Hello everyone,
I’m working with a Heltec WiFi LoRa 32 V3 board, and I’m trying to set up a basic LoRa sender. Despite following the initial setup instructions, I’m encountering the following issue: the display on my board shows “Starting LoRa failed!”.
Here’s the sender code I’m using:
#include <heltec.h>
delay(1000); // Wait for stabilization
Serial.println("Initializing Heltec with LoRa...");
// Initialize Heltec with Display and LoRa
Heltec.begin(true /* Display */, true /* LoRa */, false /* BLE */);
Serial.println("Heltec initialized, configuring LoRa pins...");
// Manually configure LoRa module pins
LoRa.setPins(8 /* CS */, 12 /* RST */, 14 /* DIO0 */);
Serial.println("Pins set, initializing LoRa...");
// Check if the LoRa module initialized correctly
if (!LoRa.begin(868E6, true)) {
Serial.println("Starting LoRa failed! Check power and antenna connection.");
Heltec.display->clear();
Heltec.display->drawString(0, 0, "Starting LoRa failed!");
Heltec.display->display();
while (1); // Stop here if initialization failed
Serial.println("LoRa Initialized Successfully!");
Heltec.display->drawString(0, 0, "LoRa Sender Started!");
Serial.println("Sending packet...");
// Send a test packet
LoRa.beginPacket();
LoRa.print("Hello, this is a test message from LoRa!");
LoRa.endPacket();
delay(2000); // Wait 2 seconds before the next packet
Here is my platformio.ini configuration:
[env:heltec_wifi_lora_32_V3]
board = heltec_wifi_lora_32_V3
heltecautomation/Heltec ESP32 Dev-Boards@^1.1.2
Wire
I’ve double-checked the connections and antenna, but the initialization still fails with the message “Starting LoRa failed!”. Has anyone else encountered this issue with the Heltec LoRa V3, or is there something I might be missing in the code or setup?
Any insights or suggestions would be greatly appreciated!
Thanks in advance!
