In summary; my GitLab.com SaaS runner started working and I don’t know why!
I added the env command to the job, re-ran the CI Pipeline again and got different behaviour than previously. My pio_probe_hosts.py script reports “No attempt …” for all hosts, which means that is_proxy_set() is throwing an exception. Previously, it successfully made a socket connection to the first host.
Moreover, the subsequent pio run commands don’t report “No internet connection”, but now succeed in installing the required packages and then the overall build succeeds.
One other mystery is that this coverage build was also previously failing because LDF did not correctly detect all of the required source modules (only on the SaaS runner), so the final link failed. This time it succeeded! I suspected this might be connected to the Internet connection problem, and perhaps that is the case.
$ env
CI_PROJECT_NAMESPACE=xxxxxx-xxxxxxx
GITLAB_USER_ID=10495412
CI_RUNNER_VERSION=16.6.0~beta.105.gd2263193
FF_SKIP_NOOP_BUILD_STAGES=true
CI_SERVER_NAME=GitLab
CI_RUNNER_DESCRIPTION=3-blue.saas-linux-small-amd64.runners-manager.gitlab.com/default
GITLAB_USER_EMAIL=xxxxxx@xxxxxx.co.uk
CI_SERVER_REVISION=5d2ce169a5b
FF_USE_WINDOWS_LEGACY_PROCESS_STRATEGY=true
CI_RUNNER_EXECUTABLE_ARCH=linux/amd64
CI_PIPELINE_NAME=
CI_REGISTRY_USER=gitlab-ci-token
CI_API_V4_URL=https://gitlab.com/api/v4
CI_REGISTRY_PASSWORD=[MASKED]
CI_RUNNER_SHORT_TOKEN=zxwgkjAP
CI_JOB_NAME=dmod_coverage_ut
CI_OPEN_MERGE_REQUESTS=xxxxxx-xxxxxxx/ws1dry1!1064
HOSTNAME=runner-zxwgkjap-project-54156664-concurrent-0
GITLAB_USER_LOGIN=xxxxxxx
CI_PROJECT_NAME=ws1dry1
CI_PIPELINE_SOURCE=push
FF_RETRIEVE_POD_WARNING_EVENTS=false
CI_JOB_STATUS=running
CI_PIPELINE_ID=1168978552
FF_DISABLE_POWERSHELL_STDIN=false
CI_COMMIT_REF_SLUG=1617-prepare-ci-pipeline-for-update-to-gitlab-16-7
CI_SERVER=yes
FF_SET_PERMISSIONS_BEFORE_CLEANUP=true
CI_COMMIT_SHORT_SHA=d41e7cfd
CI_JOB_NAME_SLUG=dmod-coverage-ut
RUNNER_TEMP_PROJECT_DIR=/builds/xxxxxx-xxxxxxx/ws1dry1.tmp
FF_CMD_DISABLE_DELAYED_ERROR_LEVEL_EXPANSION=false
CI_DEPENDENCY_PROXY_GROUP_IMAGE_PREFIX=gitlab.com:443/xxxxxx-xxxxxxx/dependency_proxy/containers
FF_USE_GIT_BUNDLE_URIS=true
PWD=/builds/xxxxxx-xxxxxxx/ws1dry1/dmod
CI_RUNNER_TAGS=["gce", "east-c", "linux", "ruby", "mysql", "postgres", "mongo", "git-annex", "shared", "docker", "saas-linux-small-amd64"]
CI_PROJECT_PATH=xxxxxx-xxxxxxx/ws1dry1
FF_USE_NEW_BASH_EVAL_STRATEGY=false
CI_SERVER_TLS_CA_FILE=/builds/xxxxxx-xxxxxxx/ws1dry1.tmp/CI_SERVER_TLS_CA_FILE
CI_DEPENDENCY_PROXY_DIRECT_GROUP_IMAGE_PREFIX=gitlab.com:443/xxxxxx-xxxxxxx/dependency_proxy/containers
CI_COMMIT_REF_PROTECTED=false
FF_USE_POWERSHELL_PATH_RESOLVER=false
CI_API_GRAPHQL_URL=https://gitlab.com/api/graphql
CI_SERVER_VERSION_MINOR=9
CI_COMMIT_SHA=d41e7cfdd05c3732c783849b90b8755eaf485d99
HOME=/root
FF_NETWORK_PER_BUILD=false
CI_DEPENDENCY_PROXY_PASSWORD=[MASKED]
CI_JOB_TIMEOUT=7200
CI_PROJECT_VISIBILITY=private
CI_CONCURRENT_PROJECT_ID=0
FF_SCRIPT_SECTIONS=false
CI_COMMIT_MESSAGE=gitlab-ci.yml: Add env dump and pio probe hosts to DMOD coverage job.
DOCKER_TLS_CERTDIR=
CI_SERVER_SHELL_SSH_PORT=22
monDockerImage=wsone_buildenv_phycore_imx8_a53_m4f:v6.7
CI_JOB_JWT_V1=[MASKED]
CI_JOB_JWT_V2=[MASKED]
FF_USE_DIRECT_DOWNLOAD=true
CI_PAGES_DOMAIN=gitlab.io
FF_PRINT_POD_EVENTS=false
CI_SERVER_VERSION=16.9.0-pre
FF_USE_POD_ACTIVE_DEADLINE_SECONDS=true
CI_REGISTRY=registry.gitlab.com
CI_SERVER_PORT=443
CI_PROJECT_NAMESPACE_ID=79864741
FF_USE_IMPROVED_URL_MASKING=false
CI_PAGES_URL=https://ws1dry1-xxxxxx-xxxxxxx-4fa0ead4973f0e8f81abf62cbac45755537485df.gitlab.io
CI_PIPELINE_IID=14
CI_REPOSITORY_URL=https://gitlab-ci-token:[MASKED]@gitlab.com/xxxxxx-xxxxxxx/ws1dry1.git
CI_SERVER_URL=https://gitlab.com
FF_ENABLE_BASH_EXIT_CODE_CHECK=false
GITLAB_FEATURES=audit_events,blocked_issues,board_iteration_lists,code_owners,code_review_analytics,full_codequality_report,group_activity_analytics,group_bulk_edit,issuable_default_templates,issue_weights,iterations,ldap_group_sync,merge_request_approvers,milestone_charts,multiple_issue_assignees,multiple_ldap_servers,multiple_merge_request_assignees,multiple_merge_request_reviewers,project_merge_request_analytics,protected_refs_for_users,push_rules,resource_access_token,seat_link,usage_quotas,visual_review_app,wip_limits,zoekt_code_search,blocked_work_items,description_diffs,send_emails_from_admin_area,repository_size_limit,maintenance_mode,scoped_issue_board,contribution_analytics,group_webhooks,member_lock,elastic_search,repository_mirrors,adjourned_deletion_for_projects_and_groups,admin_audit_log,auditor_user,blocking_merge_requests,board_assignee_lists,board_milestone_lists,ci_secrets_management,ci_pipeline_cancellation_restrictions,cluster_agents_ci_impersonation,cluster_agents_user_impersonation,cluster_deployments,code_owner_approval_required,code_suggestions,commit_committer_check,commit_committer_name_check,compliance_framework,custom_compliance_frameworks,custom_file_templates,custom_project_templates,cycle_analytics_for_groups,cycle_analytics_for_projects,db_load_balancing,default_branch_protection_restriction_in_groups,default_project_deletion_protection,delete_unconfirmed_users,dependency_proxy_for_packages,disable_name_update_for_users,disable_personal_access_tokens,domain_verification,epics,extended_audit_events,external_authorization_service_api_management,feature_flags_code_references,file_locks,geo,generic_alert_fingerprinting,git_two_factor_enforcement,group_allowed_email_domains,group_coverage_reports,group_forking_protection,group_milestone_project_releases,group_project_templates,group_repository_analytics,group_saml,group_scoped_ci_variables,ide_schema_config,incident_metric_upload,instance_level_scim,jira_issues_integration,ldap_group_sync_filter,merge_request_performance_metrics,admin_merge_request_approvers_rules,merge_trains,metrics_reports,metrics_observability,logs_observability,multiple_alert_http_integrations,multiple_approval_rules,multiple_group_issue_boards,object_storage,microsoft_group_sync,operations_dashboard,package_forwarding,pages_size_limit,pages_multiple_versions,productivity_analytics,project_aliases,protected_environments,reject_non_dco_commits,reject_unsigned_commits,remote_development,saml_group_sync,service_accounts,scoped_labels,smartcard_auth,ssh_certificates,swimlanes,target_branch_rules,type_of_work_analytics,minimal_access_role,unprotection_restrictions,ci_project_subscriptions,incident_timeline_view,oncall_schedules,escalation_policies,zentao_issues_integration,coverage_check_approval_rule,issuable_resource_links,group_protected_branches,group_level_merge_checks_setting,oidc_client_groups_claim,disable_deleting_account_for_users,disable_private_profiles,group_ip_restriction,issues_analytics,password_complexity,group_wikis,email_additional_text,custom_file_templates_for_namespace,incident_sla,export_user_permissions,cross_project_pipelines,feature_flags_related_issues,merge_pipelines,ci_cd_projects,github_integration,ai_chat,ai_config_chat,ai_features,ai_git_command,ai_tanuki_bot,ai_analyze_ci_job_failure,ai_agents,api_discovery,api_fuzzing,auto_rollback,breach_and_attack_simulation,fill_in_merge_request_template,cluster_image_scanning,external_status_checks,combined_project_analytics_dashboards,compliance_pipeline_configuration,container_scanning,credentials_inventory,custom_roles,dast,dependency_scanning,dora4_analytics,epic_colors,enterprise_templates,environment_alerts,evaluate_group_level_compliance_pipeline,explain_code,external_audit_events,experimental_features,generate_description,generate_commit_message,generate_test_file,ai_generate_cube_query,git_abuse_rate_limit,group_ci_cd_analytics,group_level_compliance_dashboard,group_level_analytics_dashboard,incident_management,inline_codequality,insights,issuable_health_status,issues_completed_analytics,jira_vulnerabilities_integration,jira_issue_association_enforcement,kubernetes_cluster_vulnerabilities,license_scanning,okrs,personal_access_token_expiration_policy,pre_receive_secret_detection,product_analytics,project_quality_summary,project_level_analytics_dashboard,prometheus_alerts,quality_management,related_epics,release_evidence_test_artifacts,report_approver_rules,required_ci_templates,requirements,runner_maintenance_note,runner_performance_insights,runner_upgrade_management,runner_upgrade_management_for_namespace,sast,sast_iac,sast_custom_rulesets,sast_fp_reduction,secret_detection,security_configuration_in_ui,security_dashboard,security_on_demand_scans,security_orchestration_policies,security_training,ssh_key_expiration_policy,summarize_mr_changes,summarize_my_mr_code_review,summarize_notes,summarize_submitted_review,stale_runner_cleanup_for_namespace,status_page,suggested_reviewers,subepics,tracing,unique_project_download_limit,vulnerability_auto_fix,vulnerability_finding_signatures,coverage_fuzzing,devops_adoption,group_level_devops_adoption,instance_level_devops_adoption
CI_COMMIT_DESCRIPTION=
FF_USE_ADVANCED_POD_SPEC_CONFIGURATION=false
CI_TEMPLATE_REGISTRY_HOST=registry.gitlab.com
CI_JOB_STAGE=unit_test
CI_PIPELINE_URL=https://gitlab.com/xxxxxx-xxxxxxx/ws1dry1/-/pipelines/1168978552
CI_DEFAULT_BRANCH=master
GITLAB_ENV=/builds/xxxxxx-xxxxxxx/ws1dry1.tmp/gitlab_runner_env
CI_SERVER_VERSION_PATCH=0
CI_COMMIT_TITLE=gitlab-ci.yml: Add env dump and pio probe hosts to DMOD coverage job.
CI_PROJECT_ROOT_NAMESPACE=xxxxxx-xxxxxxx
FF_ENABLE_JOB_CLEANUP=false
FF_RESOLVE_FULL_TLS_CHAIN=false
GITLAB_USER_NAME=Tim Jones
CI_PROJECT_DIR=/builds/xxxxxx-xxxxxxx/ws1dry1
SHLVL=1
CI_RUNNER_ID=12270835
CI_PIPELINE_CREATED_AT=2024-02-08T09:03:35Z
CI_COMMIT_TIMESTAMP=2024-02-08T09:03:31+00:00
CI_DISPOSABLE_ENVIRONMENT=true
CI_SERVER_SHELL_SSH_HOST=gitlab.com
CI_JOB_JWT=[MASKED]
CI_REGISTRY_IMAGE=registry.gitlab.com/xxxxxx-xxxxxxx/ws1dry1
CI_SERVER_PROTOCOL=https
dmodDockerImage=wsone_buildenv_dmod_platformio:v4.9
CI_COMMIT_AUTHOR=Tim Jones <xxxxxx@xxxxxx.co.uk>
FF_POSIXLY_CORRECT_ESCAPES=false
CI_COMMIT_REF_NAME=1617-prepare-ci-pipeline-for-update-to-gitlab-16-7
CI_SERVER_HOST=gitlab.com
CI_JOB_URL=https://gitlab.com/xxxxxx-xxxxxxx/ws1dry1/-/jobs/6124120660
CI_JOB_TOKEN=[MASKED]
CI_JOB_STARTED_AT=2024-02-08T09:03:41Z
CI_CONCURRENT_ID=615
CI_PROJECT_DESCRIPTION=
CI_COMMIT_BRANCH=1617-prepare-ci-pipeline-for-update-to-gitlab-16-7
CI_PROJECT_CLASSIFICATION_LABEL=
FF_USE_LEGACY_KUBERNETES_EXECUTION_STRATEGY=false
CI_RUNNER_REVISION=d2263193
FF_KUBERNETES_HONOR_ENTRYPOINT=false
FF_USE_NEW_SHELL_ESCAPE=false
CI_DEPENDENCY_PROXY_USER=gitlab-ci-token
FF_USE_DYNAMIC_TRACE_FORCE_SEND_INTERVAL=false
FF_DISABLE_UMASK_FOR_DOCKER_EXECUTOR=false
CI_PROJECT_PATH_SLUG=xxxxxx-xxxxxxx-ws1dry1
CI_NODE_TOTAL=1
CI_BUILDS_DIR=/builds
CI_JOB_ID=6124120660
CI_PROJECT_REPOSITORY_LANGUAGES=c,c++,python,qml,motorola 68k assembly
PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
FF_SECRET_RESOLVING_FAILS_IF_MISSING=true
CI_PROJECT_ID=54156664
CI=true
GITLAB_CI=true
CI_JOB_IMAGE=registry.gitlab.com/xxxxxx-xxxxxxx/ws1dry1/wsone_buildenv_dmod_platformio:v4.9
CI_COMMIT_BEFORE_SHA=d12f366d04eae751408509a243a8da90eca4d9b7
CI_PROJECT_TITLE=Ws1Dry1
dockerRegistry=registry.gitlab.com/xxxxxx-xxxxxxx/ws1dry1
CI_SERVER_VERSION_MAJOR=16
CI_CONFIG_PATH=.gitlab-ci.yml
FF_USE_FASTZIP=false
CI_DEPENDENCY_PROXY_SERVER=gitlab.com:443
DOCKER_DRIVER=overlay2
CI_PROJECT_URL=https://gitlab.com/xxxxxx-xxxxxxx/ws1dry1
OLDPWD=/builds/xxxxxx-xxxxxxx/ws1dry1
_=/usr/bin/env
$ python3 scripts/test/pio_probe_hosts.py
No attempt for 185.199.110.153 failed
No attempt for 88.198.170.159 failed
No attempt for github.com failed
No attempt for registry.platformio.org failed
No attempt for registry.nm1.platformio.org failed
$ pio run -t clean -e native
Processing native (platform: native)
Tool Manager: Installing platformio/tool-scons @ ~4.40400.0
Downloading 0% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100%
Unpacking
Tool Manager: tool-scons@4.40400.0 has been installed!
Build environment is clean
Done cleaning
========================= [SUCCESS] Took 2.60 seconds =========================
Environment Status Duration
native SUCCESS 00:00:02.604
========================= 1 succeeded in 00:00:02.604 =========================
$ SCRIPT=scripts/test/native_unit_test_pio.sh
$ $SCRIPT
PlatformIO Core, version 6.1.4
Done cleaning
========================= [SUCCESS] Took 0.24 seconds =========================
native SUCCESS 00:00:00.238
========================= 1 succeeded in 00:00:00.238 =========================
Collected 3 tests (native/test_gtest, target/test_dap, target/test_dha)
Processing native/test_gtest in native environment
Building...
Library Manager: Installing throwtheswitch/Unity @ ^2.5.2
Unpacking
Library Manager: Unity@2.5.2 has been installed!
LDF Modes: Finder ~ chain+, Compatibility ~ strict
Library Manager: Installing googletest
Unpacking
Library Manager: googletest@1.12.1 has been installed!
Found 13 compatible libraries
