How do I add third-party libraries downloaded from the Internet?Not downloaded from GitHub and platformIO!Sometimes platformIO doesn’t have the library you want
How do I add third-party(private) libraries downloaded from the Internet?(No such file or directory)
Well a good start would be to put the downloaded library into the lib
folder so that you have lib/<your new library>/<source files>
To control the build options of the library, and which files are build if exclusions are needed, can be done through adding a library.json
file:
https://docs.platformio.org/en/latest/manifests/library-json/index.html
More complicated libraries might need custom Python logic to build, (see extra_scripts
above), but that really depends on the library. A good library.json
should work for most libraries.
thanks for your reply!!
I created the.c file in the lib folder and added the path to the c_cpp_properties.json folder, but the compilation error was still reported
Can you help me with a specific problem?
Processing uno_r4_wifi (platform: renesas-ra; board: uno_r4_wifi; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/renesas-ra/uno_r4_wifi.html
PLATFORM: Renesas RA (1.1.0) > Arduino Uno R4 WiFi
HARDWARE: RA4M1 48MHz, 32KB RAM, 256KB Flash
DEBUG: Current (cmsis-dap) External (cmsis-dap, jlink)
- framework-arduinorenesas-uno @ 1.0.2
- tool-bossac @ 1.10901.0 (1.9.1)
- toolchain-gccarmnoneeabi @ 1.100301.220327 (10.3.1)
Found 16 compatible libraries
Compiling .pio\build\uno_r4_wifi\src\main.cpp.o
Compiling .pio\build\uno_r4_wifi\FrameworkArduino\cortex_handlers.c.o
Compiling .pio\build\uno_r4_wifi\FrameworkArduino\dac.cpp.o
Compiling .pio\build\uno_r4_wifi\FrameworkArduino\digital.cpp.o
Compiling .pio\build\uno_r4_wifi\FrameworkArduino\itoa.c.o
Compiling .pio\build\uno_r4_wifi\FrameworkArduino\main.cpp.o
Compiling .pio\build\uno_r4_wifi\FrameworkArduino\pinDefinitions.cpp.o
Compiling .pio\build\uno_r4_wifi\FrameworkArduino\pulse.cpp.o
Compiling .pio\build\uno_r4_wifi\FrameworkArduino\pwm.cpp.o
Compiling .pio\build\uno_r4_wifi\FrameworkArduino\shift.cpp.o
Compiling .pio\build\uno_r4_wifi\FrameworkArduino\time.cpp.o
Compiling .pio\build\uno_r4_wifi\FrameworkArduino\tinyusb\class\audio\audio_device.c.o
src\main.cpp:2:9: fatal error: lcd12864.c: No such file or directory
2 | #include"lcd12864.c"
compilation terminated.
*** [.pio\build\uno_r4_wifi\src\main.cpp.o] Error 1
========================================================================================= [FAILED] Took 3.07 seconds =========================================================================================
* 终端进程“C:\Users\xiang\.platformio\penv\Scripts\platformio.exe 'run'”已终止,退出代码: 1。
Totally wrong. You didn’t follow the required folder structure at all.
This is also explained in every README file in the lib/
folder
The c_cpp_properties.json
is auto-generated, never ever edit it yourself, if you’ve placed the files in the correct places and did the configuration right, this file will be automatically correct.
Also, where is the header file that belongs to that .c
file? You want to have a .h
file that declares all the functions implemented in the .c
file so that you can call it externally.
Thank you. Problem solved.
