Hello, I was using the example code, LORAWAN_OLED, from this library, GitHub - Heltec-Aaron-Lee/WiFi_Kit_series: Arduino source codes and toolchain for WiFi_Kit_series made by HelTecAutomation.. I did the installed the esp32s core as per the documentation by running get.py from this https://github.com/Heltec-Aaron-Lee/WiFi_Kit_series/tree/master/esp32/tools. It is working fine on Arduino IDE. I migrated to platformIO and I am getting a lot of errors based on the toolchain-xtensa-esp32s3 wrong references. Can anyone tell, how I can fix this? Thank you in advance.
c:/users/zain/.platformio/packages/toolchain-xtensa-esp32s3/bin/…/lib/gcc/xtensa-esp32s3-elf/8.4.0/…/…/…/…/xtensa-esp32s3-elf/bin/ld.exe: .pio/build/heltec_wifi_lora_32_V3/src/main.cpp.o:(.literal._Z5setupv+0x10): undefined reference to `Mcu’
c:/users/zain/.platformio/packages/toolchain-xtensa-esp32s3/bin/…/lib/gcc/xtensa-esp32s3-elf/8.4.0/…/…/…/…/xtensa-esp32s3-elf/bin/ld.exe: .pio/build/heltec_wifi_lora_32_V3/src/main.cpp.o:(.literal._Z5setupv+0x20): undefined reference to `McuClass::begin()’
and more errors like this. Simple chipID example of ESP 32 is running fine.
