Greetings.
I hope someone can point me to the right direction. I spent 3days with this problem and no luck.
I have blue pill STM32F103c8 and i have a working arduino code that is working if I compile it and upload it with Arduino ide.
My code:
#include <Wire_slave.h>
#define SLAVE_ADDRESS 0x04
volatile bool receiveFlag = false;
volatile bool requestFlag = false;
String toSend;
uint8_t req_opcode; // request event register
uint8_t rcv_opcode; // receive event register
uint8_t speed;
String opcode_str;
void receiveEvent(int howMany) {
if (howMany == 0) return;
for (int i = 0; i < howMany; i++) {
temp[i] = Wire.read();
temp[i + 1] = '\0'; //add null after ea. char
rcv_opcode = temp[0];
for (int i = 0; i < howMany; ++i)
temp[i] = temp[i + 1];
receiveFlag = true;
void requestEvent()
requestFlag = true;
Wire.write(rcv_opcode);
// initialize i2c as slave
Wire.begin(SLAVE_ADDRESS);
Wire.onReceive(receiveEvent);
Wire.onRequest(requestEvent);
Serial.println("Ready!");
pinMode(PC13, OUTPUT);
digitalWrite(PC13, LOW);
delay(100);
digitalWrite(PC13, HIGH);
delay(100);
if (receiveFlag == true) {
Serial.println("receive register "+String(rcv_opcode)+".");
Serial.println("receive_flag "+String(temp)+".");
if (requestFlag == true) {
opcode_str = String("request ") + String(req_opcode) + String(".");
Serial.println(opcode_str);
If I try to compile in platformio I get error:
In file included from src\main.cpp:2:0:
C:\Users\uros\.platformio\packages\framework-arduinoststm32-maple\STM32F1\libraries\Wire/Wire_slave.h:1:2: error: #error "Something is trying to include Wire_slave.h when Wire.h is already included, they are mutually exclusive"
src\main.cpp: In function 'void receiveEvent(int)':
src\main.cpp:20:15: error: 'Wire' was not declared in this scope
src\main.cpp: In function 'void requestEvent()':
src\main.cpp:48:3: error: 'Wire' was not declared in this scope
src\main.cpp: In function 'void setup()':
src\main.cpp:53:3: error: 'Wire' was not declared in this scope
*** [.pio\build\bluepill_f103c8\src\main.cpp.o] Error 1
The same code works in Arduino IDE.
I also tried to exclude Wire library with lib_ignore = Wire in platformio.ini becouse I see that error is in \Wire/Wire_slave.h. But now I get error:
Linking .pio\build\bluepill_f103c8\firmware.elf
.pio\build\bluepill_f103c8\lib931\libWireSlave.a(i2c_slave.c.o): In function `i2c_bus_reset':
i2c_slave.c:(.text.i2c_bus_reset+0x0): multiple definition of `i2c_bus_reset'
.pio\build\bluepill_f103c8\FrameworkArduino\libmaple\i2c.c.o:i2c.c:(.text.i2c_bus_reset+0x0): first defined here
.pio\build\bluepill_f103c8\lib931\libWireSlave.a(i2c_slave.c.o): In function `i2c_init':
i2c_slave.c:(.text.i2c_init+0x0): multiple definition of `i2c_init'
.pio\build\bluepill_f103c8\FrameworkArduino\libmaple\i2c.c.o:i2c.c:(.text.i2c_init+0x0): first defined here
.pio\build\bluepill_f103c8\lib931\libWireSlave.a(i2c_slave.c.o): In function `i2c_master_enable':
i2c_slave.c:(.text.i2c_master_enable+0x0): multiple definition of `i2c_master_enable'
.pio\build\bluepill_f103c8\FrameworkArduino\libmaple\i2c.c.o:i2c.c:(.text.i2c_master_enable+0x0): first defined here
.pio\build\bluepill_f103c8\lib931\libWireSlave.a(i2c_slave.c.o): In function `i2c_master_xfer':
i2c_slave.c:(.text.i2c_master_xfer+0x0): multiple definition of `i2c_master_xfer'
.pio\build\bluepill_f103c8\FrameworkArduino\libmaple\i2c.c.o:i2c.c:(.text.i2c_master_xfer+0x0): first defined here
.pio\build\bluepill_f103c8\lib931\libWireSlave.a(i2c_slave.c.o): In function `_i2c_irq_handler':
i2c_slave.c:(.text._i2c_irq_handler+0x0): multiple definition of `_i2c_irq_handler'
.pio\build\bluepill_f103c8\FrameworkArduino\libmaple\i2c.c.o:i2c.c:(.text._i2c_irq_handler+0x0): first defined here
.pio\build\bluepill_f103c8\lib931\libWireSlave.a(i2c_slave.c.o): In function `_i2c_irq_error_handler':
i2c_slave.c:(.text._i2c_irq_error_handler+0x0): multiple definition of `_i2c_irq_error_handler'
.pio\build\bluepill_f103c8\FrameworkArduino\libmaple\i2c.c.o:i2c.c:(.text._i2c_irq_error_handler+0x0): first defined here
*** [.pio\build\bluepill_f103c8\firmware.elf] Error 1
Here is my platformio.ini file:
[env:bluepill_f103c8]
platform = ststm32
board = bluepill_f103c8
upload_protocol = stlink
monitor_port = COM1
board_build.mcu = stm32f103c8t6
board_build.core = maple
lib_ignore = Wire
Maybe you will ask why i use maple core. Because the wire_slave library works as i expect (using smbus library on raspberrypi), Library Wire doesn’t work as expected.
I hope someone can help me.
Thanks
