I tried changing from …
upload_port = COM[3]
upload_speed = 921600
… to …
upload_protocol = espota
upload_port = 192.168.1.199
… and I’m still getting “Please specify upload_port” even when only building. How do I fix this?
… to …
Full platformio.ini and output?
Thanks. Enjoy …
[env:esp12e]
platform = espressif8266
board = esp12e
upload_port = 192.168.1.199 // ???
; upload_port = COM[3]
; upload_speed = 921600
monitor_port = COM[3]
; monitor_speed = 74880
; monitor_speed = 115200
monitor_speed = 921600
monitor_filters = log2file, esp8266_exception_decoder, default, time
; monitor_filters = esp8266_exception_decoder, default
monitor_rts = 0
monitor_dtr = 0
board_build.f_cpu = 160000000L
build_type = release
-Wunused-variable
-Wdeprecated-declarations
links2004/WebSockets@^2.3.6
jandrassy/TelnetStream@^1.2.2
khoih-prog/ESP8266TimerInterrupt@^1.6.0
extra_scripts = download_fs.py
Processing esp12e (platform: espressif8266; board: esp12e; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/espressif8266/esp12e.html
PLATFORM: Espressif 8266 (4.0.1) > Espressif ESP8266 ESP-12E
HARDWARE: ESP8266 160MHz, 80KB RAM, 4MB Flash
- framework-arduinoespressif8266 @ 3.30002.0 (3.0.2)
- tool-esptool @ 1.413.0 (4.13)
- tool-esptoolpy @ 1.30000.201119 (3.0.0)
- toolchain-xtensa @ 2.100300.210717 (10.3.0)
Found 38 compatible libraries
|-- WebSockets @ 2.3.7
| |-- Hash @ 1.0
| |-- ESP8266WiFi @ 1.0
| |-- Ethernet @ 2.0.0
| | |-- SPI @ 1.0
| |-- SPI @ 1.0
|-- TelnetStream @ 1.2.2
| |-- Ethernet @ 2.0.0
| | |-- SPI @ 1.0
|-- ESP8266TimerInterrupt @ 1.6.0
|-- Wire @ 1.0
|-- LittleFS @ 0.1.0
|-- ESP8266mDNS @ 1.2
|-- ESP8266WebServer @ 1.0
|-- ArduinoOTA @ 1.0
Error: Please specify `upload_port` for environment or use global `--upload-port` option.
For some development platforms it can be a USB flash drive (i.e. /media/<user>/<device name>)
=========================== [FAILED] Took 3.15 seconds ===========================
* The terminal process "C:\Users\mark\.platformio\penv\Scripts\platformio.exe 'run'" terminated with exit code: 1.
This script unconditionally tries to do an autodetection when it’s loaded.
Comment out the extra_scripts line from the platformio.ini with a ; and retry as a first test.
Thanks for the fast response. That fixed it. I assumed the script was run after a build. In any case the script doesn’t work so the fix is no problem.
