No, because it’s trying to add an Adafruit GFX library, even though it isn’t called for. I just went through and deleted all the pio folders, but it’s getting hung up on ‘Arduino’ again.
CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/wemos_d1_mini32.html
PLATFORM: Espressif 32 (2.0.0) > WeMos D1 MINI ESP32
Library Manager: Installing Arduino
Library Manager: Warning! More than one package has been found by Arduino requirements:
- mbed-aluqard/arduino @ 0.0.0+sha.3b83fc30bbdf
- mbed-eduardog26/Arduino @ 0.0.0-alpha+sha.abbc3308dfa1
- mbed-thechrisyd/Arduino @ 0.0.0+sha.272d0276d474
- mbed-gastonfeng/arduino @ 0.0.0-alpha+sha.b000674ff8b3
- mbed-rahulsitaram/Arduino @ 0.0.0+sha.d0b32a4209f0
- mbed-team2/Arduino @ 0.0.0+sha.d96590319bcf
Library Manager: Please specify detailed REQUIREMENTS using package owner and version (showed above) to avoid name conflicts
Library Manager: arduino @ 0.0.0+sha.3b83fc30bbdf has been installed!
Library Manager: Installing BLEDevice
Warning! Could not find the package with 'BLEDevice' requirements for your system 'windows_amd64'
Library Manager: Installing BLEScan
Warning! Could not find the package with 'BLEScan' requirements for your system 'windows_amd64'
Library Manager: Installing adafruit/Adafruit_GFX
KeyError: 'versions':
File "C:\Users\joema\.platformio\penv\lib\site-packages\platformio\builder\main.py", line 169:
File "C:\Users\joema\.platformio\packages\tool-scons\scons-local-4.0.1\SCons\Script\SConscript.py", line 598:
File "C:\Users\joema\.platformio\packages\tool-scons\scons-local-4.0.1\SCons\Script\SConscript.py", line 287:
File "C:\Users\joema\.platformio\platforms\espressif32\builder\main.py", line 223:
File "C:\Users\joema\.platformio\packages\tool-scons\scons-local-4.0.1\SCons\Environment.py", line 219:
File "C:\Users\joema\.platformio\penv\lib\site-packages\platformio\builder\tools\platformio.py", line 62:
env.ProcessProjectDeps()
File "C:\Users\joema\.platformio\penv\lib\site-packages\platformio\builder\tools\platformio.py", line 140:
project_lib_builder = env.ConfigureProjectLibBuilder()
File "C:\Users\joema\.platformio\penv\lib\site-packages\platformio\builder\tools\piolib.py", line 1062:
project.install_dependencies()
File "C:\Users\joema\.platformio\penv\lib\site-packages\platformio\builder\tools\piolib.py", line 898:
lm.install(spec)
File "c:\users\joema\.platformio\penv\lib\site-packages\platformio\package\manager\_install.py", line 49:
spec, silent=silent, skip_dependencies=skip_dependencies, force=force
File "c:\users\joema\.platformio\penv\lib\site-packages\platformio\package\manager\library.py", line 86:
force=force,
File "c:\users\joema\.platformio\penv\lib\site-packages\platformio\package\manager\_install.py", line 99:
pkg = self.install_from_registry(spec, search_filters, silent=silent)
File "c:\users\joema\.platformio\penv\lib\site-packages\platformio\package\manager\_registry.py", line 86:
version = self.pick_best_registry_version(package["versions"], spec)
==================================================================================== [FAILED] Took
