
Just create a “pitch.h” in your source folder and copy the content from the linked file above.
There is a “TonePitch” library in the registry: See PlatformIO Registry
This library comes with an example.
To install this library, simply add rodrigodornelles/TonePitch@^1.0.3
to your lib_deps
in platformio.ini:
lib_deps = rodrigodornelles/TonePitch@^1.0.3
ohhh ok I was confused by the include! Thanks.
