Hi new here,
I’m struggling with my Platformio - ESPEASY - custom.h file. I’ve done the undef and define things. But i don’t understand how apply the settings using:
export PLATFORMIO_BUILD_FLAGS="’-DUSE_CUSTOM_H’"
… where do i put this line? I tried the serial console but that gave me the reply: “Unknown command!”
Should i add some line somewhere in my platformio.ini or ESPEasy-Globals.h …?
Realy confused …
Thanks !
Harry
Do you use Windows or Linux or Mac as your OS?
The line is supposed to export an environment variable PLATFORMIO_BUILD_FLAGS
with the value DUSE_CUSTOM_H
. This command will be valid for Linux and Mac.
Effectively you can also do the same by going into your projects platformio.ini
and adding the line
build_flags = -DUSE_CUSTOM_H
Hi Maxgerhardt thanks for your reply!
I use Windows, so i’ll have to edit the platformio.ini …
I’ll try that asap.
Harry
It somewhat worked … no errors or what so ever, but the settings used in the custom.h file were not set in the esp (nodemcu) … so i must be overviewing sonething …![:thinking: :thinking:](https://community.platformio.org/images/emoji/twitter/thinking.png?v=6)
Can you please write a
#error "CUSTOM CONFIG BEING USED"
into your Config.h
to see if its being included? The file must be named Config.h
. During recompilation it should throw you an error if its used. Does it do that?
Reading ESPEasy/ESPEasy-Globals.h at mega · letscontrolit/ESPEasy · GitHub it should work.
I do get this printed: " #warning “**** Using Settings from Custom.h File ***” "
but that’s from my custom.h, … i don’t have any config.h file as far as i can see …
The code linked above will include the Custom.h
file when the macro USE_CUSTOM_H
is defined, so that’s where your put your custom settings.
Can you upload a ZIP of your project to dropbox or open a github with your actual passwords removed so I can reproduce this?
