For example, consider a library somelib with the following directory structure:
somelib/ ├── examples/ │ └── platformio/ │ ├── etc/ │ ├── include/ │ ├── lib/ │ ├── src/ │ ├── test/ │ └── platformio.ini ├── include/ │ └── somelib.h ├── scripts/ │ └── platformio/ │ └── postinstall.py └── library.json
And the following relevant content in the PlatformIO files:
examples/platformio/platformio.ini[env] lib_deps = somelib=symlink://../..library.json{ "scripts": { "postinstall": "scripts/platformio/postinstall.py" } }scripts/platformio/postinstall.pyimport traceback try: Import("env") except: traceback.print_exc() try: env = DefaultEnvironment() except: traceback.print_exc() print(env)
Now when trying to run the example project, I encounter the following errors:
$ cd examples/platformio $ pio run Processing [...] --------------------------------------------------------------------------------------- Library Manager: Installing symlink://../../ Traceback (most recent call last): File "/opt/somelib/src/scripts/platformio/postinstall.py", line 4, in <module> Import("env") ^^^^^^ NameError: name 'Import' is not defined Traceback (most recent call last): File "/opt/somelib/src/scripts/platformio/postinstall.py", line 4, in <module> Import("env") ^^^^^^ NameError: name 'Import' is not defined During handling of the above exception, another exception occurred: Traceback (most recent call last): File "/opt/somelib/src/scripts/platformio/postinstall.py", line 8, in <module> env = DefaultEnvironment() ^^^^^^^^^^^^^^^^^^ NameError: name 'DefaultEnvironment' is not defined Traceback (most recent call last): File "/opt/somelib/src/scripts/platformio/postinstall.py", line 12, in <module> print(env) ^^^ NameError: name 'env' is not defined
Note I don’t see these errors when using, e.g., extra_scripts = post:[...] from a project’s platformio.ini. These errors appear only when using scripts defined in a library.json.
How should I be retrieving the construction environment in this case?
EDIT
If you are recreating this example, be aware that PlatformIO considers the library installed after producing these errors — i.e., running the project with pio run again will not execute the postinstall scripts or generate any errors. You will need to remove the installed library before running again:
$ pio pkg uninstall --no-save -l somelib # || rm -rf .pio
To the developers: consider ways to handle dependencies installed after their preinstall/postinstall scripts exit with non-zero status.
In my case above, I would prefer that the installation fail. Whether this means it is removed or is somehow marked incomplete, it should effectually cause PlatformIO to re-install it when I run the project again.
However, that solution may be extreme in the general case. Another option would be to highlight the command that failed in the error message/diagnostics so the user can re-run it manually without having to intervene with dependency management.
