Hi, i have a issue when compiling a project ( THIS GitHub - Duckle29/Hollow-Clock-ESP: An ESP8266 or ESP32 firmware for the Hollow Clock) with Wemos Di mini ESP32 the error at the beginning gives it to me on pins D1 … D8 not declared, then I correct the pins with those of my Card type 22, 23,28 … etc and the compilation phase gives me the error on the ESPAsyncWiFiManager library.
Please help me !!!
Can’t reproduce.
>pio run -e wemos_d1_mini32
Processing wemos_d1_mini32 (platform: espressif32; board: wemos_d1_mini32; framework: arduino)
------------------------------------------------------------------------------------------------------------------------Verbose mode can be enabled via `-v, --verbose` option
CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/wemos_d1_mini32.html
PLATFORM: Espressif 32 (3.3.2) > WeMos D1 MINI ESP32
- framework-arduinoespressif32 3.10006.210326 (1.0.6)
- tool-esptoolpy 1.30100.210531 (3.1.0)
- toolchain-xtensa32 2.50200.97 (5.2.0)
Library Manager: Installing me-no-dev/ESP Async WebServer @ ^1.2.3
Library Manager: ESP Async WebServer @ 1.2.3 has been installed!
Library Manager: Installing dependencies...
Library Manager: Installing ESPAsyncTCP
Library Manager: ESPAsyncTCP @ 1.2.2 has been installed!
Library Manager: Installing AsyncTCP
Library Manager: AsyncTCP @ 1.1.1 has been installed!
Library Manager: Installing Hash
Library Manager: Already installed, built-in library
Library Manager: Installing alanswx/ESPAsyncWiFiManager @ ^0.23
Library Manager: ESPAsyncWiFiManager @ 0.23.0 has been installed!
Found 35 compatible libraries
|-- <ESP Async WebServer> 1.2.3
| |-- <AsyncTCP> 1.1.1
| |-- <FS> 1.0
| |-- <WiFi> 1.0
|-- <ESPAsyncWiFiManager> 0.23.0
| |-- <DNSServer> 1.1.0
| | |-- <WiFi> 1.0
| | |-- <AsyncTCP> 1.1.1
| | |-- <FS> 1.0
| | |-- <WiFi> 1.0
| |-- <WiFi> 1.0
|-- <WiFi> 1.0
Compiling .pio\build\wemos_d1_mini32\src\main.cpp.o
Generating partitions .pio\build\wemos_d1_mini32\partitions.bin
Compiling .pio\build\wemos_d1_mini32\lib1f7\AsyncTCP\AsyncTCP.cpp.o
Compiling .pio\build\wemos_d1_mini32\lib4ed\FS\FS.cpp.o
Compiling .pio\build\wemos_d1_mini32\lib4ed\FS\vfs_api.cpp.o
Compiling .pio\build\wemos_d1_mini32\lib586\WiFi\ETH.cpp.o
Compiling .pio\build\wemos_d1_mini32\lib586\WiFi\WiFi.cpp.o
Compiling .pio\build\wemos_d1_mini32\lib586\WiFi\WiFiAP.cpp.o
Compiling .pio\build\wemos_d1_mini32\lib586\WiFi\WiFiClient.cpp.o
Compiling .pio\build\wemos_d1_mini32\lib586\WiFi\WiFiGeneric.cpp.o
Compiling .pio\build\wemos_d1_mini32\lib586\WiFi\WiFiMulti.cpp.o
Compiling .pio\build\wemos_d1_mini32\lib586\WiFi\WiFiSTA.cpp.o
Compiling .pio\build\wemos_d1_mini32\lib586\WiFi\WiFiScan.cpp.o
Compiling .pio\build\wemos_d1_mini32\lib586\WiFi\WiFiServer.cpp.o
Compiling .pio\build\wemos_d1_mini32\lib586\WiFi\WiFiUdp.cpp.o
Compiling .pio\build\wemos_d1_mini32\lib1d3\ESP Async WebServer\AsyncEventSource.cpp.o
Compiling .pio\build\wemos_d1_mini32\lib1d3\ESP Async WebServer\AsyncWebSocket.cpp.o
Compiling .pio\build\wemos_d1_mini32\lib1d3\ESP Async WebServer\SPIFFSEditor.cpp.o
Archiving .pio\build\wemos_d1_mini32\lib4ed\libFS.a
Indexing .pio\build\wemos_d1_mini32\lib4ed\libFS.a
Compiling .pio\build\wemos_d1_mini32\lib1d3\ESP Async WebServer\WebAuthentication.cpp.o
Compiling .pio\build\wemos_d1_mini32\lib1d3\ESP Async WebServer\WebHandlers.cpp.o
Compiling .pio\build\wemos_d1_mini32\lib1d3\ESP Async WebServer\WebRequest.cpp.o
Compiling .pio\build\wemos_d1_mini32\lib1d3\ESP Async WebServer\WebResponses.cpp.o
Compiling .pio\build\wemos_d1_mini32\lib1d3\ESP Async WebServer\WebServer.cpp.o
Compiling .pio\build\wemos_d1_mini32\lib8df\DNSServer\DNSServer.cpp.o
Archiving .pio\build\wemos_d1_mini32\lib1f7\libAsyncTCP.a
Indexing .pio\build\wemos_d1_mini32\lib1f7\libAsyncTCP.a
Compiling .pio\build\wemos_d1_mini32\lib17c\ESPAsyncWiFiManager\ESPAsyncWiFiManager.cpp.o
Archiving .pio\build\wemos_d1_mini32\libFrameworkArduinoVariant.a
Indexing .pio\build\wemos_d1_mini32\libFrameworkArduinoVariant.a
Compiling .pio\build\wemos_d1_mini32\FrameworkArduino\Esp.cpp.o
Archiving .pio\build\wemos_d1_mini32\lib586\libWiFi.a
Compiling .pio\build\wemos_d1_mini32\FrameworkArduino\FunctionalInterrupt.cpp.o
Compiling .pio\build\wemos_d1_mini32\FrameworkArduino\HardwareSerial.cpp.o
Compiling .pio\build\wemos_d1_mini32\FrameworkArduino\IPAddress.cpp.o
Indexing .pio\build\wemos_d1_mini32\lib586\libWiFi.a
Compiling .pio\build\wemos_d1_mini32\FrameworkArduino\IPv6Address.cpp.o
Compiling .pio\build\wemos_d1_mini32\FrameworkArduino\MD5Builder.cpp.o
Compiling .pio\build\wemos_d1_mini32\FrameworkArduino\Print.cpp.o
Compiling .pio\build\wemos_d1_mini32\FrameworkArduino\Stream.cpp.o
Archiving .pio\build\wemos_d1_mini32\lib8df\libDNSServer.a
Indexing .pio\build\wemos_d1_mini32\lib8df\libDNSServer.a
Compiling .pio\build\wemos_d1_mini32\FrameworkArduino\StreamString.cpp.o
Compiling .pio\build\wemos_d1_mini32\FrameworkArduino\WMath.cpp.o
Compiling .pio\build\wemos_d1_mini32\FrameworkArduino\WString.cpp.o
Compiling .pio\build\wemos_d1_mini32\FrameworkArduino\base64.cpp.o
Compiling .pio\build\wemos_d1_mini32\FrameworkArduino\cbuf.cpp.o
Compiling .pio\build\wemos_d1_mini32\FrameworkArduino\esp32-hal-adc.c.o
Compiling .pio\build\wemos_d1_mini32\FrameworkArduino\esp32-hal-bt.c.o
.pio\libdeps\wemos_d1_mini32\ESPAsyncWiFiManager\ESPAsyncWiFiManager.cpp: In member function 'void AsyncWiFiManager::copySSIDInfo(wifi_ssid_count_t)':
.pio\libdeps\wemos_d1_mini32\ESPAsyncWiFiManager\ESPAsyncWiFiManager.cpp:314:12: warning: unused variable 'res' [-Wunused-variable]
bool res=WiFi.getNetworkInfo(i, wifiSSIDs[i].SSID, wifiSSIDs[i].encryptionType, wifiSSIDs[i].RSSI, wifiSSIDs[i].BSSID, wifiSSIDs[i].channel);
Compiling .pio\build\wemos_d1_mini32\FrameworkArduino\esp32-hal-cpu.c.o
Compiling .pio\build\wemos_d1_mini32\FrameworkArduino\esp32-hal-dac.c.o
Compiling .pio\build\wemos_d1_mini32\FrameworkArduino\esp32-hal-gpio.c.o
Compiling .pio\build\wemos_d1_mini32\FrameworkArduino\esp32-hal-i2c.c.o
Compiling .pio\build\wemos_d1_mini32\FrameworkArduino\esp32-hal-ledc.c.o
Compiling .pio\build\wemos_d1_mini32\FrameworkArduino\esp32-hal-log.c.o
Compiling .pio\build\wemos_d1_mini32\FrameworkArduino\esp32-hal-matrix.c.o
Compiling .pio\build\wemos_d1_mini32\FrameworkArduino\esp32-hal-misc.c.o
Compiling .pio\build\wemos_d1_mini32\FrameworkArduino\esp32-hal-psram.c.o
Compiling .pio\build\wemos_d1_mini32\FrameworkArduino\esp32-hal-rmt.c.o
Compiling .pio\build\wemos_d1_mini32\FrameworkArduino\esp32-hal-sigmadelta.c.o
Compiling .pio\build\wemos_d1_mini32\FrameworkArduino\esp32-hal-spi.c.o
Compiling .pio\build\wemos_d1_mini32\FrameworkArduino\esp32-hal-time.c.o
Compiling .pio\build\wemos_d1_mini32\FrameworkArduino\esp32-hal-timer.c.o
Compiling .pio\build\wemos_d1_mini32\FrameworkArduino\esp32-hal-touch.c.o
C:\Users\Max\.platformio\packages\framework-arduinoespressif32\cores\esp32\esp32-hal-spi.c: In function 'spiTransferBytesNL':
C:\Users\Max\.platformio\packages\framework-arduinoespressif32\cores\esp32\esp32-hal-spi.c:922:39: warning: initialization from incompatible pointer type [-Wincompatible-pointer-types]
uint8_t * last_out8 = &result[c_longs-1];
C:\Users\Max\.platformio\packages\framework-arduinoespressif32\cores\esp32\esp32-hal-spi.c:923:40: warning: initialization from incompatible pointer type [-Wincompatible-pointer-types]
uint8_t * last_data8 = &last_data;
Compiling .pio\build\wemos_d1_mini32\FrameworkArduino\esp32-hal-uart.c.o
Compiling .pio\build\wemos_d1_mini32\FrameworkArduino\libb64\cdecode.c.o
Compiling .pio\build\wemos_d1_mini32\FrameworkArduino\libb64\cencode.c.o
Compiling .pio\build\wemos_d1_mini32\FrameworkArduino\main.cpp.o
Compiling .pio\build\wemos_d1_mini32\FrameworkArduino\stdlib_noniso.c.o
Compiling .pio\build\wemos_d1_mini32\FrameworkArduino\wiring_pulse.c.o
Compiling .pio\build\wemos_d1_mini32\FrameworkArduino\wiring_shift.c.o
Archiving .pio\build\wemos_d1_mini32\lib17c\libESPAsyncWiFiManager.a
Indexing .pio\build\wemos_d1_mini32\lib17c\libESPAsyncWiFiManager.a
Archiving .pio\build\wemos_d1_mini32\libFrameworkArduino.a
Indexing .pio\build\wemos_d1_mini32\libFrameworkArduino.a
Archiving .pio\build\wemos_d1_mini32\lib1d3\libESP Async WebServer.a
Indexing .pio\build\wemos_d1_mini32\lib1d3\libESP Async WebServer.a
Linking .pio\build\wemos_d1_mini32\firmware.elf
Retrieving maximum program size .pio\build\wemos_d1_mini32\firmware.elf
Checking size .pio\build\wemos_d1_mini32\firmware.elf
RAM: [= ] 13.4% (used 43884 bytes from 327680 bytes)
Flash: [======= ] 73.9% (used 968169 bytes from 1310720 bytes)
Building .pio\build\wemos_d1_mini32\firmware.bin
esptool.py v3.1
Merged 1 ELF section
============== [SUCCESS] Took 33.65 seconds ==============
We’d need to see the full build output log.
Thanks for your quick response!!! This is OK?
-------------------------------------------------------------------------------------------------------------------------------------------------------------------Verbose mode can be enabled via `-v, --verbose` option
Library Manager: Installing RECOMMENDED
Warning! Could not find the package with 'RECOMMENDED' requirements for your system 'windows_amd64'
Found 81 compatible libraries
| |-- <AsyncTCP> 1.1.1
| |-- <FS> 1.0
| |-- <WiFi> 1.2.7
| | |-- <SPI> 1.0
|-- <ESPAsyncWiFiManager> 0.30.0
| | |-- <WiFi> 1.2.7
| | | |-- <SPI> 1.0
| | |-- <AsyncTCP> 1.1.1
| | |-- <FS> 1.0
| | |-- <WiFi> 1.2.7
| | | |-- <SPI> 1.0
| |-- <WiFi> 1.2.7
| | |-- <SPI> 1.0
|-- <WiFi> 1.2.7
| |-- <SPI> 1.0
Archiving .pio\build\wemos_d1_mini32\lib15a\libESP Async WebServer.a
Compiling .pio\build\wemos_d1_mini32\lib8eb\ESPAsyncWiFiManager\ESPAsyncWiFiManager.cpp.o
.pio\libdeps\wemos_d1_mini32\ESPAsyncWiFiManager\src\ESPAsyncWiFiManager.cpp: In member function 'void AsyncWiFiManager::setupConfigPortal()':
.pio\libdeps\wemos_d1_mini32\ESPAsyncWiFiManager\src\ESPAsyncWiFiManager.cpp:136:10: error: 'class WiFiClass' has no member named 'softAPConfig'
WiFi.softAPConfig(_ap_static_ip, _ap_static_gw, _ap_static_sn);
.pio\libdeps\wemos_d1_mini32\ESPAsyncWiFiManager\src\ESPAsyncWiFiManager.cpp:141:10: error: 'class WiFiClass' has no member named 'softAP'
WiFi.softAP(_apName, _apPassword); // password option
.pio\libdeps\wemos_d1_mini32\ESPAsyncWiFiManager\src\ESPAsyncWiFiManager.cpp:145:10: error: 'class WiFiClass' has no member named 'softAP'
WiFi.softAP(_apName);
.pio\libdeps\wemos_d1_mini32\ESPAsyncWiFiManager\src\ESPAsyncWiFiManager.cpp:150:17: error: 'class WiFiClass' has no member named 'softAPIP'
DEBUG_WM(WiFi.softAPIP());
.pio\libdeps\wemos_d1_mini32\ESPAsyncWiFiManager\src\ESPAsyncWiFiManager.cpp:158:45: error: 'class WiFiClass' has no member named 'softAPIP'
if (!dnsServer->start(DNS_PORT, "*", WiFi.softAPIP()))
.pio\libdeps\wemos_d1_mini32\ESPAsyncWiFiManager\src\ESPAsyncWiFiManager.cpp: In member function 'boolean AsyncWiFiManager::autoConnect(const char*, const char*, long unsigned int, long unsigned int)':
.pio\libdeps\wemos_d1_mini32\ESPAsyncWiFiManager\src\ESPAsyncWiFiManager.cpp:254:8: error: 'class WiFiClass' has no member named 'mode'
WiFi.mode(WIFI_STA);
.pio\libdeps\wemos_d1_mini32\ESPAsyncWiFiManager\src\ESPAsyncWiFiManager.cpp:254:13: error: 'WIFI_STA' was not declared in this scope
.pio\libdeps\wemos_d1_mini32\ESPAsyncWiFiManager\src\ESPAsyncWiFiManager.cpp: In member function 'String AsyncWiFiManager::networkListAsString()':
.pio\libdeps\wemos_d1_mini32\ESPAsyncWiFiManager\src\ESPAsyncWiFiManager.cpp:314:42: error: 'WIFI_AUTH_OPEN' was not declared in this scope
if (wifiSSIDs[i].encryptionType != WIFI_AUTH_OPEN)
.pio\libdeps\wemos_d1_mini32\ESPAsyncWiFiManager\src\ESPAsyncWiFiManager.cpp: In member function 'void AsyncWiFiManager::scan(boolean)':
.pio\libdeps\wemos_d1_mini32\ESPAsyncWiFiManager\src\ESPAsyncWiFiManager.cpp:350:50: error: no matching function for call to 'WiFiClass::scanNetworks(boolean&)'
wifi_ssid_count_t n = WiFi.scanNetworks(async);
In file included from .pio\libdeps\wemos_d1_mini32\ESPAsyncWiFiManager\src\ESPAsyncWiFiManager.h:20:0,
from .pio\libdeps\wemos_d1_mini32\ESPAsyncWiFiManager\src\ESPAsyncWiFiManager.cpp:14:
C:\Users\Giorgio\.platformio\lib\WiFi\src/WiFi.h:195:12: note: candidate: int8_t WiFiClass::scanNetworks()
int8_t scanNetworks();
C:\Users\Giorgio\.platformio\lib\WiFi\src/WiFi.h:195:12: note: candidate expects 0 arguments, 1 provided
.pio\libdeps\wemos_d1_mini32\ESPAsyncWiFiManager\src\ESPAsyncWiFiManager.cpp: In member function 'void AsyncWiFiManager::copySSIDInfo(wifi_ssid_count_t)':
.pio\libdeps\wemos_d1_mini32\ESPAsyncWiFiManager\src\ESPAsyncWiFiManager.cpp:357:12: error: 'WIFI_SCAN_FAILED' was not declared in this scope
if (n == WIFI_SCAN_FAILED)
.pio\libdeps\wemos_d1_mini32\ESPAsyncWiFiManager\src\ESPAsyncWiFiManager.cpp:361:17: error: 'WIFI_SCAN_RUNNING' was not declared in this scope
else if (n == WIFI_SCAN_RUNNING)
.pio\libdeps\wemos_d1_mini32\ESPAsyncWiFiManager\src\ESPAsyncWiFiManager.cpp:406:12: error: 'class WiFiClass' has no member named 'getNetworkInfo'
.pio\libdeps\wemos_d1_mini32\ESPAsyncWiFiManager\src\ESPAsyncWiFiManager.cpp: In member function 'void AsyncWiFiManager::startConfigPortalModeless(const char*, const char*)':
.pio\libdeps\wemos_d1_mini32\ESPAsyncWiFiManager\src\ESPAsyncWiFiManager.cpp:464:8: error: 'class WiFiClass' has no member named 'mode'
WiFi.mode(WIFI_AP_STA);
.pio\libdeps\wemos_d1_mini32\ESPAsyncWiFiManager\src\ESPAsyncWiFiManager.cpp:464:13: error: 'WIFI_AP_STA' was not declared in this scope
.pio\libdeps\wemos_d1_mini32\ESPAsyncWiFiManager\src\ESPAsyncWiFiManager.cpp: In member function 'void AsyncWiFiManager::setInfo()':
.pio\libdeps\wemos_d1_mini32\ESPAsyncWiFiManager\src\ESPAsyncWiFiManager.cpp:503:29: error: invalid conversion from 'uint8_t {aka unsigned char}' to 'wl_status_t'
[-fpermissive]
wifiStatus = WiFi.status();
.pio\libdeps\wemos_d1_mini32\ESPAsyncWiFiManager\src\ESPAsyncWiFiManager.cpp: In member function 'void AsyncWiFiManager::criticalLoop()':
.pio\libdeps\wemos_d1_mini32\ESPAsyncWiFiManager\src\ESPAsyncWiFiManager.cpp:519:32: error: 'class WiFiClass' has no member named 'scanComplete'
wifi_ssid_count_t n = WiFi.scanComplete();
.pio\libdeps\wemos_d1_mini32\ESPAsyncWiFiManager\src\ESPAsyncWiFiManager.cpp:523:12: error: 'class WiFiClass' has no member named 'scanDelete'
WiFi.scanDelete();
.pio\libdeps\wemos_d1_mini32\ESPAsyncWiFiManager\src\ESPAsyncWiFiManager.cpp: In member function 'boolean AsyncWiFiManager::startConfigPortal(const char*, const char*)':
.pio\libdeps\wemos_d1_mini32\ESPAsyncWiFiManager\src\ESPAsyncWiFiManager.cpp:577:8: error: 'class WiFiClass' has no member named 'mode'
.pio\libdeps\wemos_d1_mini32\ESPAsyncWiFiManager\src\ESPAsyncWiFiManager.cpp:577:13: error: 'WIFI_AP_STA' was not declared in this scope
.pio\libdeps\wemos_d1_mini32\ESPAsyncWiFiManager\src\ESPAsyncWiFiManager.cpp:613:28: error: no matching function for call to 'WiFiClass::disconnect(bool)'
WiFi.disconnect(false);
C:\Users\Giorgio\.platformio\lib\WiFi\src/WiFi.h:130:9: note: candidate: int WiFiClass::disconnect()
int disconnect(void);
C:\Users\Giorgio\.platformio\lib\WiFi\src/WiFi.h:130:9: note: candidate expects 0 arguments, 1 provided
.pio\libdeps\wemos_d1_mini32\ESPAsyncWiFiManager\src\ESPAsyncWiFiManager.cpp:618:20: error: no matching function for call to 'WiFiClass::begin()'
WiFi.begin(); // try to reconnect to AP
C:\Users\Giorgio\.platformio\lib\WiFi\src/WiFi.h:60:9: note: candidate: int WiFiClass::begin(char*)
int begin(char* ssid);
C:\Users\Giorgio\.platformio\lib\WiFi\src/WiFi.h:60:9: note: candidate expects 1 argument, 0 provided
C:\Users\Giorgio\.platformio\lib\WiFi\src/WiFi.h:70:9: note: candidate: int WiFiClass::begin(char*, uint8_t, const char*)
int begin(char* ssid, uint8_t key_idx, const char* key);
C:\Users\Giorgio\.platformio\lib\WiFi\src/WiFi.h:70:9: note: candidate expects 3 arguments, 0 provided
C:\Users\Giorgio\.platformio\lib\WiFi\src/WiFi.h:79:9: note: candidate: int WiFiClass::begin(char*, const char*)
int begin(char* ssid, const char *passphrase);
C:\Users\Giorgio\.platformio\lib\WiFi\src/WiFi.h:79:9: note: candidate expects 2 arguments, 0 provided
.pio\libdeps\wemos_d1_mini32\ESPAsyncWiFiManager\src\ESPAsyncWiFiManager.cpp:628:12: error: 'class WiFiClass' has no member named 'mode'
.pio\libdeps\wemos_d1_mini32\ESPAsyncWiFiManager\src\ESPAsyncWiFiManager.cpp:628:17: error: 'WIFI_STA' was not declared in this scope
.pio\libdeps\wemos_d1_mini32\ESPAsyncWiFiManager\src\ESPAsyncWiFiManager.cpp:649:14: error: 'class WiFiClass' has no member named 'mode'
.pio\libdeps\wemos_d1_mini32\ESPAsyncWiFiManager\src\ESPAsyncWiFiManager.cpp:649:19: error: 'WIFI_STA' was not declared in this scope
.pio\libdeps\wemos_d1_mini32\ESPAsyncWiFiManager\src\ESPAsyncWiFiManager.cpp: In member function 'uint8_t AsyncWiFiManager::connectWifi(String, String)':
.pio\libdeps\wemos_d1_mini32\ESPAsyncWiFiManager\src\ESPAsyncWiFiManager.cpp:692:99: error: no matching function for call to 'WiFiClass::config(IPAddress&, IPAddress&, IPAddress&, IPAddress&, IPAddress&)'
WiFi.config(_sta_static_ip, _sta_static_gw, _sta_static_sn, _sta_static_dns1, _sta_static_dns2);
C:\Users\Giorgio\.platformio\lib\WiFi\src/WiFi.h:85:10: note: candidate: void WiFiClass::config(IPAddress)
void config(IPAddress local_ip);
C:\Users\Giorgio\.platformio\lib\WiFi\src/WiFi.h:85:10: note: candidate expects 1 argument, 5 provided
C:\Users\Giorgio\.platformio\lib\WiFi\src/WiFi.h:92:10: note: candidate: void WiFiClass::config(IPAddress, IPAddress)
void config(IPAddress local_ip, IPAddress dns_server);
C:\Users\Giorgio\.platformio\lib\WiFi\src/WiFi.h:92:10: note: candidate expects 2 arguments, 5 provided
C:\Users\Giorgio\.platformio\lib\WiFi\src/WiFi.h:100:10: note: candidate: void WiFiClass::config(IPAddress, IPAddress, IPAddress)
void config(IPAddress local_ip, IPAddress dns_server, IPAddress gateway);
C:\Users\Giorgio\.platformio\lib\WiFi\src/WiFi.h:100:10: note: candidate expects 3 arguments, 5 provided
C:\Users\Giorgio\.platformio\lib\WiFi\src/WiFi.h:109:10: note: candidate: void WiFiClass::config(IPAddress, IPAddress, IPAddress, IPAddress)
void config(IPAddress local_ip, IPAddress dns_server, IPAddress gateway, IPAddress subnet);
C:\Users\Giorgio\.platformio\lib\WiFi\src/WiFi.h:109:10: note: candidate expects 4 arguments, 5 provided
.pio\libdeps\wemos_d1_mini32\ESPAsyncWiFiManager\src\ESPAsyncWiFiManager.cpp:709:26: error: no matching function for call to 'WiFiClass::disconnect(bool)'
.pio\libdeps\wemos_d1_mini32\ESPAsyncWiFiManager\src\ESPAsyncWiFiManager.cpp:711:26: error: invalid conversion from 'const char*' to 'char*' [-fpermissive]
WiFi.begin(ssid.c_str(), pass.c_str());
C:\Users\Giorgio\.platformio\lib\WiFi\src/WiFi.h:79:9: note: initializing argument 1 of 'int WiFiClass::begin(char*, const char*)'
.pio\libdeps\wemos_d1_mini32\ESPAsyncWiFiManager\src\ESPAsyncWiFiManager.cpp:715:21: error: request for member 'length' in 'WiFi.WiFiClass::SSID()', which is of non-class type 'char*'
if (WiFi.SSID().length() > 0)
.pio\libdeps\wemos_d1_mini32\ESPAsyncWiFiManager\src\ESPAsyncWiFiManager.cpp:724:28: error: no matching function for call to 'WiFiClass::disconnect(bool)'
.pio\libdeps\wemos_d1_mini32\ESPAsyncWiFiManager\src\ESPAsyncWiFiManager.cpp:726:18: error: no matching function for call to 'WiFiClass::begin()'
WiFi.begin();
.pio\libdeps\wemos_d1_mini32\ESPAsyncWiFiManager\src\ESPAsyncWiFiManager.cpp:731:18: error: no matching function for call to 'WiFiClass::begin()'
WiFi.begin();
.pio\libdeps\wemos_d1_mini32\ESPAsyncWiFiManager\src\ESPAsyncWiFiManager.cpp: In member function 'uint8_t AsyncWiFiManager::waitForConnectResult()':
.pio\libdeps\wemos_d1_mini32\ESPAsyncWiFiManager\src\ESPAsyncWiFiManager.cpp:756:17: error: 'class WiFiClass' has no member named 'waitForConnectResult'
return WiFi.waitForConnectResult();
.pio\libdeps\wemos_d1_mini32\ESPAsyncWiFiManager\src\ESPAsyncWiFiManager.cpp: In member function 'void AsyncWiFiManager::resetSettings()':
.pio\libdeps\wemos_d1_mini32\ESPAsyncWiFiManager\src\ESPAsyncWiFiManager.cpp:813:8: error: 'class WiFiClass' has no member named 'mode'
WiFi.mode(WIFI_AP_STA); // cannot erase if not in STA mode !
.pio\libdeps\wemos_d1_mini32\ESPAsyncWiFiManager\src\ESPAsyncWiFiManager.cpp:813:13: error: 'WIFI_AP_STA' was not declared in this scope
.pio\libdeps\wemos_d1_mini32\ESPAsyncWiFiManager\src\ESPAsyncWiFiManager.cpp:814:8: error: 'class WiFiClass' has no member named 'persistent'
WiFi.persistent(true);
.pio\libdeps\wemos_d1_mini32\ESPAsyncWiFiManager\src\ESPAsyncWiFiManager.cpp:818:29: error: no matching function for call to 'WiFiClass::disconnect(bool, bool)'
WiFi.disconnect(true, true);
C:\Users\Giorgio\.platformio\lib\WiFi\src/WiFi.h:130:9: note: candidate expects 0 arguments, 2 provided
.pio\libdeps\wemos_d1_mini32\ESPAsyncWiFiManager\src\ESPAsyncWiFiManager.cpp:820:8: error: 'class WiFiClass' has no member named 'persistent'
WiFi.persistent(false);
.pio\libdeps\wemos_d1_mini32\ESPAsyncWiFiManager\src\ESPAsyncWiFiManager.cpp: In member function 'String AsyncWiFiManager::infoAsString()':
.pio\libdeps\wemos_d1_mini32\ESPAsyncWiFiManager\src\ESPAsyncWiFiManager.cpp:1152:16: error: 'class WiFiClass' has no member named 'softAPIP'
page += WiFi.softAPIP().toString();
.pio\libdeps\wemos_d1_mini32\ESPAsyncWiFiManager\src\ESPAsyncWiFiManager.cpp:1155:16: error: 'class WiFiClass' has no member named 'softAPmacAddress'
page += WiFi.softAPmacAddress();
.pio\libdeps\wemos_d1_mini32\ESPAsyncWiFiManager\src\ESPAsyncWiFiManager.cpp:1164:27: error: no matching function for call to 'WiFiClass::macAddress()'
page += WiFi.macAddress();
C:\Users\Giorgio\.platformio\lib\WiFi\src/WiFi.h:137:14: note: candidate: uint8_t* WiFiClass::macAddress(uint8_t*)
uint8_t* macAddress(uint8_t* mac);
C:\Users\Giorgio\.platformio\lib\WiFi\src/WiFi.h:137:14: note: candidate expects 1 argument, 0 provided
*** [.pio\build\wemos_d1_mini32\lib8eb\ESPAsyncWiFiManager\ESPAsyncWiFiManager.cpp.o] Error 1
=================================================================== [FAILED] Took 5.20 seconds ===================================================================
PS C:\Users\Giorgio\Documents\PlatformIO\Projects\HOLLOW CLOCK 2 - WeMos D1 MINI ESP32>
Compiling with ESP8266 Board Success, but with the board ESP32 Error : .pio\build\esp32\lib661\ESPAsyncWiFiManager\ESPAsyncWiFiManager.cpp.o] Error 1
This is with ESP8266 Board:
> Executing task: C:\Users\Giorgio\.platformio\penv\Scripts\platformio.exe run --environment esp8266 <
Processing esp8266 (platform: espressif8266; board: d1_mini; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/espressif8266/d1_mini.html
PLATFORM: Espressif 8266 (3.2.0) > WeMos D1 R2 and mini
HARDWARE: ESP8266 80MHz, 80KB RAM, 4MB Flash
- framework-arduinoespressif8266 3.30002.0 (3.0.2)
- tool-esptool 1.413.0 (4.13)
- tool-esptoolpy 1.30000.201119 (3.0.0)
- toolchain-xtensa 2.100300.210717 (10.3.0)
Found 88 compatible libraries
| |-- <ESPAsyncTCP> 1.2.2
| |-- <Hash> 1.0
| |-- <ESP8266WiFi> 1.0
| |-- <WiFi> 1.2.7
| | |-- <SPI> 1.0
| |-- <DNSServer> 1.1.1
| | |-- <WiFi> 1.2.7
| | | |-- <SPI> 1.0
| | |-- <Hash> 1.0
| | |-- <WiFi> 1.2.7
| | | |-- <SPI> 1.0
| |-- <WiFi> 1.2.7
| | |-- <SPI> 1.0
|-- <WiFi> 1.2.7
| |-- <SPI> 1.0
Compiling .pio\build\esp8266\src\main.cpp.o
Generating LD script .pio\build\esp8266\ld\local.eagle.app.v6.common.ld
Compiling .pio\build\esp8266\libec6\ESPAsyncTCP\AsyncPrinter.cpp.o
Compiling .pio\build\esp8266\libec6\ESPAsyncTCP\ESPAsyncTCP.cpp.o
Compiling .pio\build\esp8266\libec6\ESPAsyncTCP\ESPAsyncTCPbuffer.cpp.o
Compiling .pio\build\esp8266\libec6\ESPAsyncTCP\SyncClient.cpp.o
Compiling .pio\build\esp8266\libec6\ESPAsyncTCP\tcp_axtls.c.o
Compiling .pio\build\esp8266\lib839\Hash\Hash.cpp.o
Compiling .pio\build\esp8266\libbb1\ESP8266WiFi\BearSSLHelpers.cpp.o
Compiling .pio\build\esp8266\libbb1\ESP8266WiFi\CertStoreBearSSL.cpp.o
Archiving .pio\build\esp8266\lib839\libHash.a
Compiling .pio\build\esp8266\libbb1\ESP8266WiFi\ESP8266WiFi.cpp.o
Compiling .pio\build\esp8266\libbb1\ESP8266WiFi\ESP8266WiFiAP.cpp.o
Compiling .pio\build\esp8266\libbb1\ESP8266WiFi\ESP8266WiFiGeneric.cpp.o
Compiling .pio\build\esp8266\libbb1\ESP8266WiFi\ESP8266WiFiGratuitous.cpp.o
Compiling .pio\build\esp8266\libbb1\ESP8266WiFi\ESP8266WiFiMulti.cpp.o
Archiving .pio\build\esp8266\libec6\libESPAsyncTCP.a
Compiling .pio\build\esp8266\libbb1\ESP8266WiFi\ESP8266WiFiSTA-WPS.cpp.o
Compiling .pio\build\esp8266\libbb1\ESP8266WiFi\ESP8266WiFiSTA.cpp.o
src\main.cpp: In function 'void setup()':
src\main.cpp:18:21: warning: comparison of integer expressions of different signedness: 'int' and 'unsigned int' [-Wsign-compare]
18 | for (int i = 0; i < sizeof(delays) / sizeof(delays[0]); i++)
Compiling .pio\build\esp8266\libbb1\ESP8266WiFi\ESP8266WiFiScan.cpp.o
Compiling .pio\build\esp8266\libbb1\ESP8266WiFi\WiFiClient.cpp.o
Compiling .pio\build\esp8266\libbb1\ESP8266WiFi\WiFiClientSecureBearSSL.cpp.o
Compiling .pio\build\esp8266\libbb1\ESP8266WiFi\WiFiServer.cpp.o
Compiling .pio\build\esp8266\libbb1\ESP8266WiFi\WiFiServerSecureBearSSL.cpp.o
Compiling .pio\build\esp8266\libbb1\ESP8266WiFi\WiFiUdp.cpp.o
Compiling .pio\build\esp8266\libbb1\ESP8266WiFi\enable_wifi_at_boot_time.cpp.o
Compiling .pio\build\esp8266\libe39\SPI\SPI.cpp.o
Compiling .pio\build\esp8266\lib4c6\WiFi\WiFi.cpp.o
Compiling .pio\build\esp8266\lib4c6\WiFi\WiFiClient.cpp.o
Compiling .pio\build\esp8266\lib4c6\WiFi\WiFiServer.cpp.o
Compiling .pio\build\esp8266\lib4c6\WiFi\WiFiUdp.cpp.o
Compiling .pio\build\esp8266\lib4c6\WiFi\utility\server_drv.cpp.o
Compiling .pio\build\esp8266\lib4c6\WiFi\utility\spi_drv.cpp.o
Archiving .pio\build\esp8266\libe39\libSPI.a
Compiling .pio\build\esp8266\lib4c6\WiFi\utility\wifi_drv.cpp.o
Compiling .pio\build\esp8266\libb63\ESP Async WebServer\AsyncEventSource.cpp.o
Archiving .pio\build\esp8266\libbb1\libESP8266WiFi.a
Compiling .pio\build\esp8266\libb63\ESP Async WebServer\AsyncWebSocket.cpp.o
Compiling .pio\build\esp8266\libb63\ESP Async WebServer\SPIFFSEditor.cpp.o
Compiling .pio\build\esp8266\libb63\ESP Async WebServer\WebAuthentication.cpp.o
Compiling .pio\build\esp8266\libb63\ESP Async WebServer\WebHandlers.cpp.o
C:\Users\Giorgio\.platformio\lib\WiFi\src\utility\spi_drv.cpp: In static member function 'static int SpiDrv::waitResponseCmd(uint8_t, uint8_t, uint8_t*, uint8_t*)':
C:\Users\Giorgio\.platformio\lib\WiFi\src\utility\spi_drv.cpp:127:10: warning: this 'else' clause does not guard... [-Wmisleading-indentation]
127 | }else \
C:\Users\Giorgio\.platformio\lib\WiFi\src\utility\spi_drv.cpp:160:9: note: in expansion of macro 'CHECK_DATA'
160 | CHECK_DATA(numParam, _data);
C:\Users\Giorgio\.platformio\lib\WiFi\src\utility\spi_drv.cpp:161:9: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the
'else'
161 | {
In file included from C:\Users\Giorgio\.platformio\lib\WiFi\src\utility\spi_drv.cpp:22:
C:\Users\Giorgio\.platformio\lib\WiFi\src/utility/spi_drv.h: At global scope:
C:\Users\Giorgio\.platformio\lib\WiFi\src/utility/spi_drv.h:41:13: warning: 'initialized' defined but not used [-Wunused-variable]
41 | static bool initialized = false;
C:\Users\Giorgio\.platformio\lib\WiFi\src\utility\wifi_drv.cpp: In static member function 'static uint8_t WiFiDrv::getEncTypeNetowrks(uint8_t)':
C:\Users\Giorgio\.platformio\lib\WiFi\src\utility\wifi_drv.cpp:451:10: warning: converting to non-pointer type 'uint8_t' {aka 'unsigned char'} from NULL [-Wconversion-null]
451 | return NULL;
C:\Users\Giorgio\.platformio\lib\WiFi\src\utility\wifi_drv.cpp: In static member function 'static int32_t WiFiDrv::getRSSINetoworks(uint8_t)':
C:\Users\Giorgio\.platformio\lib\WiFi\src\utility\wifi_drv.cpp:476:10: warning: converting to non-pointer type 'int' from NULL [-Wconversion-null]
476 | return NULL;
Compiling .pio\build\esp8266\libb63\ESP Async WebServer\WebRequest.cpp.o
Compiling .pio\build\esp8266\libb63\ESP Async WebServer\WebResponses.cpp.o
Archiving .pio\build\esp8266\lib4c6\libWiFi.a
Compiling .pio\build\esp8266\libb63\ESP Async WebServer\WebServer.cpp.o
Compiling .pio\build\esp8266\lib1dd\DNSServer\DNSServer.cpp.o
In file included from .pio\libdeps\esp8266\ESP Async WebServer\src\SPIFFSEditor.cpp:1:
.pio\libdeps\esp8266\ESP Async WebServer\src\SPIFFSEditor.h:16:101: warning: 'SPIFFS' is deprecated: SPIFFS has been deprecated. Please consider moving to LittleFS or other filesystems. [-Wdeprecated-declarations]
16 | SPIFFSEditor(const String& username=String(), const String& password=String(), const fs::FS& fs=SPIFFS);
In file included from .pio\libdeps\esp8266\ESP Async WebServer\src/ESPAsyncWebServer.h:27,
from .pio\libdeps\esp8266\ESP Async WebServer\src\SPIFFSEditor.h:3,
C:\Users\Giorgio\.platformio\packages\framework-arduinoespressif8266\cores\esp8266/FS.h:275:15: note: declared here
275 | extern fs::FS SPIFFS __attribute__((deprecated("SPIFFS has been deprecated. Please consider moving to LittleFS or other filesystems.")));
Archiving .pio\build\esp8266\lib1dd\libDNSServer.a
Compiling .pio\build\esp8266\lib8f0\ESPAsyncWiFiManager\ESPAsyncWiFiManager.cpp.o
Archiving .pio\build\esp8266\libFrameworkArduinoVariant.a
Compiling .pio\build\esp8266\FrameworkArduino\Crypto.cpp.o
Compiling .pio\build\esp8266\FrameworkArduino\Esp-frag.cpp.o
Compiling .pio\build\esp8266\FrameworkArduino\Esp-version.cpp.o
Compiling .pio\build\esp8266\FrameworkArduino\Esp.cpp.o
Compiling .pio\build\esp8266\FrameworkArduino\FS.cpp.o
Compiling .pio\build\esp8266\FrameworkArduino\FSnoop.cpp.o
Compiling .pio\build\esp8266\FrameworkArduino\FunctionalInterrupt.cpp.o
Compiling .pio\build\esp8266\FrameworkArduino\HardwareSerial.cpp.o
Compiling .pio\build\esp8266\FrameworkArduino\IPAddress.cpp.o
.pio\libdeps\esp8266\ESPAsyncWiFiManager\ESPAsyncWiFiManager.cpp: In member function 'void AsyncWiFiManager::copySSIDInfo(wifi_ssid_count_t)':
.pio\libdeps\esp8266\ESPAsyncWiFiManager\ESPAsyncWiFiManager.cpp:312:12: warning: unused variable 'res' [-Wunused-variable]
312 | bool res=WiFi.getNetworkInfo(i, wifiSSIDs[i].SSID, wifiSSIDs[i].encryptionType, wifiSSIDs[i].RSSI, wifiSSIDs[i].BSSID, wifiSSIDs[i].channel, wifiSSIDs[i].isHidden);
.pio\libdeps\esp8266\ESPAsyncWiFiManager\ESPAsyncWiFiManager.cpp: In member function 'boolean AsyncWiFiManager::isIp(String)':
.pio\libdeps\esp8266\ESPAsyncWiFiManager\ESPAsyncWiFiManager.cpp:1162:21: warning: comparison of integer expressions of different signedness: 'int' and 'unsigned int' [-Wsign-compare]
1162 | for (int i = 0; i < str.length(); i++) {
Compiling .pio\build\esp8266\FrameworkArduino\LwipDhcpServer-NonOS.cpp.o
Compiling .pio\build\esp8266\FrameworkArduino\LwipDhcpServer.cpp.o
Compiling .pio\build\esp8266\FrameworkArduino\LwipIntf.cpp.o
Compiling .pio\build\esp8266\FrameworkArduino\LwipIntfCB.cpp.o
Compiling .pio\build\esp8266\FrameworkArduino\MD5Builder.cpp.o
Compiling .pio\build\esp8266\FrameworkArduino\Print.cpp.o
.pio\libdeps\esp8266\ESPAsyncWiFiManager\ESPAsyncWiFiManager.cpp: At global scope:
.pio\libdeps\esp8266\ESPAsyncWiFiManager\ESPAsyncWiFiManager.cpp:150:15: warning: 'String byteToHexString(uint8_t*, uint8_t, String)' defined but not used [-Wunused-function]
150 | static String byteToHexString(uint8_t* buf, uint8_t length, String strSeperator="-") {
Compiling .pio\build\esp8266\FrameworkArduino\Schedule.cpp.o
Compiling .pio\build\esp8266\FrameworkArduino\StackThunk.cpp.o
Compiling .pio\build\esp8266\FrameworkArduino\Stream.cpp.o
Compiling .pio\build\esp8266\FrameworkArduino\StreamSend.cpp.o
Compiling .pio\build\esp8266\FrameworkArduino\Tone.cpp.o
Archiving .pio\build\esp8266\lib8f0\libESPAsyncWiFiManager.a
Compiling .pio\build\esp8266\FrameworkArduino\TypeConversion.cpp.o
Compiling .pio\build\esp8266\FrameworkArduino\Updater.cpp.o
Compiling .pio\build\esp8266\FrameworkArduino\WMath.cpp.o
Compiling .pio\build\esp8266\FrameworkArduino\WString.cpp.o
Compiling .pio\build\esp8266\FrameworkArduino\abi.cpp.o
Compiling .pio\build\esp8266\FrameworkArduino\aes_unwrap.cpp.o
Compiling .pio\build\esp8266\FrameworkArduino\base64.cpp.o
Compiling .pio\build\esp8266\FrameworkArduino\cbuf.cpp.o
Compiling .pio\build\esp8266\FrameworkArduino\cont.S.o
Compiling .pio\build\esp8266\FrameworkArduino\cont_util.cpp.o
Compiling .pio\build\esp8266\FrameworkArduino\core_esp8266_app_entry_noextra4k.cpp.o
Compiling .pio\build\esp8266\FrameworkArduino\core_esp8266_eboot_command.cpp.o
Compiling .pio\build\esp8266\FrameworkArduino\core_esp8266_features.cpp.o
Compiling .pio\build\esp8266\FrameworkArduino\core_esp8266_flash_quirks.cpp.o
Compiling .pio\build\esp8266\FrameworkArduino\core_esp8266_flash_utils.cpp.o
Compiling .pio\build\esp8266\FrameworkArduino\core_esp8266_i2s.cpp.o
Archiving .pio\build\esp8266\libb63\libESP Async WebServer.a
Compiling .pio\build\esp8266\FrameworkArduino\core_esp8266_main.cpp.o
Compiling .pio\build\esp8266\FrameworkArduino\core_esp8266_non32xfer.cpp.o
Compiling .pio\build\esp8266\FrameworkArduino\core_esp8266_noniso.cpp.o
Compiling .pio\build\esp8266\FrameworkArduino\core_esp8266_phy.cpp.o
Compiling .pio\build\esp8266\FrameworkArduino\core_esp8266_postmortem.cpp.o
Compiling .pio\build\esp8266\FrameworkArduino\core_esp8266_si2c.cpp.o
Compiling .pio\build\esp8266\FrameworkArduino\core_esp8266_sigma_delta.cpp.o
Compiling .pio\build\esp8266\FrameworkArduino\core_esp8266_spi_utils.cpp.o
Compiling .pio\build\esp8266\FrameworkArduino\core_esp8266_timer.cpp.o
Compiling .pio\build\esp8266\FrameworkArduino\core_esp8266_vm.cpp.o
Compiling .pio\build\esp8266\FrameworkArduino\core_esp8266_waveform_phase.cpp.o
Compiling .pio\build\esp8266\FrameworkArduino\core_esp8266_waveform_pwm.cpp.o
Compiling .pio\build\esp8266\FrameworkArduino\core_esp8266_wiring.cpp.o
Compiling .pio\build\esp8266\FrameworkArduino\core_esp8266_wiring_analog.cpp.o
Compiling .pio\build\esp8266\FrameworkArduino\core_esp8266_wiring_digital.cpp.o
Compiling .pio\build\esp8266\FrameworkArduino\core_esp8266_wiring_pulse.cpp.o
Compiling .pio\build\esp8266\FrameworkArduino\core_esp8266_wiring_pwm.cpp.o
Compiling .pio\build\esp8266\FrameworkArduino\core_esp8266_wiring_shift.cpp.o
Compiling .pio\build\esp8266\FrameworkArduino\crc32.cpp.o
Compiling .pio\build\esp8266\FrameworkArduino\debug.cpp.o
Compiling .pio\build\esp8266\FrameworkArduino\exc-c-wrapper-handler.S.o
Compiling .pio\build\esp8266\FrameworkArduino\exc-sethandler.cpp.o
Compiling .pio\build\esp8266\FrameworkArduino\flash_hal.cpp.o
Compiling .pio\build\esp8266\FrameworkArduino\gdb_hooks.cpp.o
Compiling .pio\build\esp8266\FrameworkArduino\heap.cpp.o
Compiling .pio\build\esp8266\FrameworkArduino\hwdt_app_entry.cpp.o
Compiling .pio\build\esp8266\FrameworkArduino\libb64\cdecode.cpp.o
Compiling .pio\build\esp8266\FrameworkArduino\libb64\cencode.cpp.o
Compiling .pio\build\esp8266\FrameworkArduino\libc_replacements.cpp.o
Compiling .pio\build\esp8266\FrameworkArduino\mmu_iram.cpp.o
Compiling .pio\build\esp8266\FrameworkArduino\reboot_uart_dwnld.cpp.o
Compiling .pio\build\esp8266\FrameworkArduino\spiffs\spiffs_cache.cpp.o
Compiling .pio\build\esp8266\FrameworkArduino\spiffs\spiffs_check.cpp.o
Compiling .pio\build\esp8266\FrameworkArduino\spiffs\spiffs_gc.cpp.o
Compiling .pio\build\esp8266\FrameworkArduino\spiffs\spiffs_hydrogen.cpp.o
Compiling .pio\build\esp8266\FrameworkArduino\spiffs\spiffs_nucleus.cpp.o
Compiling .pio\build\esp8266\FrameworkArduino\spiffs_api.cpp.o
Compiling .pio\build\esp8266\FrameworkArduino\sqrt32.cpp.o
Compiling .pio\build\esp8266\FrameworkArduino\stdlib_noniso.cpp.o
Compiling .pio\build\esp8266\FrameworkArduino\time.cpp.o
Compiling .pio\build\esp8266\FrameworkArduino\uart.cpp.o
Compiling .pio\build\esp8266\FrameworkArduino\umm_malloc\umm_info.c.o
Compiling .pio\build\esp8266\FrameworkArduino\umm_malloc\umm_integrity.c.o
Compiling .pio\build\esp8266\FrameworkArduino\umm_malloc\umm_local.c.o
Compiling .pio\build\esp8266\FrameworkArduino\umm_malloc\umm_malloc.cpp.o
Compiling .pio\build\esp8266\FrameworkArduino\umm_malloc\umm_poison.c.o
Archiving .pio\build\esp8266\libFrameworkArduino.a
Linking .pio\build\esp8266\firmware.elf
Retrieving maximum program size .pio\build\esp8266\firmware.elf
Checking size .pio\build\esp8266\firmware.elf
RAM: [===== ] 51.7% (used 42368 bytes from 81920 bytes)
Flash: [===== ] 50.0% (used 522701 bytes from 1044464 bytes)
Building .pio\build\esp8266\firmware.bin
Creating BIN file ".pio\build\esp8266\firmware.bin" using "C:\Users\Giorgio\.platformio\packages\framework-arduinoespressif8266\bootloaders\eboot\eboot.elf" and ".pio\build\esp8266\firmware.elf"
================================================================== [SUCCESS] Took 31.93 seconds ==================================================================
Environment Status Duration
esp8266 SUCCESS 00:00:31.932
You have globally installed a “WiFi” library in your PlatformIO folder which is interfering with the build. Remove the folder mentioned above and rebuild.
