Hello! I’m developing a program for ESP32. I use an external library in which there is a check of the following definitions:
#if defined(ESP8266) || defined(ESP32)
#define…
#define…
#elif defined(STM32_DEVICE)
#define…
#elif defined(SIM800)
#else
#define…
Question: where in the Platformio settings is #define ESP32 and how can I change this definition to its own value, for example SIM800
The particular ESP32
define is added in the python script controlling the build process for the espressif32 platform:
CPPDEFINES=[
"ESP32", "ESP_PLATFORM", ("F_CPU", "$BOARD_F_CPU"), "HAVE_CONFIG_H",
("MBEDTLS_CONFIG_FILE", '\\"mbedtls/esp_config.h\\"')
See platform-espressif32/main.py at develop · platformio/platform-espressif32 · GitHub. This is done for all devices on the ESP32 platform.
Then, each device is again described by a board JSON file in which additional defines can be added. E.g., the esp32dev.json
"build": {
"core": "esp32",
"extra_flags": "-DARDUINO_ESP32_DEV",
See platform-espressif32/esp32dev.json at develop · platformio/platform-espressif32 · GitHub.
I think what you want is to add a specific #define
in a build environment in your platformio.ino
file. You can do that by utilizing the build_flags
section (docs), e.g. by having a platformio.ini
like:
; build environment settings for a nodemcu board
[env:nodemcuv2]
platform = espressif8266
board = nodemcuv2
; additional compiler flags. define the SIM800 macro for this type of build
-D SIM800
; other flags..
My platformio.ini:
build_flags = -D SIM800
I added the flag build_flags = -D SIM800
However, the program is compiled for ESP32, this I see when debugging
Yes, the firmware is compiled for an ESP32 because that’s the board and platform you’ve given it? The build_flags
just defines the macro SIM800
. And that doesn’t work? Try adding a piece of code like
#ifdef SIM800
#error "SIM800 was defined"
#else
#error "SIM800 was NOT defined"
The compilation should fail giving you telling you in the “error” message whether it was defined or not.
Yes, in this case the compilation happens with an error:
src\main.h:5:2: error: #error “SIM800 was defined”
*** [.pioenvs\esp32dev\src\main.cpp.o] Error 1
[ERROR] Took 10.94 seconds
Good, that means that the macro definition works as intended. But you’re still having problems beyond that?
Understood! My mistake. It was really necessary to register build_flags = -D SIM800.
Thank you so much!
