Hello. I’m trying to install package of a custom uno r4 minima and use it on platformio, but without success.
With arduino IDE, I put the custom board package folder on “Arduino15/packages/myCustomBoard” (in customBoard we can find all ‘bootloader’, ‘core’, ‘viriants’, ‘libraray’ etc folder)
And it works fine like this.
So to do the same on platformio, I tried to follow this link steps https://docs.platformio.org/en/stable/platforms/creating_platform.html
but I get stuck on “Installation step 4” → I can’t find any the custom board created with the pio platform search cmd on the CLI.
Even if I create and add the exact same file as mentionned on the link, I can’t see the myplatform on the pio platform search list.
So need help to understand why please.
Oh you should not need to create your own platform. PlatformIO already has https://github.com/platformio/platform-renesas-ra/ as the base Platform supporting the Uno R4 Minima.
All you should need to do is
- Duplicate uno_r4_minima.json as
boards/my_custom_minima.json in the project folder (that can be created by creating a new project for the regular Uno R4 Minima)
- If you only added a new folder to
variants/ to support your board, add that same folder, e.g. myCustomBoard to <user home folder>\.platformio\packages\framework-arduino-renesas-uno\variants
- Edit the
my_custom_minima.json in regards to the variant field, this must match the name of the folder you added to variants (e.g., myCustomBoard). CHange Name and macros as needed too.
- Change your
platformio.ini to reference that new board
[env:my_custom_minima]
platform = renesas-ra
board = my_custom_minima
That’s it.
Thank you @maxgerhardt but I’m not sure to understand all you said.
1st: I need to create a new project IO by selecting uno r4 minima as board and save the project for example in “download” folder?
2nd: Put inside the folder created, the file uno_r4_minima.json ?
3th : Go to .platformio\packages\framework-arduino-renesas-uno\variants and copy my variant folder name inside ?
Can I copy framework-arduino-renesas-uno folder and rename it as I want ?
4th : For modifying my_custom_minima, what do you mean by ‘variant’ ? do you mean the file variant.cpp" I can find in the ‘variant\MINIMA’ folder ?
