it works ok with arduinoide, how can i add it to platformio
hardware integration files can be find in the follow link
https://github.com/LGTMCU/Larduino_HSP/files/3333048/Larduino_HSP_v3.6c.zip
Can you please test the example in this repository: GitHub - maxgerhardt/larduino-pio: PlatformIO + Larduino Core example
Also, which board exactly do you use in the Arduino IDE? You have to set this in the platformio.ini.
i clone the repository and compile it , but got this error
Processing larduino_test (platform: atmelavr; board: lardu_328ps20; framework: arduino)
File "C:\Users\zj\.platformio\penv\lib\site-packages\platformio\__main__.py", line 102, in main
File "C:\Users\zj\.platformio\penv\lib\site-packages\click\core.py", line 764, in __call__
File "C:\Users\zj\.platformio\penv\lib\site-packages\click\core.py", line 717, in main
rv = self.invoke(ctx)
File "C:\Users\zj\.platformio\penv\lib\site-packages\platformio\commands\__init__.py", line 44, in invoke
return super(PlatformioCLI, self).invoke(ctx)
File "C:\Users\zj\.platformio\penv\lib\site-packages\click\core.py", line 1137, in invoke
File "C:\Users\zj\.platformio\penv\lib\site-packages\click\core.py", line 956, in invoke
File "C:\Users\zj\.platformio\penv\lib\site-packages\click\core.py", line 555, in invoke
return callback(*args, **kwargs)
File "C:\Users\zj\.platformio\penv\lib\site-packages\click\decorators.py", line 17, in new_func
File "C:\Users\zj\.platformio\penv\lib\site-packages\platformio\commands\run\command.py", line 138, in cli
is_test_running,
File "C:\Users\zj\.platformio\penv\lib\site-packages\platformio\commands\run\command.py", line 170, in process_env
result = {"env": name, "duration": time(), "succeeded": ep.process()}
File "C:\Users\zj\.platformio\penv\lib\site-packages\platformio\commands\run\processor.py", line 81, in process
result = p.run(build_vars, build_targets, self.silent, self.verbose, self.jobs)
File "C:\Users\zj\.platformio\penv\lib\site-packages\platformio\managers\platform.py", line 398, in run
self.configure_default_packages(options, targets)
File "C:\Users\zj\.platformio\platforms\atmelavr\platform.py", line 39, in configure_default_packages
self.packages[framework_package]["optional"] = False
KeyError: 'framework-arduino-avr-lgt8f'
It seems like it has failed to install the framework-arduino-avr-lgt8f package. That should have been downloaded automatically using the git which should be present on the system… Do you have git installed and available in the cmd.exe?
Can you please do the following:
C:\Users\zj\.platformio\packages in the Windows Explorerframework-arduino-avr-lgt8f
Larduino_HSP-master folder in the downloaded ZIP in that folder so that the filestructure is nowi got the problem
add framework-arduino-avr-lgt8f to the file %platformio_home%.platforms\atmelavr\platform.json
i can work with platformio now, thanks.
