I didn’t quite follow the recommendation.
Here is OTA-Update.h
#ifndef OTA_Update_h
#define OTA_Update_h
#include "Arduino.h"
//#include <AsyncWebServer_Teensy41.h>
#include "FXUtil.h" // read_ascii_line(), hex file support
extern "C" {
#include "FlashTxx.h" // TLC/T3x/T4x/TMM flash primitives
class OTA_Update {
public:
OTA_Update();
void OTAapply();
private:
Here is OTA_Update.cpp
#include "AsyncWebServer_Teensy41.h"
#include "OTA_Update.h"
// hex_info_t struct for hex record and hex file info
typedef struct { //
char *data; // pointer to array allocated elsewhere
unsigned int addr; // address in intel hex record
unsigned int code; // intel hex record type (0=data, etc.)
unsigned int num; // number of data bytes in intel hex record
uint32_t base; // base address to be added to intel hex 16-bit addr
uint32_t min; // min address in hex file
uint32_t max; // max address in hex file
int eof; // set true on intel hex EOF (code = 1)
int lines; // number of hex records received
} hex_info_t;
void read_ascii_line( Stream *serial, char *line, int maxbytes );
int parse_hex_line( const char *theline, char *bytes, unsigned int *addr, unsigned int *num, unsigned int *code );
int process_hex_record( hex_info_t *hex );
void update_firmware( Stream *in, Stream *out, uint32_t buffer_addr, uint32_t buffer_size );
static char line[96]; // buffer for hex lines
int line_index=0;
static char data[32] __attribute__ ((aligned (8))); // buffer for hex data
hex_info_t hex = { // intel hex info struct
data, 0, 0, 0, // data,addr,num,code
0, 0xFFFFFFFF, 0, // base,min,max,
0, 0 // eof,lines
bool ota_status=0; // 1=running
bool ota_final=0;
bool ota_apply=0;
uint32_t buffer_addr, buffer_size;
AsyncWebServer server(80);
void handleNotFound(AsyncWebServerRequest *request)
request->send(404, "text/plain", "Not found");
void OTAend(AsyncWebServerRequest *request){
AsyncWebParameter* p = request->getParam(0);
Serial.printf("FILE[%s]: %s, size: %u\n", p->name().c_str(), p->value().c_str(), p->size());
if (ota_final){
Serial.printf( "\nhex file: %1d lines %1lu bytes (%08lX - %08lX)\n",
hex.lines, hex.max-hex.min, hex.min, hex.max );
// check FSEC value in new code -- abort if incorrect
#if defined(KINETISK) || defined(KINETISL)
uint32_t value = *(uint32_t *)(0x40C + buffer_addr);
if (value != 0xfffff9de) {
Serial.printf( "new code contains correct FSEC value %08lX\n", value );
else {
Serial.printf( "abort - FSEC value %08lX should be FFFFF9DE\n", value );
ota_final=false;
if (ota_final){
// check FLASH_ID in new code - abort if not found
if (check_flash_id( buffer_addr, hex.max - hex.min )) {
Serial.printf( "new code contains correct target ID %s\n", FLASH_ID );
else {
Serial.printf( "abort - new code missing string %s\n", FLASH_ID );
ota_final=false;
AsyncWebServerResponse *response = request->beginResponse((!ota_final)?500:200, "text/plain", (!ota_final)?"OTA Failed... Going for reboot":"OTA Success! Going for reboot");
response->addHeader("Connection", "close");
response->addHeader("Access-Control-Allow-Origin", "*");
request->send(response);
ota_apply=true;
void OTA(AsyncWebServerRequest *request, String filename, size_t index, uint8_t *data, size_t len, bool final){
if (!ota_status){
Serial.println("Starting OTA...");
if (firmware_buffer_init( &buffer_addr, &buffer_size ) == 0) {
Serial.println( "unable to create buffer" );
} else {
Serial.printf( "created buffer = %1luK %s (%08lX - %08lX)\n",
buffer_size/1024, IN_FLASH(buffer_addr) ? "FLASH" : "RAM",
buffer_addr, buffer_addr + buffer_size );
ota_status=true;
if (ota_status) {
if(len){
size_t i=0;
while (i<len){
if (data[i]==0x0A || (line_index==sizeof(line)-1)){ // '\n'
line[line_index] = 0; // null-terminate
//Serial.printf( "%s\n", line );
if (parse_hex_line( (const char*)line, hex.data, &hex.addr, &hex.num, &hex.code ) == 0) {
Serial.printf( "abort - bad hex line %s\n", line );
return request->send(400, "text/plain", "abort - bad hex line");
else if (process_hex_record( &hex ) != 0) { // error on bad hex code
Serial.printf( "abort - invalid hex code %d\n", hex.code );
return request->send(400, "text/plain", "invalid hex code");
else if (hex.code == 0) { // if data record
uint32_t addr = buffer_addr + hex.base + hex.addr - FLASH_BASE_ADDR;
if (hex.max (FLASH_BASE_ADDR + buffer_size)) {
Serial.print("addr: "); Serial.println(addr);
Serial.print("buffer_addr: "); Serial.println(buffer_addr);
Serial.print("buffer_size: "); Serial.println(buffer_size);
Serial.print("hex.base: "); Serial.println(hex.base);
Serial.print("hex.addr: "); Serial.println(hex.addr);
Serial.print("hex.max: "); Serial.println(hex.max);
Serial.print("FLASH_BASE_ADDR: "); Serial.println(FLASH_BASE_ADDR);
Serial.printf( "abort - max address %08lX too large\n", hex.max );
return request->send(400, "text/plain", "abort - max address too large");
else if (!IN_FLASH(buffer_addr)) {
memcpy( (void*)addr, (void*)hex.data, hex.num );
else if (IN_FLASH(buffer_addr)) {
int error = flash_write_block( addr, hex.data, hex.num );
if (error) {
Serial.printf( "abort - error %02X in flash_write_block()\n", error );
return request->send(400, "text/plain", "abort - error in flash_write_block()");
hex.lines++;
line_index=0;
} else if (data[i]!=0x0D){ // '\r'
line[line_index++]=data[i];
i++;
if (final) { // if the final flag is set then this is the last frame of data
Serial.println("Transfer finished");
ota_final=true;
}else{
return;
} else {
return request->send(400, "text/plain", "OTA could not begin");
//extern "C" char* sbrk(int incr);
int freeRam() {
char top;
return &top - reinterpret_cast<char*>(sbrk(0));
OTA_Update::OTA_Update()
Serial.print("\nOTA through Ethernet code for ");
Serial.println(BOARD_NAME);
server.onNotFound(handleNotFound);
server.on("/", HTTP_GET, [](AsyncWebServerRequest * request) {
String html = "<body><h1>OTA through Ethernet demo code for Teensy41</h1><br \><h2>select and send your binary file:</h2><br \><div><form method='POST' enctype='multipart/form-data' action='/'><input type='file' name='file'><button type='submit'>Send</button></form></div></body>";
request->send(200, "text/html", html);
server.on("/", HTTP_POST, OTAend, OTA);
server.begin();
void OTA_Update::OTAapply(){
delay(100);
if (ota_final){
Serial.printf( "calling flash_move() to load new firmware...\n" );
flash_move( FLASH_BASE_ADDR, buffer_addr, hex.max-hex.min );
Serial.flush();
REBOOT;
for (;;) {}
} else {
Serial.printf( "erase FLASH buffer / free RAM buffer...\n" );
firmware_buffer_free( buffer_addr, buffer_size );
Serial.flush();
REBOOT;
for (;;) {}
