Hi, I am using my raspberry pi pico to developing with a library that needs a c++20 support.
However when I add the flag to switch to the gnu++2a in the platformio.ini, it still does not recognize the class
Is the compiler too old?
If yes, how should I upgrade?
If not, what should I do in this case?
Thank you
By default, PlatformIO uses arm-none-eabi GCC 9.2.1 for the raspberypi platform.
You are free to upgrade to one of the higher available versions, just like the documentation already says.
I tried to upgrade the compiler version.
When I try to compile it again, it suddenly begin to have lot more errors
This is the platformio.ini
Weird. However, the library explicitly says
This library works for
- arduino-pico:
Raspberry Pi Pico,Adafruit Feather RP2040, …
That Arduino core is using a custom toolchain. Since support for Arduino-Pico is however not included in the standard PlatformIO platform, you’ll have to this fork. .
I.e., try this exact platformio.ini:
[env:pico]
platform = https://github.com/maxgerhardt/platform-raspberrypi.git
; not: pico. Use the board associated with Arduino-Pico
board = rpipico
; standard is already C++17, should work fine for this lib. No build_flags.
Then you have not yet enabled Win32 Long Paths. Tiny USB inside the Pico-SDK has absurdly long filenames.
It works! This help heaps! Thank you!
