GTest passes but shows SKIPPED
This is my first time setting up testing.
I created a new project, imported GTest and followed a tutorial on how to do it.
When I run the tests i see that it passes but it writes “SKIPPED”…
Output when i run “pio test -vv”:
PS C:\Users\razib\Desktop\Projects\Old Computer Projects\Laser Tag\Repository\laser-tag\laser-tag-v2> pio test -v
Collected 1 tests (test_native)
Processing test_native in native environment
Building...
Testing...
[==========] Running 1 test from 1 test suite.
[----------] Global test environment set-up.
[----------] 1 test from example
[ RUN      ] example.test_if_returns_sum_of_two_given_ints
[       OK ] example.test_if_returns_sum_of_two_given_ints (0 ms)
[----------] 1 test from example (0 ms total)
[----------] Global test environment tear-down
[==========] 1 test from 1 test suite ran. (0 ms total)
[  PASSED  ] 1 test.
---------------------------------------------------------- native:test_native [PASSED] Took 14.58 seconds ----------------------------------------------------------
============================================================================= SUMMARY =============================================================================
Environment    Test         Status    Duration
d1             test_native  SKIPPED
native         test_native  SKIPPED   00:00:14.577
============================================================ 0 test cases: 0 succeeded in 00:00:14.577 ============================================================
This is my platformio.ini:
[env:d1]
platform = espressif8266
board = d1
test_ignore = test_native
build_flags = -DEMBEDDED_BUILD
lib_deps = google/googletest@^1.12.1
[env:native]
platform = native
lib_compat_mode = off
test_ignore = test_embedded
    -std=c++17
In project/test/test_native i have two files.
native_test.cpp:
#include <gtest/gtest.h>
int main(int argc, char** argv){
    testing::InitGoogleTest(&argc, argv);
    return RUN_ALL_TESTS();
test_example.cpp:
TEST(example, test_if_returns_sum_of_two_given_ints){
    ASSERT_EQ(3, 3);
  • Windows 11
@valeros , please take a look.
Hi @razi.berg, you’re using a non-default testing framework, but I don’t see the test_framework option in your platformio.ini. You need to specify test_framework = googletest so that PlatformIO will be able to properly pick up test cases from your test files. More info here.
