i have a project where i am having difficulties with one of my advanced scripts.
The script is meant to bundle the binary files into a zip archive - however it is bundling the main.cpp.o
instead of the firmware file.
Here is the script:
#!/usr/bin/env python3
Import("env")
import sys
from ntpath import basename
from zipfile import ZipFile
import json
def createZip(source, target, env):
if (
sys.platform.startswith("ubuntu")
or sys.platform.startswith("Linux")
or sys.platform.startswith("linux")
print("Program has been built, creating zip archive!")
my_flags = env.ParseFlags(env["BUILD_FLAGS"])
defines = dict()
for x in my_flags.get("CPPDEFINES"):
if type(x) is tuple:
(k, v) = x
defines[k] = v
elif type(x) is list:
k = x[0]
v = x[1]
defines[k] = v
else:
defines[x] = "" # empty value
s = lambda x: x.replace('"', "")
print("FLASH_EXTRA_IMAGES: %s\n" % env["FLASH_EXTRA_IMAGES"])
print("ESP32_APP_OFFSET: %s\n" % env["ESP32_APP_OFFSET"])
array_args = [env["FLASH_EXTRA_IMAGES"], env["ESP32_APP_OFFSET"]]
for (offset, image) in env["FLASH_EXTRA_IMAGES"]:
print("\nImage: %s" % str(image))
array_args.append(str(offset))
array_args.append(str(image))
for _source in source:
print("\nSource: %s" % str(_source))
array_args.append(str(_source))
n = 2
partitions_arg = array_args[1:]
partitions = final = [
partitions_arg[i * n : (i + 1) * n]
for i in range((len(partitions_arg) + n - 1) // n)
file_name = "./build/{0}/{1}.zip".format(str(env["PIOENV"]), env["PROGNAME"])
with ZipFile(file_name, "w") as archive:
print('\nCreating "' + archive.filename + '"', end="\n")
parts = []
for [offset, path] in partitions:
filename = basename(path)
archive.write(path, filename)
partition = {
"path": filename,
"offset": int(offset, 16),
parts.append(partition)
manifest = {
"chipFamily": "ESP32",
"parts": parts,
archive.writestr("manifest.json", json.dumps(manifest))
else:
print("Not running on Linux, skipping zip creation")
env.AddPostAction("$PROGPATH", createZip)
In particular - the issue is that the source
variable is only returning the main.cpp.o
file instead of the firmware binary.
This is how i call the script in the ini
file
extra_scripts =
pre:tools/customname.py
post:tools/createzip.py
How can i solve this?
Note: The firmware binary has a custom name.
