Hi. I have a project destined for a 1MB ESP-01. I need more spiffs space than the default, so I’m taking a stab at setting up my own partition table. My understanding is that I should be able to create a project-level csv file and point to it in my platformio.ini file.
I’ve created: moreSPIFFS.csv as so:
# Espressif ESP8266 Partition Table
# Name, Type, SubType, Offset, Size
nvs, data, nvs, 0x9000, 0x6000
phy_init, data, phy, 0xf000, 0x1000
factory, app, factory, 0x10000, 0x70000
spiffs, data, spiffs, 0x80000, 0x70000
My platformio.ini file looks like so:
[env:esp01]
platform = espressif8266
board = esp01_1m
painlessmesh/painlessMesh@^1.4.5
makuna/NeoPixelBus@^2.6.0
board_build.partitions = moreSPIFFS.csv
build_type = debug
monitor_filters = esp8266_exception_decoder
check_tool = cppcheck
upload_port = COM9
However, I don’t see any indication while uploading (code or the File System Image) that it’s even trying to use my partition. Nor do I see the size of the filesystem change at runtime.
I’ve read the docs a few times now, but I feel like I’m missing something! How do I grow my spiffs size?
Thanks!
- Core
5.2.3 - Home
3.4.0
