Help: cannot open source file "wifi101.h" (dependency of "WIFIConnectorMKR1000.h")
Hi.
I’m new to programming, I’m working on a very small school project, it’s about connecting our arduino to the internet and transferring the data from the tmp36 sensor to thingsboard, our teacher gave us a ready made code, and we just need to build it and upload it to arduino mkr1000.
I use platformeIO being in vscode which runs on Linux Ubuntu 21.10(64 bits), I downloaded two libraries (MQTT and WIFI101) to use it for internet connection and data transfer.
Except that, after downloading the libraries, I have this problem that persists, I have struggled in the forums to find a solution in vain.
If someone can help me, I’d be really happy.
I am new (Linux, vscode, platformeio, arduino, cpp)
Here is the the errors that display.
1- #include errors detected. Please update your includePath. Squiggles are disabled for this translation unit (/home/yvan/Documents/PlatformIO/Projects/IoTMP36/src/main.cpp).
2- cannot open source file “wifi101.h” (dependency of “WIFIConnector_MKR1000.h”)
 > Executing task in folder IoTMP36: platformio run <
Processing mkr1000USB (platform: atmelsam; board: mkr1000USB; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/atmelsam/mkr1000USB.html
PLATFORM: Atmel SAM (7.0.0) > Arduino MKR1000
HARDWARE: SAMD21G18A 48MHz, 32KB RAM, 256KB Flash
DEBUG: Current (atmel-ice) External (atmel-ice, blackmagic, jlink)
 - framework-arduino-samd 1.8.11
 - framework-cmsis 1.40500.0 (4.5.0)
 - framework-cmsis-atmel 1.2.2
Found 14 compatible libraries
|-- <WiFi101> 0.16.1
|   |-- <SPI> 1.0
|-- <MQTT> 2.5.0
|-- <SPI> 1.0
Compiling .pio/build/mkr1000USB/src/main.cpp.o
In file included from src/main.cpp:11:0:
include/WIFIConnector_MKR1000.h:13:10: fatal error: wifi101.h: No such file or directory
* Looking for wifi101.h dependency? Check our library registry!
* CLI  > platformio lib search "header:wifi101.h"
* Web  > https://platformio.org/lib/search?query=header:wifi101.h
 #include <wifi101.h>
compilation terminated.
Compiling .pio/build/mkr1000USB/libde3/WiFi101/WiFiServer.cpp.o
Compiling .pio/build/mkr1000USB/libde3/WiFi101/WiFiUdp.cpp.o
Compiling .pio/build/mkr1000USB/libde3/WiFi101/bsp/source/nm_bsp_arduino.c.o
*** [.pio/build/mkr1000USB/src/main.cpp.o] Error 1
========================================= [FAILED] Took 1.57 seconds =========================================
The terminal process "platformio 'run'" terminated with exit code: 1.
If you need more information for understant me, kindly ask me. thanks.
You are on Linux where you have to take care to correctly spell the filenames in regards to the upper- and lowercasing. Windows ignores upper/lowercase in the filename.
Since you see m to want to use the WiFi101 library, it has a header called WiFi101.h. Not wifi101.h. (As can also be seen in tutorials). Change the code in your project’s include/WIFIConnector_MKR1000.h file accordingly.
Thank you, that’s exactly the solution.
By the way, my teacher’s code was developed under windows, therefore, I just did copy and paste, I couldn’t imagine for a moment that this could happen.
Thank you very much, I had a hard time to find the solution.
Thanks again.
