Hi everybody. I´m Grimor from Spain.
I´m trying to make this project with ESP32 wroom dev module and 64x32 RGB Led Matrix.
LIGHTWELL RGB MATRIX CLOCK
I´m usually do this things with arduino IDE but never with Platformio before.
So i installed Visual Studio Code on windows 10 PC and install Platformio. The code is alright beacuse is a comercial project from a chinesse company who sells the PCB and apps for this clock. I think i already downloaded all the libraries, but when i try to compìle i get several errors:
C:/Users/julii/.platformio/packages/framework-arduinoespressif32/tools/sdk/esp32/include/soc/esp32/include/soc/soc.h:146:31: note: in expansion of macro 'REG_READ'
(REG_WRITE((_r),((REG_READ(_r) & ~((_f##_V) << (_f##_S)))|(((_v) & (_f##_V))<<(_f##_S))))); \
C:/Users/julii/.platformio/packages/framework-arduinoespressif32/tools/sdk/esp32/include/soc/esp32/include/soc/io_mux_reg.h:91:46: note: in expansion of macro 'REG_SET_FIELD'
#define PIN_FUNC_SELECT(PIN_NAME, FUNC) REG_SET_FIELD(PIN_NAME, MCU_SEL, FUNC)
.pio/libdeps/esp32dev/SmartMatrix/src/esp32_i2s_parallel.c:136:6: note: in expansion of macro 'PIN_FUNC_SELECT'
PIN_FUNC_SELECT(GPIO_PIN_MUX_REG[gpio], PIN_FUNC_GPIO);
C:/Users/julii/.platformio/packages/framework-arduinoespressif32/tools/sdk/esp32/include/esp_common/include/esp_assert.h:23:28: error: expression in static assertion is not an integer
_Static_assert(__builtin_choose_expr(__builtin_constant_p(CONDITION), (CONDITION), 1), #MSG); \
C:/Users/julii/.platformio/packages/framework-arduinoespressif32/tools/sdk/esp32/include/soc/esp32/include/soc/soc.h:104:45: note: in definition of macro 'REG_WRITE'
(*(volatile uint32_t *)(_r)) = (_v); \
C:/Users/julii/.platformio/packages/framework-arduinoespressif32/tools/sdk/esp32/include/soc/esp32/include/soc/soc.h:96:38: note: in expansion of macro 'TRY_STATIC_ASSERT'
#define ASSERT_IF_DPORT_REG(_r, OP) TRY_STATIC_ASSERT(!IS_DPORT_REG(_r), (Cannot use OP for DPORT registers use DPORT_##OP));
C:/Users/julii/.platformio/packages/framework-arduinoespressif32/tools/sdk/esp32/include/soc/esp32/include/soc/soc.h:109:13: note: in expansion of macro 'ASSERT_IF_DPORT_REG'
ASSERT_IF_DPORT_REG((_r), REG_READ); \
.pio/libdeps/esp32dev/SmartMatrix/src/esp32_i2s_parallel.c:137:31: error: 'GPIO_MODE_DEF_OUTPUT' undeclared (first use in this function)
gpio_set_direction(gpio, GPIO_MODE_DEF_OUTPUT);
.pio/libdeps/esp32dev/SmartMatrix/src/esp32_i2s_parallel.c: In function 'i2s_parallel_setup_without_malloc':
.pio/libdeps/esp32dev/SmartMatrix/src/esp32_i2s_parallel.c:278:23: error: 'I2S0O_DATA_OUT0_IDX' undeclared (first use in this function); did you mean 'I2S_TX_DATA_NUM_S'?
sig_data_base=I2S0O_DATA_OUT0_IDX;
I2S_TX_DATA_NUM_S
.pio/libdeps/esp32dev/SmartMatrix/src/esp32_i2s_parallel.c:279:17: error: 'I2S0O_WS_OUT_IDX' undeclared (first use in this function); did you mean 'I2S_RX_WS_OUT_DELAY'?
sig_clk=I2S0O_WS_OUT_IDX;
I2S_RX_WS_OUT_DELAY
.pio/libdeps/esp32dev/SmartMatrix/src/esp32_i2s_parallel.c:282:27: error: 'I2S1O_DATA_OUT0_IDX' undeclared (first use in this function); did you mean 'I2S_TX_DATA_NUM_S'?
sig_data_base=I2S1O_DATA_OUT0_IDX;
I2S_TX_DATA_NUM_S
.pio/libdeps/esp32dev/SmartMatrix/src/esp32_i2s_parallel.c:285:27: error: 'I2S1O_DATA_OUT8_IDX' undeclared (first use in this function); did you mean 'I2S_TX_DATA_NUM_S'?
sig_data_base=I2S1O_DATA_OUT8_IDX;
I2S_TX_DATA_NUM_S
.pio/libdeps/esp32dev/SmartMatrix/src/esp32_i2s_parallel.c:289:17: error: 'I2S1O_WS_OUT_IDX' undeclared (first use in this function); did you mean 'I2S_RX_WS_OUT_DELAY'?
sig_clk=I2S1O_WS_OUT_IDX;
I2S_RX_WS_OUT_DELAY
.pio/libdeps/esp32dev/SmartMatrix/src/esp32_i2s_parallel.c:384:5: warning: implicit declaration of function 'esp_intr_alloc'; did you mean 'ets_intr_unlock'? [-Wimplicit-function-declaration]
esp_intr_alloc(ETS_I2S1_INTR_SOURCE, (int)(ESP_INTR_FLAG_IRAM | ESP_INTR_FLAG_LEVEL1), i2s_isr, NULL, NULL);
ets_intr_unlock
.pio/libdeps/esp32dev/SmartMatrix/src/esp32_i2s_parallel.c:384:48: error: 'ESP_INTR_FLAG_IRAM' undeclared (first use in this function); did you mean 'ESP_ERR_FLASH_BASE'?
ESP_ERR_FLASH_BASE
.pio/libdeps/esp32dev/SmartMatrix/src/esp32_i2s_parallel.c:384:69: error: 'ESP_INTR_FLAG_LEVEL1' undeclared (first use in this function); did you mean 'ESP_ERR_FLASH_BASE'?
ESP_ERR_FLASH_BASE
*** [.pio\build\esp32dev\lib202\SmartMatrix\esp32_i2s_parallel.c.o] Error 1
=========================================================== [FAILED] Took 67.07 seconds ===========================================================
* El proceso del terminal "C:\Users\julii\.platformio\penv\Scripts\platformio.exe 'run', '--target', 'upload'" finalizó con el código de salida 1.
* Las tareas reutilizarán el terminal, presione cualquier tecla para cerrarlo.
I´m just a newbie, so any help will be apreciated.
Thanks in advance.
