I have Platformio core 5.0.2 installed.
I tried to reference github libraries in platformio.ini in different ways.
I always get the following UserSideException during compiling.
Library Manager: Installing git+https://github.com/adlerweb/MCP23S17
UserSideException: Please install Git client from https://git-scm.com/downloads:
I Installed git version 2.29.2. I tried the x32 and/or x64.
Nothing helps.
Does anybody have an idea bout this?
Thanks in advance.
Andre
I see that you have installed the git client. Is it on your systemâs PATH? If not, you will need to add it. After adding it, any existing open applications will not see it, they will need to be restarted. VSCode, for example, will need to be restarted after adding git to the PATH. When an application loads, it copies the environment at that time. Changing the environment outside of the application will not affect it.
HTH
Cheers,
Norm.
Hi Norman
Thanks for the hint, I checked the Windows environment variable PATH.
âC:\Program Files\Git\cmdâ is listed there.
Git files exist in that path too. It looks all ok to me.
That doesnât seem to be the cause.
Any other ideas?
Additional InformationâŠ
I get a bunch of subsequent errors after that error message:
File âC:\users\lappi.platformio\penv\lib\site-packages\platformio\builder\main.pyâ, line 170:
env.SConscript(â$BUILD_SCRIPTâ)
File âC:\Users\Lappi.platformio\packages\tool-scons\scons-local-4.0.1\SCons\Script\SConscript.pyâ, line 598:
File âC:\Users\Lappi.platformio\packages\tool-scons\scons-local-4.0.1\SCons\Script\SConscript.pyâ, line 287:
exec(compile(scriptdata, scriptname, âexecâ), call_stack[-1].globals)
etcâŠ
I checked the path for python too.
"C:\Users\Lappi\AppData\Local\Programs\Python\Python39\Scripts" and
C:\Users\Lappi\AppData\Local\Programs\Python\Python39.
Those are in the Accounts PATH, not in the System PATH.
Python exists in those Paths.
Can it be there is some Trouble with python?
Version 3.9.0 is installed.
Regards
Andre
Open a terminal (Windows + R -> cmd.exe) and execute git --version. What does it return?
It gives
git version 2.29.2.windows.2
Try to log out and log back into the Windows account, or better, reboot the computer â seems to me like the environment changes have just not been propagated to VSCode properly.
I rebooted it before already. I just rebooted again. Still the same.
Open a PIO terminal and again execute git --version. What does it return?
Git is not beeing recognized there.
PS D:\Daten\Dropbox\uC\VSC_Workspace\Uhr_55> git --version
git : Die Benennung "git" wurde nicht als Name eines Cmdlet, einer Funktion, einer Skriptdatei oder eines ausfĂŒhrbaren Programms
erkannt. ĂberprĂŒfen Sie die Schreibweise des Namens, oder ob der Pfad korrekt ist (sofern enthalten), und wiederholen Sie den Vorgang.
In Zeile:1 Zeichen:1
+ git --version
+ CategoryInfo : ObjectNotFound: (git:String) [], CommandNotFoundException
+ FullyQualifiedErrorId : CommandNotFoundException
Eh⊠interesting⊠Never seen that one before. Try a few things:
- In VSCode, go to
File -> Preferences -> Settings and search for âgit pathâ. There will be a âEdit in settings.jsonâ button which takes you to the configuration file. Put the direct path to your git.exe executable in there (and remember to escape a backslash with a backslash, as in C:\\Program Files\\git\\cmd\\git.exe, for example)
- restart VSCode and see if
git is now being recognized in the PIO terminal
- if not, uninstall the PlatformIO VSCode extension in the extension side, reinstall it and restart VSCode â does it work now?
The path modification didnât help.
The reinstallation of platformio helped. It recognizes the command after that with âgit --versionâ and returns âgit version 2.29.2.windows.2â.
I reset the path to ââ again and it still finds git. So the path wasnât the cause obviously.
I finds the libraries and installs them now:
Library Manager: Installing git+https://github.com/adlerweb/MCP23S17.git
Cloning into âC:\Users\Lappi.platformio.cache\tmp\pkg-installing-lpcmkziwââŠ
Library Manager: MCP23S17 @ 2018.9.24+sha.842f9d7 has been installed!
Library Manager: Installing git+https://github.com/wonho-maker/Adafruit_SH1106.git
Cloning into âC:\Users\Lappi.platformio.cache\tmp\pkg-installing-l994j5rsââŠ
Library Manager: Adafruit_SH1106 @ 0.0.0+20201108154149.sha.f4e427f has been installed!
Gosh that was a weird one.
Thanks a lot.
By the way. I have a second PC with the same behaviour.
It seems systemic therefore or i did the same on both machines to have the same effect.
I will try that trick there too.
My guess is that PlatformIO checks for the git executable path only at installation time once; this would explain why a re-install helps to suddenly find git again. Maybe @ivankravets can cross-check this.
OK. Sounds plausible.
Thanks a lot for your help.
Regards
Andre
Python 3.9? I think thereâs a problem with that newest version. Unless if course, VSCode is using python supplied with PlatformIO.
Cheers,
Norm.
No, it does not. We just call git and it should be visible in the system PATH. There is an issue with Windows, sometimes you need to restart the application or OS to take a new path into effect.
Seems to be at least buggy then because he said re booted already :S
I just rebooted pc after installing git, and I now it works.
I can download libraries from git.
Hi, iâm having the same problem.
git : El tĂ©rmino âgitâ no se reconoce como nombre de un cmdlet, funciĂłn, archivo de script o programa ejecutable. Compruebe si escribiĂł correctamente el nombre o,
si incluyó una ruta de acceso, compruebe que dicha ruta es correcta e inténtelo de nuevo.
En lĂnea: 1 CarĂĄcter: 1
Uninstalling pio extension will delete projects folder?
Should I follow some procedure to keep projects in the folder?
Br
Juan
find this in settings.json
"idf.gitPathWin": "C:\\\\Users\\\\Juan\\\\.espressif\\\\tools\\\\idf-git\\\\2.39.2\\\\cmd\\\\git.exe",
"cmake.saveBeforeBuild": false,
"idf.saveBeforeBuild": false,
"task.saveBeforeRun": "never",
"idf.pythonInstallPath": "tools\\\\idf-python\\\\3.11.2\\\\python.exe",
"idf.hasWalkthroughBeenShown": true,
"terminal.integrated.scrollback": 3000,
"workbench.settings.applyToAllProfiles": \[
"explorer.confirmDelete": false,
"git.path": ""
should i copy first line (âidf.gitPathWinâ) at âgit.pathâ field?
