Hi, I tried to build the civetweb example from the zephyr samples (.platformio\packages\framework-zephyr\samples\net\sockets\civetweb) for the Nucleo-F767zi with PlatformIO under Windows but I always failed…
Maybe some could tell me how to configure the project and get a successful build at the end.
What I’ve done (and tried) so far:
- Created a empty pio project with pio.ini:
platform = ststm32 board = nucleo_f767zi framework = zephyr
- Copied the content of the src folder from the civetweb sample into the projects src folder.
- Copied the prj.conf file from the sample into the projects zephyr folder.
- Build the project… Failed because libc_extensions.h was not found by civetweb.c
Okay, no problem at all… - Just added the src directory to include paths in projects zephyr/CMakeLists.txt:
zephyr_include_directories(../src)
- Build the project… Compling ok… Linking failed due to a bunch of undefined references.
You can find my (not building) test project at github: GitHub - julianobst/pio-zephyr-civetweb-example
I also tried to build the example with west and the zephyr toolchain under linux (native and docker) and both times the build was successful and worked as expected.
I would appreciate any help.
Many thanks,
Julian
