I am new to compiling firmware with PlatformIO
I am under Windows 10 and the last version of Visual Studio, PlatformIO, Marlin auto Build.
Thanks a lot for your help
Robert
Every time I receive this kind of error:
Windows PowerShell
Copyright (C) Microsoft Corporation. Tous droits réservés.
Testez le nouveau systĂšme multiplateforme PowerShell https://aka.ms/pscore6
PS C:\Users\Robert\Desktop\skr12> platformio run -e STM32F103RC_btt
Processing STM32F103RC_btt (platform: ststm32@~10.0; board: genericSTM32F103RC; framework: arduino)
----------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------Verbose mode can be enabled via `-v, --verbose` option
'"CC"' n'est pas reconnu en tant que commande interne
ou externe, un programme exâcutable ou un fichier de commandes.
CalledProcessError: Command '"CC" -DTARGET_STM32F1 -D__MARLIN_FIRMWARE__ -DARDUINO_ARCH_STM32 -DDEBUG_LEVEL=0 -DSS_TIMER=4 -D__MARLIN_DEPS__ -w -dM -E -x c++ buildroot/share/PlatformIO/scripts/common-dependencies.h' returned non-zero exit status 1.:
File "C:\Users\Robert\.platformio\penv\lib\site-packages\platformio\builder\main.py", line 168:
env.SConscript(item, exports="env")
File "C:\Users\Robert\.platformio\packages\tool-scons\scons-local-4.0.1\SCons\Script\SConscript.py", line 598:
File "C:\Users\Robert\Desktop\skr12\buildroot\share\PlatformIO\scripts\common-dependencies.py", line 327:
apply_features_config()
File "C:\Users\Robert\Desktop\skr12\buildroot\share\PlatformIO\scripts\common-dependencies.py", line 141:
if not env.MarlinFeatureIsEnabled(feature):
File "C:\Users\Robert\.platformio\packages\tool-scons\scons-local-4.0.1\SCons\Environment.py", line 219:
File "C:\Users\Robert\Desktop\skr12\buildroot\share\PlatformIO\scripts\common-dependencies.py", line 292:
load_marlin_features()
File "C:\Users\Robert\Desktop\skr12\buildroot\share\PlatformIO\scripts\common-dependencies.py", line 280:
define_list = subprocess.check_output(cmd, shell=True).splitlines()
File "C:\Users\Robert\.platformio\python3\lib\subprocess.py", line 411:
**kwargs).stdout
File "C:\Users\Robert\.platformio\python3\lib\subprocess.py", line 512:
output=stdout, stderr=stderr)
============================================================================== [FAILED] Took 0.75 seconds ==============================================================================
Environment Status Duration
STM32F103RC_btt FAILED 00:00:00.747
Thanks for your answer,
Robert
- Itâs Visual Studio Code
- Itâs the last version of Marlin, 2.0.7.2
PS C:\Users\Robert\Desktop\skr12> pio system info
PlatformIO Core 5.0.4
Python 3.7.7-final.0
System Type windows_amd64
Platform Windows-10
File System Encoding utf-8
Locale Encoding cp1252
PlatformIO Core Directory C:\Users\Robert\.platformio
PlatformIO Core Executable C:\Users\Robert\.platformio\penv\Scripts\platformio.exe
Python Executable c:\users\robert\.platformio\penv\scripts\python.exe
Global Libraries 0
Development Platforms 2
Tools & Toolchains 11
It is known that this bug appears for some users ([BUG] 'CC' is not recognized as an internal or external command · Issue #20671 · MarlinFirmware/Marlin · GitHub).
The Marlin devs (and me) are desperately trying to track down why this happens because it works on our computers.
Does the file C:\Users\Robert\.platformio\packages\toolchain-gccarmnoneeabi\bin\arm-none-eabi-gcc.exe exist?
Have you tried removing the .pio folder in the Marlin project folder and retry building?
Have you tried removing all folders C:\Users\Robert\.platformio\packages\toolchain-gccarmnoneeabi* (there might be multiple ones) and retry building?
If that fails, please do as described in Issues building with fresh marlin firmware and PlatformIO 2.2.1 - #25 by maxgerhardt but in the [env:STM32F103RC_btt] section instead of the mega2560 one.
Logs can be posted here in Markdown code format (tripple-backquote block).
Does the file C:\Users\Robert\.platformio\packages\toolchain-gccarmnoneeabi\bin\arm-none-eabi-gcc.exe exist? NO
I removed all folders from .platformio
Reinstall platformIO
Retry the compilation and received this message:
Windows PowerShell
Testez le nouveau systĂšme multiplateforme PowerShell Install PowerShell on Windows, Linux, and macOS - PowerShell | Microsoft Learn
----------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------C:\Users\Robert.platformio\python3\python.exe: canât open file âC:\Users\Robert.platformio\packages\tool-scons\scons.pyâ: [Errno 2] No such file or directory
============================================================================== [FAILED] Took 0.08 seconds ==============================================================================
STM32F103RC_btt FAILED 00:00:00.078
======================================================================== 1 failed, 0 succeeded in 00:00:00.078 ========================================================================
PS C:\Users\Robert\Desktop\skr12> echo âdoneâ >D:\Temp\ipc
and scons.py exist and I can open it with notepad+
I shall try an installation on my old laptop ( Macpro)
The problem is , maybe, linked at my old Windows 10 installationâŠ
Very weird if the file is there. Do you have some antivirus enabled on your system that could interfere? Can you temporarily disable it?
Also you can remove all folders within C:\Users\Robert\.platformio\packages\ and rebuild the project, and it should cleanly redownload all packages.
You can maybe also try the marlin version downloadable at https://github.com/MarlinFirmware/Marlin/archive/bugfix-2.0.x.zip for the bugfix-2.0.x branch, that may have a fixed script.
This morning, I tried the compilation on my old Macbook( 10years); and it work perfectly!!!
The problem is certainly with my Windows 10 installation,
The next step will be : a Windows reinstallation from scratch( but not for todayâŠ)
A great âTHANKSâ for your support, and for me this case is closed.
Robert
