Hello
I’m new to platform io and I am having problems making the emacs lsp recognize the installed library header files. It builds and uploads alright, but the syntax highlighting is off.
I’ve searched for similar problems, but not found anything that solves exactly this problem.
In my case I am getting a red underlined #include "DHT.h" and the message DHT.h not found.
Dependency graph:
|-- DHT sensor library @ 1.4.4
| |-- Adafruit Unified Sensor @ 1.1.7
I am using ccls (as instructed in the platformio emacs documentation).
‘Arduino.h’ is found out of the box without any problems and gives no error (as long as I use ccls).
If I do pio run -t compiledb, that I saw suggested somewhere on the forum, and then open the file I get the messages
LSP :: ccls:7394 initialized successfully in folders: (/home/espen/code/esp32-env/dht11)
LSP :: Error from the Language Server: not indexed (Invalid Request) [9 times]
And no syntax highlighting at all. Anyone know how to figure this out?
platformio.ini
[env:featheresp32]
board = featheresp32
adafruit/DHT sensor library@^1.4.4
adafruit/Adafruit Unified Sensor@^1.1.7
EDIT: added platformio.ini, clarity
