Hello, I cannot create a project, please help me. It gives me an error code. I would appreciate it if you could provide me with a very clear solution.
PIO Core Call Error:
The following files/directories have been created in C:\Users\efeal\OneDrive\Documenten\PlatformIO\Projects\ADSFAFAFA
lib - Put project specific (private) libraries here
Resolving deneyapkartg dependencies...
Already up-to-date.
Updating metadata for the vscode IDE...
UserSideException: Processing deneyapkartg (platform: espressif32; board: deneyapkartg; framework: espidf)
CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/deneyapkartg.html
PLATFORM: Espressif 32 (6.7.0) > Deneyap Kart G
HARDWARE: ESP32C3 160MHz, 320KB RAM, 4MB Flash
DEBUG: Current (cmsis-dap) External (cmsis-dap, esp-bridge, esp-builtin, esp-prog, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa)
- framework-espidf @ 3.50201.240515 (5.2.1)
- tool-cmake @ 3.16.4
- tool-idf @ 1.0.1
- tool-mconf @ 1.4060000.20190628 (406.0.0)
- tool-ninja @ 1.9.0
- tool-riscv32-esp-elf-gdb @ 11.2.0+20220823
- tool-xtensa-esp-elf-gdb @ 11.2.0+20230208
- toolchain-esp32ulp @ 1.23500.220830 (2.35.0)
- toolchain-riscv32-esp @ 13.2.0+20230928
No pyvenv.cfg file
CalledProcessError: Command '['C:\\Users\\efeal\\.platformio\\penv\\.espidf-5.2.1\\Scripts\\python.exe', '-m', 'pip', 'list', '--format=json', '--disable-pip-version-check']' returned non-zero exit status 106.:
File "C:\Users\efeal\.platformio\penv\Lib\site-packages\platformio\builder\main.py", line 173:
File "C:\Users\efeal\.platformio\packages\tool-scons\scons-local-4.7.0\SCons\Script\SConscript.py", line 612:
File "C:\Users\efeal\.platformio\packages\tool-scons\scons-local-4.7.0\SCons\Script\SConscript.py", line 279:
File "C:\Users\efeal\.platformio\platforms\espressif32\builder\main.py", line 368:
File "C:\Users\efeal\.platformio\packages\tool-scons\scons-local-4.7.0\SCons\Util\envs.py", line 251:
File "C:\Users\efeal\.platformio\penv\Lib\site-packages\platformio\builder\tools\piobuild.py", line 61:
env.ProcessProgramDeps()
File "C:\Users\efeal\.platformio\penv\Lib\site-packages\platformio\builder\tools\piobuild.py", line 121:
File "C:\Users\efeal\.platformio\penv\Lib\site-packages\platformio\builder\tools\piobuild.py", line 347:
SConscript(env.GetFrameworkScript(name), exports="env")
File "C:\Users\efeal\.platformio\packages\tool-scons\scons-local-4.7.0\SCons\Script\SConscript.py", line 676:
return method(*args, **kw)
File "C:\Users\efeal\.platformio\platforms\espressif32\builder\frameworks\espidf.py", line 1315:
install_python_deps()
File "C:\Users\efeal\.platformio\platforms\espressif32\builder\frameworks\espidf.py", line 1193:
installed_packages = _get_installed_pip_packages(python_exe_path)
File "C:\Users\efeal\.platformio\platforms\espressif32\builder\frameworks\espidf.py", line 1153:
pip_output = subprocess.check_output(
File "C:\Users\efeal\.platformio\python3\Lib\subprocess.py", line 466:
return run(*popenargs, stdout=PIPE, timeout=timeout, check=True,
File "C:\Users\efeal\.platformio\python3\Lib\subprocess.py", line 571:
raise CalledProcessError(retcode, process.args,
========================== [FAILED] Took 0.78 seconds ==========================
