I’m trying to get Serial2 working on my Nucleo L432KC, using PA10 (RX) and PA9 (TX). My goal is to verify that Serial2 is transmitting and receiving properly. However, I’m running into issues where:
- I receive garbled characters (
�� Serial2 Test Start
). - Serial2 does not seem to be receiving any data.
I suspect a baud rate mismatch, pin mapping issue, or hardware limitation. I’ve tried different baud rates and swapping TX/RX connections, but the issue persists.
// Define Serial2 explicitly on PA10 (RX) and PA9 (TX)
HardwareSerial ss(PA10, PA9);
Serial.begin(9600); // USB Serial for debugging
ss.begin(9600); // Initialize Serial2
delay(100);
Serial.println(“ Serial2 Test Start”);
ss.write(‘A’); // Send ‘A’ every second
delay(1000);
if (ss.available()) { // Read from Serial2
char received = ss.read();
Serial.print("📩 Serial2 Received: ");
Serial.println(received);
What I’ve Tried So Far:
- Checked TX/RX wiring:
- PA9 (TX) → FTDI RX
- PA10 (RX) → FTDI TX
- GND → GND
- Swapped TX and RX just in case
- Tested different baud rates (
9600
,115200
) - Added a small delay (
delay(100);
) afterss.begin()
- Tried a different UART port (PA2/PA3), but no luck
- Tried a simpler sketch with just
ss.println("Hello from Serial2!");
, but still no response
Checked PlatformIO settings inplatformio.ini
[env:nucleo_l432kc]
platform = ststm32
board = nucleo_l432kc
upload_protocol = stlink
monitor_port = COM2
monitor_speed = 9600
Wire
-D PIO_FRAMEWORK_ARDUINO_ENABLE_HWSERIAL2
