Thank you for your help, I achieve to Set a hello World with my Heltec Wireless Stick V3 and send some in LoRaWAN. I have two more questions, the first is why is the reason that using other board for the project in this case the Heltec WiFi LoRa 32 (V3) make works with the Wireless stick, I’m really curious about it.
My second question is about the code, I need to hear data that arrives in Serial1 pins 19 and 20 at any time, and then send it thought LoRaWAN. I’m not sure about what command is using to send the data in the example. This is the code that I’m using.
#include "config.h"
#include <RadioLib.h>
#include <Preferences.h>
Preferences store;
RTC_DATA_ATTR uint16_t bootCount = 0;
RTC_DATA_ATTR uint16_t bootCountSinceUnsuccessfulJoin = 0;
RTC_DATA_ATTR uint8_t LWsession[RADIOLIB_LORAWAN_SESSION_BUF_SIZE];
// Configuración de tiempos ajustables
const uint32_t rejoinIntervalSeconds = 5; // Tiempo de reintento de unión en segundos
const uint32_t sendIntervalMillis = 10000; // Tiempo de envío de datos en milisegundos
bool sleepEnabled = true; // Controla si el dispositivo se duerme después de enviar
uint32_t sleepDurationSeconds = 10; // Duración del sueño en segundos
void print_wakeup_reason()
esp_sleep_wakeup_cause_t wakeup_reason = esp_sleep_get_wakeup_cause();
if (wakeup_reason == ESP_SLEEP_WAKEUP_TIMER)
Serial.println(F("Wake from sleep"));
else
Serial.print(F("Wake not caused by deep sleep: "));
Serial.println(wakeup_reason);
Serial.print(F("Boot count: "));
Serial.println(++bootCount);
void printStoredNonces()
uint8_t buffer[RADIOLIB_LORAWAN_NONCES_BUF_SIZE];
store.getBytes("nonces", buffer, RADIOLIB_LORAWAN_NONCES_BUF_SIZE);
Serial.println(F("Stored Nonces:"));
for (size_t i = 0; i < RADIOLIB_LORAWAN_NONCES_BUF_SIZE; i++)
Serial.print(buffer[i], HEX);
Serial.print(" ");
Serial.println();
void printStoredSession()
Serial.println(F("Stored Session Buffer:"));
for (size_t i = 0; i < RADIOLIB_LORAWAN_SESSION_BUF_SIZE; i++)
Serial.print(LWsession[i], HEX);
Serial.print(" ");
Serial.println();
void gotoSleep(uint32_t seconds)
Serial.print(F("Sleeping for "));
Serial.print(seconds);
Serial.println(F(" seconds\n"));
esp_sleep_enable_timer_wakeup(seconds * 1000UL * 1000UL);
Serial.flush();
esp_deep_sleep_start();
Serial.println(F("\n\n### Sleep failed, restarting ###\n"));
delay(5000);
ESP.restart();
int16_t lwActivate()
int16_t state = RADIOLIB_ERR_UNKNOWN;
node.beginOTAA(joinEUI, devEUI, nwkKey, appKey);
Serial.println(F("Recalling LoRaWAN nonces & session"));
store.begin("radiolib");
if (store.isKey("nonces"))
state = node.setBufferNonces(buffer);
debug(state != RADIOLIB_ERR_NONE, F("Restoring nonces buffer failed"), state, false);
state = node.setBufferSession(LWsession);
debug((state != RADIOLIB_ERR_NONE) && (bootCount > 1), F("Restoring session buffer failed"), state, false);
if (state == RADIOLIB_ERR_NONE)
Serial.println(F("Succesfully restored session - now activating"));
state = node.activateOTAA();
if (state == RADIOLIB_LORAWAN_SESSION_RESTORED)
Serial.println(F("Session successfully restored. Current credentials:"));
printStoredNonces();
printStoredSession();
store.end();
return state;
else
Serial.println(F("Failed to activate restored session, retrying join."));
else
Serial.println(F("No Nonces saved - starting fresh."));
state = RADIOLIB_ERR_NETWORK_NOT_JOINED;
while (state != RADIOLIB_LORAWAN_NEW_SESSION)
Serial.println(F("Join ('login') to the LoRaWAN Network"));
uint8_t *persist = node.getBufferNonces();
memcpy(buffer, persist, RADIOLIB_LORAWAN_NONCES_BUF_SIZE);
store.putBytes("nonces", buffer, RADIOLIB_LORAWAN_NONCES_BUF_SIZE);
if (state != RADIOLIB_LORAWAN_NEW_SESSION)
Serial.print(F("Join failed: "));
Serial.println(state);
delay(rejoinIntervalSeconds * 1000);
Serial.println(F("Joined"));
delay(1000);
store.end();
return state;
void setup()
while (!Serial)
delay(2000);
Serial.println(F("\nSetup"));
print_wakeup_reason();
int16_t state = radio.begin();
debug(state != RADIOLIB_ERR_NONE, F("Initialize radio failed"), state, true);
state = lwActivate();
if (state == RADIOLIB_LORAWAN_NEW_SESSION || state == RADIOLIB_LORAWAN_SESSION_RESTORED)
uint8_t value1 = radio.random(100);
uint16_t value2 = radio.random(2000);
uint8_t uplinkPayload[3];
uplinkPayload[0] = value1;
uplinkPayload[1] = highByte(value2);
uplinkPayload[2] = lowByte(value2);
state = node.sendReceive(uplinkPayload, sizeof(uplinkPayload));
debug((state < RADIOLIB_ERR_NONE) && (state != RADIOLIB_ERR_NONE), F("Error in sendReceive"), state, false);
Serial.print(F("FCntUp: "));
Serial.println(node.getFCntUp());
uint8_t *persist = node.getBufferSession();
memcpy(LWsession, persist, RADIOLIB_LORAWAN_SESSION_BUF_SIZE);
if (sleepEnabled)
gotoSleep(sleepDurationSeconds); // Dormir si está habilitado
else
Serial.println(F("Sleep disabled, staying awake."));
else
Serial.println(F("Failed to join the network, retrying."));
while (true)
break;
void loop() {}
