I’m porting a small FW from STM32Cube to arduino(ststm32,gd32).
In STM32Cube I used HAL_UARTEx_ReceiveToIdle_DMA() configured with a ring buffer, together with idle detection HAL_UARTEx_RxEventCallback().
In addition I configured the preemption priorities in that way that UART-DMA had higher priority than my secondary interrupts like my hardware timers.
For sure, quite optimal because of UART-to-DMA, quick interrupt/callback once data is ready, while other possibly interrupts/callback got a lower priority.
Now in arduino, I switched to HardwareSerial::read().
Work so far, but it’s much slower! That slow, that the test-suite which send some hundreds of serial commands to my FW, outperforms my FW processing.
I already increased SERIAL_RX_BUFFER_SIZE but this only delays the problem till ringbuffer “tail” eat ringbuffer “head”
My questions are now:
1.) Could it be that framework-arduinoststm32 is that much “slower” than my previous implementation via HAL API?
2.) Is it possible to get some kind of HAL_UARTEx_RxEventCallback() with HardwareSerial instead of polling it via HardwareSerial::read()
3.) Do I have the possibility in arduino to priorize the usart and timer interrupts?
4.) Any other ideas?
There’s also no shame in tossing the Arduino framework away if it doesn’t fit your applications requirements in terms of performance – performing a surgery on the Arduino core to fit in DMA utilization may be overkill and a pain to maintain.
Well the PCB is only a bunch of buttons, LEDs and Mosfets and no moon-challenger
After your explanation that serialEventRun() get processed at the end of arduino’s loop() (which I wasn’t aware of before), it got clear that my timer callbacks delayed reaching that point.
In addition it turned out that printf() @ STM32 has wasted another huge amount of CPU cycles, which I simply switched of with a -DDEBUG_UART=NP build flag.
Interestingly the GD didn’t had that problems, but I guessed a.) because of it has a floating point unit and b.) I couldn’t find any similar of the DEBUG_UART stuff within the framework-arduinogd32 sources.
