When you compile a C++ program for the Arduino (or Mega) then the stack pointer register SP, whihc is made up of two 8 bit registers SPH and SPL, are initialised with a value which corresponds to the top of available RAM. Here’s the startup code for an Arduino UNO, which has 2048 bytes of SRAM:
000000b8 <__ctors_end>:
b8: 11 24 eor r1, r1
ba: 1f be out 0x3f, r1 ; 63
bc: cf ef ldi r28, 0xFF ; 255
be: d8 e0 ldi r29, 0x08 ; 8
c0: de bf out 0x3e, r29 ; 62
c2: cd bf out 0x3d, r28 ; 61
Registers r28 and r29 are loaded with 255 + (8 * 256), which is the initial stack pointer address. That works out at address 2303 decimal. Registers 0x3e and 0x3d are SPH and SPL respectively, so the stack is initially loaded with the address of the top of RAM. The memeory map for an ATmega328P is:
You can see that where the device has 2048 bytes of SRAM, the stack address is initialised to the top of that area, at address 0x08FF - which is what we see in the code above.
The stack grows downwards as it is used and may, if you have a recursive loop that never terminates, for example, start overwriting data in the lower end of SRAM.
TL;DR: There is no stack size! The stack size is all of available SRAM.
I suspect there’s a bug in the code you are running. Are you able to post it here?
