Hello everyone,
I’m trying to repurpose a SKR Mini E3 V3.0 board to run my own firmware instead of using it as a 3D printer controller. However, I ran into some serious issues while flashing it.
What I Did:
- Attempted to flash via ST-Link V2:
I tried flashing my custom firmware using ST-Link V2 but encountered an error due to Read-Out Protection (RDP). - Attempted to flash via SD card:
Since I couldn’t use ST-Link, I tried flashing the firmware via SD card.
Unfortunately, after this attempt, the board is now completely unresponsive, and I can no longer connect via ST-Link. - Current Situation:
The board does not boot or respond to any input. I suspect that I may have overwritten or corrupted the bootloader. - My PlatformIO Configuration (
platform.ini
[env:nucleo_g0b1re]
platform = ststm32
board = nucleo_g0b1re
upload_protocol = stlink
board_build.mcu = stm32g0b1ret6
What I Need Help With:
How can I recover my board and restore its firmware?
Is there a way to manually flash the bootloader and regain control?
What is the best method to safely flash custom firmware onto this board without bricking it again?
I would really appreciate any guidance! I know this might be a bit beyond my skill level, but I’m eager to learn and make this board work for a different project.
Thank you in advance for any help!
