How can I build/upload all my builds at the same time?
I have a platformio.ini file with different envs, one for each board where I define some defines for each device. When I press upload (or build), it proceeds to build/upload everything one at a time. Since the builds are not dependent on another, would there be a way to make all those run in parallel?
Here is my .ini
[env]
platform = espressif8266
board = nodemcuv2
board_build.f_cpu = 160000000L
board_build.f_flash = 80000000L
upload_protocol = espota
    Time
    https://github.com/gmag11/NtpClient.git
    ESPAsyncUDP
    OneWire
    DallasTemperature
[env:1]
    -D PORT=4201
    -D PIO_FRAMEWORK_ARDUINO_LWIP2_HIGHER_BANDWIDTH
upload_port = 192.168.0.191
[env:2]
    -D PORT=4202
upload_port = 192.168.0.192
[env:3]
    -D PORT=4203
upload_port = 192.168.0.193
[env:4]
    -D PORT=4204
upload_port = 192.168.0.194
[env:5]
    -D PORT=4205
upload_port = 192.168.0.195
[env:6]
    -D PORT=4206
upload_port = 192.168.0.190
Thanks
Isn’t it just annoying when you’ve seen something, and can’t find it again later? :man_facepalming:
There isn’t direct support for this AFAIK, but I seem to remember Ivan mentioning in a post where someone ask a similar question, and presented a workaround - basically some way to query platformio for the build environments, and then use that to start multiple builds, one for each target environment. If I find it again, I’ll link it here.
If you are using *nix (mac should probably work too, but I can’t prove due to lack of hardware :wink: ) some kind of “shell magic” could solve your problem:
for e in $(pio project config |grep "env:"|cut -c5-); do (pio run -e $e &); done
