Header files and good practice. Harder than I thought
Dear forum.
I have a hard time grasping the ‘good practice’ rules for header files. Got a main.cpp file and I have put most of the includes and global variables in the main.h file. Also all function declaration go into the main.h file.
And -also good practice I thought- I defined a version string as in:
#define VERSION “Version 1.0 10 february 2025”.
And put that in the main.h header file as well.
Now I have another cpp file -lets call it 2nd.cpp) with some function(s) in which the #define VERSION is used (as in Serial.println(VERSION)).
However the compiler complains that VERSION is not declared. Ok I get that, every cpp file is an Island for the compiler so I have to declare VERSION as external. But it is a #define. mmh problem.
So I made another header file (2nd.h) for this 2nd.cpp file. And put in an
#include “main.h”
Problem solved? Well for the #define it is, however, now I have declared some global variables twice. I get that too, I defined an array and set its size to 1500.
char tempspace1500[1500];
I ended up in creating a third header file called ‘defines.h’, put the #define VERSION … in there and included defines.h in both main.cpp as the 2nd.cpp file. But this can not be the correct way can it?
Is there a good tutorial in howto do header files. A tutorial that is complete?
Thanks.
Header files should look like
#ifndef _MY_HEADER_FILE_NAME_H_
#define _MY_HEADER_FILE_NAME_H_
/* include all headers whose types you need */
/* define macros */
#define VERSION 0x010203
#define MANIPULATE(x) ((x) + 1)
/* declare global variables */
extern int myGlobalInt;
extern String myGlobalString;
extern char myBuf[1500];
/* declare global functions */
String my_global_function(int a, int b);
#endif /* _MY_HEADER_FILE_NAME_H_ */
And the corresponding cpp file should look like
#include "myHeaderName.h"
/* define global variables once */
int myGlobalInt = 123;
String myGlobalString = "ABC";
char myBuf[1500] = {0};
/* define global functions once */
String my_global_function(int a, int b) {
  return String(a + b);
General C/C++ tutorials already cover this, e.g.,
Thanks @maxgerhardt
So a header file contains declarations without settings. You then set (give a value) to these declarations in the cpp file.
That seems clear, although I will probably get back to this forum for the more advanced exceptions and ambiguities.
Now in your example you set
and then (again putting 1500 in the size) in the cpp file:
Would it be possible to set the array size=1500 in only one of these files? In this example I must keep track of both. Whenever I want/need to change the one I would have to change the other as well?
Thanks again.
That’s where a #define becomes handy:
.h
#define MAX_BUFSIZE 1500
extern char buf[MAX_BUFSIZE];
.cpp
With the following I have no idea what to do. I copied a class that essentially streams a print, println and/or printf statement to two different streams, in my case a Telnetstream and the Serial stream:
// Following class to stream a print(f) statement to two streams
// from Juraj (see telnetstream @ github)
class TeePrint: public Print {
    Print &out1;
    Print &out2;
    public:
      TeePrint(Print &_out1, Print &_out2) : out1(_out1), out2(_out2) {}
    virtual size_t write(uint8_t b) {
      out1.write(b);
      out2.write(b);
      return 1;
And in my main.cpp:
TeePrint tee(Serial, TelnetStream); // stream print(f) statements to both Serial as Telnet.
I can now use tee.println(“Hello World”); and that will be streamed to both Telnet as Serial.
I have several .cpp files in one project and some of them also will use this tee.print() class. But I get errors in compilation. I read you’d have to put the class in a .h file, e.g. functions.h.
I tried several solutions, but none work. Since I am not skilled (at all) in cpp I am aiming in the dark. Pls explain where I would put this class, how to define it in other cpp files and where do I put the actual declaration:
??? Again, pls be very specific as I do not know how to program CPP.
Thanks
Refactoring a class in .h and .cpp is covered in https://www.learncpp.com/cpp-tutorial/classes-and-header-files/.
