This is persistent. I tried varying all the conditions I can think of.
I got some .ini stuff from a website about using the ESP-Prog. That’s the problem, isn’t it?
Linking .pio\build\esp32dev\firmware.elf
Retrieving maximum program size .pio\build\esp32dev\firmware.elf
Checking size .pio\build\esp32dev\firmware.elf
RAM: [= ] 11.8% (used 38680 bytes from 327680 bytes)
Flash: [====== ] 59.0% (used 773789 bytes from 1310720 bytes)
Building .pio\build\esp32dev\firmware.bin
esptool.py v3.3
Creating esp32 image...
Merged 25 ELF sections
AVAILABLE: cmsis-dap, esp-prog, espota, esptool, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa
Looking for upload port...
Using manually specified: /dev/cu.usbserial-5
Uploading .pio\build\esp32dev\firmware.bin
esptool.py v3.3
Serial port /dev/cu.usbserial-5
File "C:\Users\joema\.platformio\packages\tool-esptoolpy\esptool.py", line 5387, in <module>
_main()
File "C:\Users\joema\.platformio\packages\tool-esptoolpy\esptool.py", line 5380, in _main
main()
File "C:\Users\joema\.platformio\packages\tool-esptoolpy\esptool.py", line 4687, in main
esp = esp or get_default_connected_device(ser_list, port=args.port, connect_attempts=args.connect_attempts,
File "C:\Users\joema\.platformio\packages\tool-esptoolpy\esptool.py", line 114, in get_default_connected_device
_esp = chip_class(each_port, initial_baud, trace)
File "C:\Users\joema\.platformio\packages\tool-esptoolpy\esptool.py", line 320, in __init__
self._port = serial.serial_for_url(port)
File "C:\Users\joema\.platformio\penv\lib\site-packages\serial\__init__.py", line 90, in serial_for_url
instance.open()
File "C:\Users\joema\.platformio\penv\lib\site-packages\serial\serialwin32.py", line 64, in open
raise SerialException("could not open port {!r}: {!r}".format(self.portstr, ctypes.WinError()))
serial.serialutil.SerialException: could not open port '/dev/cu.usbserial-5':
FileNotFoundError(2, 'The system cannot find the path specified.', None, 3)
*** [upload] Error 1
======================== [FAILED] Took 57.96 seconds ========================
The terminal process "C:\Users\joema\.platformio\penv\Scripts\platformio.exe 'run', '--target', 'upload'" terminated with exit code: 1.
