I follow the avr-stub instructions and I can’t run debug mode.
I have two problems.
The first is on my project. If I compile it with the debug env, I have the error fatal with Arduino library inside my libs :
src/main.cpp:1:10: fatal error: Arduino.h: No such file or directory
* Looking for Arduino.h dependency? Check our library registry!
* CLI > platformio lib search "header:Arduino.h"
* Web > https://platformio.org/lib/search?query=header:Arduino.h
compilation terminated.
Compiling .pio/build/unodebug/lib100/LogsFunctions/LogsFunctions.o
Compiling .pio/build/unodebug/lib8c9/ThermometreFunctions/ThermometreFuncitons.o
Compiling .pio/build/unodebug/lib364/TimeFunctions/TimeFunctions.o
*** [.pio/build/unodebug/src/main.o] Error 1
Indexing .pio/build/unodebug/libd8e/libavr-debugger.a
lib/KeysFunctions/KeysFunctions.cpp:3:10: fatal error: Arduino.h: No such file or directory
So I created a simple test project (blink Led) to test my configuration and this too does not work. The compilation is done, but I have an error.
I see that it is a problem with the launch of the GDB, but I do not find in the doc what to do. Apart from the platformio.ini configuration, I don’t see anything else in the doc.
In this site he talks about turning off the Optimizations. But I don’t understand about where avr-debugger folder mentioned. I don’t see any platform.local.txt and C++ (GDB/LLDB) is not listed in vscode.
#include "app_api.h" // only needed with flash breakpoints
#include "avr8-stub.h"
// initialize GDB stub
debug_init();
// initialize LED digital pin as an output.
pinMode(LED_BUILTIN, OUTPUT);
// turn the LED on (HIGH is the voltage level)
// wait for a second
delay(1000);
// turn the LED off by making the voltage LOW
delay(1000);
========================= [SUCCESS] Took 4.98 seconds =========================
undefinedPython Exception <type 'exceptions.ImportError'> No module named gdb:
warning:
Could not load the Python gdb module from `/Users/jenkins/jenkins/workspace/avr-gcc-staging/label/mac-mini/objdir/share/gdb/python'.
Limited Python support is available from the _gdb module.
Suggest passing --data-directory=/path/to/gdb/data-directory.
Reading symbols from /Users/kiwi/pCloud Drive/Programming/Arduino/debugTest/.pio/build/uno/firmware.elf...
done.
PlatformIO: debug_tool = avr-stub
I don’t know what is the path /Users/jenkins/jenkins/workspace but is not on my OS
Jenkins is a build server tool used to automate the building of binaries. GDB was build that way, and so the compiled binary refers to a path it has seen at compile time on the build system. Not sure whether the python error is integretal to this though.
Just to make sure this isn’t a path problem, can you create the project in a path that contains no spaces? E.g., /Users/kiwi/debugTest. There have been problems where that was the core issue.
Otherwise I’ll have you manually invoke avr-gdb and the initialization commands to check what’s going on after that.
Indeed, I had not noticed the space. But no, it does not influence.
========================= [SUCCESS] Took 4.47 seconds =========================
warning:
Reading symbols from /Users/kiwi/Documents/PlatformIO/Projects/211210-092201-arduino-blink/.pio/build/uno/firmware.elf...
done.
/dev/ttyUSB0: No such file or directory.
Hold up – you are on Mac, not Linux. Pretty sure /dev/ttyUSB0 is not a thing there and you’re just giving the wrong serial port. Open a CLI and execute pio device list. What device names does it show?
