GFX Library with platformio on ESP32-1732S019
I really like your library. I got sample code with my ESP32-1732S019 and that works in Arduino IDE. However I am used to platform.io more.
For some reason the same code does not work in platform.io but works in Arduino IDE. I seem to be missing some dependency in platform.io that Arduino IDE has in the background.
Could you please provide a hint what the issue could be?
Config results in Arduino@2.0.17
platform = espressif32@6.7.0
board = esp32-s3-devkitm-1
lib_deps = moononournation/GFX Library for Arduino@^1.5.2
Error is
Compiling .pio\build\esp32-s3-devkitm-1\lib6b9\GFX Library for Arduino\databus\Arduino_ESP32SPI.cpp.o
.pio/libdeps/esp32-s3-devkitm-1/GFX Library for Arduino/src/databus/Arduino_ESP32QSPI.cpp: In member function 'virtual bool Arduino_ESP32QSPI::begin(int32_t, int8_t)':
.pio/libdeps/esp32-s3-devkitm-1/GFX Library for Arduino/src/databus/Arduino_ESP32QSPI.cpp:59:21: error: 'ESP_INTR_CPU_AFFINITY_AUTO' was not declared in this scope
       .isr_cpu_id = ESP_INTR_CPU_AFFINITY_AUTO,
.pio/libdeps/esp32-s3-devkitm-1/GFX Library for Arduino/src/databus/Arduino_ESP32QSPI.cpp:59:21: note: suggested alternative: 'ESP_ETH_PHY_ADDR_AUTO'
.pio/libdeps/esp32-s3-devkitm-1/GFX Library for Arduino/src/databus/Arduino_ESP32QSPI.cpp:60:22: error: 'spi_bus_config_t' has no non-static data member named 'isr_cpu_id'
       .intr_flags = 0};
.pio/libdeps/esp32-s3-devkitm-1/GFX Library for Arduino/src/databus/Arduino_ESP32QSPI.cpp:73:23: error: 'SPI_CLK_SRC_DEFAULT' was not declared in this scope
       .clock_source = SPI_CLK_SRC_DEFAULT,
.pio/libdeps/esp32-s3-devkitm-1/GFX Library for Arduino/src/databus/Arduino_ESP32QSPI.cpp:73:23: note: suggested alternative: 'LCD_CLK_SRC_XTAL'
                       LCD_CLK_SRC_XTAL
.pio/libdeps/esp32-s3-devkitm-1/GFX Library for Arduino/src/databus/Arduino_ESP32QSPI.cpp:83:25: error: 'spi_device_interface_config_t' has no non-static data member named 'clock_source'
       .post_cb = nullptr};
.pio/libdeps/esp32-s3-devkitm-1/GFX Library for Arduino/src/databus/Arduino_ESP32RGBPanel.cpp: In member function 'uint16_t* Arduino_ESP32RGBPanel::getFrameBuffer(int16_t, int16_t)':
.pio/libdeps/esp32-s3-devkitm-1/GFX Library for Arduino/src/databus/Arduino_ESP32RGBPanel.cpp:93:3: error: 'esp_lcd_rgb_panel_config_t::<unnamed struct>' has no non-static data member named 'refresh_on_demand'
*** [.pio\build\esp32-s3-devkitm-1\lib6b9\GFX Library for Arduino\databus\Arduino_ESP32QSPI.cpp.o] Error 1
*** [.pio\build\esp32-s3-devkitm-1\lib6b9\GFX Library for Arduino\databus\Arduino_ESP32RGBPanel.cpp.o] Error 1
The library you are referring to requires Espressif32 Arduino 3.x
Unfortunately PlatformIO officially only offers Espressif32 Arduino 2.x.
Use the community fork pioarduino to get Espressif32 Arduino 3.x:
platform = https://github.com/pioarduino/platform-espressif32/releases/download/53.03.11/platform-espressif32.zip
With this platform, the Hello World example compiles without any issues.
Thank you, it solved my issue!
