I have ‘kludged’ together the Arduino as ISP code and AVR High-voltage Serial Fuse Reprogrammer for ISP HV Programmer.
I am using a Pro Mini (5v 328P) board so I can talk to it with my 6 pin serial card (the same one I use for my (HV) UPDI programmer.
I have successfully built the hardware on breadboard and can cycle between ISP mode and HV mode with a push button. I am using extra pins on Pro Mini to control HV source and source of reset signal.
I need to open a terminal when in HV mode so I may enter the required programming commands - whether to remove the target reset pin or just reset the fuse values to default.
I need to close the terminal before attempting ISP programming as the same serial port is used for the ‘Arduino as ISP’ programmer.
Both work but there is an annoying boundary condition that’s bugging me.
My unit starts up in ISP mode. If I use it immediately as ‘Arduino as ISP’ it’s fine.
If I switch the unit into HV mode and back into ISP mode, the ‘Arduino as ISP’ is still fine.
But if I temporarily start the PlatformIO terminal on the same port and then shut this down (even if I never switch the unit into HV mode), the first time I try to use it as ‘Arduino as ISP’, I get issues with AVRDUDE synchronising. It works subsequent times.
I have included the verbose AVRDUDE output from the initial attempt.
Sure I could just live with the initial glitch after closing the terminal - or have the unit start up in one mode or the other but I’d like to correct the glitch.
Do you have any ideas what I need to do to prevent this first time glitch?
I was wondering if there is some background serial message I could transmit to get the port into the right state so the initial AVRDUDE interaction does not glitch.I have code to block my ‘Arduino as ISP’ to ‘HV mode’ command push button while the unit is mid ISP session or HV fuse blowing session. I could use this to gate any background serial message I might send to the serial port just while waiting for an AVRDUDE ISP program command to start.
The AVRDUDE command line options don’t look promising.
My problem is confounded by my lack of knowledge - I am no skilled programmer.
If you can think of a way of making my serial port ‘go back to default’ after the terminal has been closed, I’d be very keen to try it.
Here’s the AVRDUDE output from the code trying to use ‘Arduino as ISP’ showing it falling over at the synch stage
AVAILABLE: custom
CURRENT: upload_protocol = custom
Uploading .pio\build\attiny13a\firmware.hex
avrdude: Version 6.3, compiled on Sep 12 2016 at 17:24:16
System wide configuration file is "C:\Users\Peter\.platformio\packages/tool-avrdude/avrdude.conf"
Using Port : COM16
Using Programmer : stk500v1
Overriding Baud Rate : 19200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x15
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x15
AVR Part : ATtiny13a
Chip Erase delay : 4000 us
PAGEL : P00
BS2 : P00
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 5 4 0 no 64 4 0 4000 4000 0xff 0xff
flash 65 6 32 0 yes 1024 32 32 4500 4500 0xff 0xff
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 2 0 0 0 0 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
Programmer Type : STK500
Description : Atmel STK500 Version 1.x firmware
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x14
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x02
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x10
Hardware Version: 4728160
Firmware Version: 0.4598883
Topcard : STK502
Vtarget : 1.8 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: stk500_initialize(): (b) protocol error, expect=0x10, resp=0x01
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x10
avrdude done. Thank you.
*** [upload] Error 1
============================================================================================================= [FAILED] Took 4.04 seconds =============================================================================================================
The platformio.ini on the code trying to use the Arduino as ISP
[env:attiny13a]
board = attiny13a
; device is Arduino as ISP
upload_port = COM16
upload_speed = 19200
upload_flags =
-C
; use "tool-avrdude-megaavr" for the atmelmegaavr platform
${platformio.packages_dir}/tool-avrdude/avrdude.conf
-p
$BOARD_MCU
-P
$UPLOAD_PORT
-b
$UPLOAD_SPEED
-c
stk500v1
-v
