My title sums it up fairly well I was trying to remove some unused files and clear some errors so I deleted my .pio file now it wont build it says it cant find a path to a file attached is the log when trying to build.
* Executing task: C:\Users\user\.platformio\penv\Scripts\platformio.exe run --environment003kb
Processing003kb (board:003kb; platform: link removed ; framework: arduino)
CONFIGURATION: linkremoved/page/boards/nordicnrf52/003kb.html
PLATFORM: Nordic nRF52 (4.4.0+sha.1a2639a) >003kb
HARDWARE: NRF52832 64MHz, 64KB RAM, 512KB Flash
DEBUG: Current (jlink) External (jlink, stlink)
- framework-arduinoadafruitnrf52 @ 1.10300.0 (1.3.0)
- tool-sreccat @ 1.164.0 (1.64)
- toolchain-gccarmnoneeabi @ 1.70201.0 (7.2.1)
LDF: Library Dependency Finder -> link removed /configure-pio-ldf
[nanopb] Installing Protocol Buffers dependencies
Requirement already satisfied: protobuf>=3.19.1 in c:\users\user\.platformio\penv\lib\site-packages (4.22.1)
[nanopb] No generation needed.
Found 24 compatible libraries
|-- ESP8266 and ESP32 OLED driver for SSD1306 displays @ 4.3.0+sha.da1ede4
| |-- Wire @ 1.0
| | |-- Adafruit TinyUSB Library
|-- OneButton @ 2.0.3
|-- arduino-fsm @ 2.2.0+sha.7db3702
|-- TinyGPSPlus @ 1.0.3+sha.127ad67
|-- Thread @ 0.0.0+sha.72921ac
|-- Nanopb @ 0.4.7
|-- ErriezCRC32 @ 1.0.1
|-- RadioLib @ 5.7.0
| |-- SPI @ 1.0
|-- QMC5883LCompass @ 1.1.1
| |-- Wire @ 1.0
|-- NonBlockingRTTTL @ 1.3.0
|-- SparkFun ATECCX08a Arduino Library @ 1.3.0+sha.52b5282
| |-- Wire @ 1.0
|-- SPI @ 1.0
|-- Wire @ 1.0
|-- Adafruit Bluefruit nRF52 Libraries
| |-- Adafruit Little File System Libraries @ 0.11.0
| |-- Adafruit Internal File System on Bluefruit nRF52 @ 0.11.0
|-- Adafruit nRFCrypto
Building in debug mode
Using meshtastic platformio-custom.py, firmware version 2.1.1.20bcf310
Compiling .pio\build\003kb\lib185\Adafruit_TinyUSB_Arduino\arduino\Adafruit_TinyUSB_API.cpp.o
The system cannot find the path specified.
Compiling .pio\build\003kb\lib185\Adafruit_TinyUSB_Arduino\arduino\Adafruit_USBD_CDC.cpp.o
Compiling .pio\build\003kb\lib185\Adafruit_TinyUSB_Arduino\arduino\Adafruit_USBD_Device.cpp.o
Compiling .pio\build\003kb\lib185\Adafruit_TinyUSB_Arduino\arduino\hid\Adafruit_USBD_HID.cpp.o
Compiling .pio\build\003kb\lib185\Adafruit_TinyUSB_Arduino\arduino\midi\Adafruit_USBD_MIDI.cpp.o
Compiling .pio\build\003kb\lib185\Adafruit_TinyUSB_Arduino\arduino\msc\Adafruit_USBD_MSC.cpp.o
Compiling .pio\build\003kb\lib185\Adafruit_TinyUSB_Arduino\arduino\ports\esp32\Adafruit_TinyUSB_esp32.cpp.o
Compiling .pio\build\003kb\lib185\Adafruit_TinyUSB_Arduino\arduino\ports\nrf\Adafruit_TinyUSB_nrf.cpp.o
Compiling .pio\build\003kb\lib185\Adafruit_TinyUSB_Arduino\arduino\ports\rp2040\Adafruit_TinyUSB_rp2040.cpp.o
Compiling .pio\build\003kb\lib185\Adafruit_TinyUSB_Arduino\arduino\ports\samd\Adafruit_TinyUSB_samd.cpp.o
Compiling .pio\build\003kb\lib185\Adafruit_TinyUSB_Arduino\arduino\webusb\Adafruit_USBD_WebUSB.cpp.o
Compiling .pio\build\003kb\lib185\Adafruit_TinyUSB_Arduino\class\audio\audio_device.c.o
Compiling .pio\build\003kb\lib185\Adafruit_TinyUSB_Arduino\class\bth\bth_device.c.o
Compiling .pio\build\003kb\lib185\Adafruit_TinyUSB_Arduino\class\cdc\cdc_device.c.o
Compiling .pio\build\003kb\lib185\Adafruit_TinyUSB_Arduino\class\dfu\dfu_device.c.o
Compiling .pio\build\003kb\lib185\Adafruit_TinyUSB_Arduino\class\dfu\dfu_rt_device.c.o
*** [.pio\build\003kb\lib185\Adafruit_TinyUSB_Arduino\arduino\Adafruit_TinyUSB_API.cpp.o] Error 1
*** [.pio\build\003kb\lib185\Adafruit_TinyUSB_Arduino\arduino\Adafruit_USBD_CDC.cpp.o] Error 1
*** [.pio\build\003kb\lib185\Adafruit_TinyUSB_Arduino\arduino\Adafruit_USBD_Device.cpp.o] Error 1
*** [.pio\build\003kb\lib185\Adafruit_TinyUSB_Arduino\arduino\hid\Adafruit_USBD_HID.cpp.o] Error 1
*** [.pio\build\003kb\lib185\Adafruit_TinyUSB_Arduino\arduino\midi\Adafruit_USBD_MIDI.cpp.o] Error 1
*** [.pio\build\003kb\lib185\Adafruit_TinyUSB_Arduino\arduino\msc\Adafruit_USBD_MSC.cpp.o] Error 1
*** [.pio\build\003kb\lib185\Adafruit_TinyUSB_Arduino\arduino\ports\esp32\Adafruit_TinyUSB_esp32.cpp.o] Error 1
*** [.pio\build\003kb\lib185\Adafruit_TinyUSB_Arduino\arduino\ports\nrf\Adafruit_TinyUSB_nrf.cpp.o] Error 1
*** [.pio\build\003kb\lib185\Adafruit_TinyUSB_Arduino\arduino\ports\rp2040\Adafruit_TinyUSB_rp2040.cpp.o] Error 1
*** [.pio\build\003kb\lib185\Adafruit_TinyUSB_Arduino\arduino\ports\samd\Adafruit_TinyUSB_samd.cpp.o] Error 1
*** [.pio\build\003kb\lib185\Adafruit_TinyUSB_Arduino\arduino\webusb\Adafruit_USBD_WebUSB.cpp.o] Error 1
*** [.pio\build\003kb\lib185\Adafruit_TinyUSB_Arduino\class\audio\audio_device.c.o] Error 1
*** [.pio\build\003kb\lib185\Adafruit_TinyUSB_Arduino\class\bth\bth_device.c.o] Error 1
*** [.pio\build\003kb\lib185\Adafruit_TinyUSB_Arduino\class\cdc\cdc_device.c.o] Error 1
*** [.pio\build\003kb\lib185\Adafruit_TinyUSB_Arduino\class\dfu\dfu_device.c.o] Error 1
*** [.pio\build\003kb\lib185\Adafruit_TinyUSB_Arduino\class\dfu\dfu_rt_device.c.o] Error 1
========================================================== [FAILED] Took 11.84 seconds ==========================================================
Environment Status Duration
003kb FAILED 00:00:11.839
===================================================== 1 failed, 0 succeeded in 00:00:11.839 =====================================================
