Help: STM32F407IGT6 Compilation Error with FreeRTOS
I use CubeMX to generate project code. When not using FreeRTOS, the project compiles normally. However, when using FreeRTOS, the project fails to compile regardless of the operation.
Normal Compilation (Without FreeRTOS, Not Using PlatformIO’s HAL Library)
[platformio]
src_dir = ./
[env:genericSTM32F407IGT6]
platform = ststm32
board = genericSTM32F407IGT6
; framework = stm32cube
-IInc
-IDrivers/STM32F4xx_HAL_Driver/Inc
-IDrivers/STM32F4xx_HAL_Driver/Inc/Legacy
-IDrivers/CMSIS/Device/ST/STM32F4xx/Include
-IDrivers/CMSIS/Include
Attempt After Adding FreeRTOS
Solution 1: Using Libraries Generated by CubeMX
[platformio]
src_dir = ./
platform = ststm32
-IInc
Error Message:
C:\Users\lemac\AppData\Local\Temp\ccVTkapf.s: Assembler messages:
C:\Users\lemac\AppData\Local\Temp\ccVTkapf.s:330: Error: selected processor does not support `vstmdbeq r0!,{s16-s31}' in Thumb mode
C:\Users\lemac\AppData\Local\Temp\ccVTkapf.s:332: Error: instruction not allowed in IT block -- `stmdb r0!,{r4-r11,r14}'
C:\Users\lemac\AppData\Local\Temp\ccVTkapf.s:352: Error: selected processor does not support `vldmiaeq r0!,{s16-s31}' in Thumb mode
C:\Users\lemac\AppData\Local\Temp\ccVTkapf.s:354: Error: instruction not allowed in IT block -- `msr psp,r0'
*** [.pio\build\genericSTM32F407IGT6\src\Middlewares\Third_Party\FreeRTOS\Source\portable\GCC\ARM_CM4F\port.o] Error 1
Consulting GPT yielded no results.
Solution 2: Using PlatformIO’s Built-in Libraries
Library Path:
C:\Users\lemac\.platformio\packages\framework-stm32cubef4\Middlewares\Third_Party\FreeRTOS\Source
Configuration:
[platformio]
src_dir = ./
platform = ststm32
-I Inc
-I C:/Users/lemac/.platformio/packages/framework-stm32cubef4/Middlewares/Third_Party/FreeRTOS/Source
-I C:/Users/lemac/.platformio/packages/framework-stm32cubef4/Middlewares/Third_Party/FreeRTOS/Source/CMSIS_RTOS_V2
-I C:/Users/lemac/.platformio/packages/framework-stm32cubef4/Middlewares/Third_Party/FreeRTOS/Source/include
-I C:/Users/lemac/.platformio/packages/framework-stm32cubef4/Middlewares/Third_Party/FreeRTOS/Source/portable
-I C:/Users/lemac/.platformio/packages/framework-stm32cubef4/Middlewares/Third_Party/FreeRTOS/Source/portable/Tasking/ARM_CM4F
build_src_filter = +<C:/Users/lemac/.platformio/packages/framework-stm32cubef4/Middlewares/Third_Party/FreeRTOS/Source/CMSIS_RTOS_V2> +</>
Error Message:
Linking .pio\build\genericSTM32F407IGT6\firmware.elf
arm-none-eabi-gcc: error: C:/Users/lemac/OneDrive/Documents/PlatformIO/Projects/.platformio/packages/framework-stm32cubef4/Middlewares/Third_Party/FreeRTOS/Source/CMSIS_RTOS_V2/cmsis_os2.o: No such file or directory
*** [.pio\build\genericSTM32F407IGT6\firmware.elf] Error 1
======================================= [FAILED] Took 2.72 seconds
Configuration:
[platformio]
src_dir = ./
platform = ststm32
-I Inc
; build_src_filter = +<C:/Users/lemac/.platformio/packages/framework-stm32cubef4/Middlewares/Third_Party/FreeRTOS/Source/CMSIS_RTOS_V2> +</>
.pio/build/genericSTM32F407IGT6/src/Src/freertos.o: In function `StartDefaultTask':
freertos.c:(.text.StartDefaultTask+0x4): undefined reference to `osDelay'
.pio/build/genericSTM32F407IGT6/src/Src/freertos.o: In function `MX_FREERTOS_Init':
freertos.c:(.text.MX_FREERTOS_Init+0x8): undefined reference to `osThreadNew'
.pio/build/genericSTM32F407IGT6/src/Src/main.o: In function `main':
main.c:(.text.startup.main+0x22): undefined reference to `osKernelInitialize'
main.c:(.text.startup.main+0x2a): undefined reference to `osKernelStart'
======================================= [FAILED] Took 4.30 seconds
Folder Structure:
