Using this platformio.ini
; Redirecting...
[env:esp-wrover-kit]
board = esp-wrover-kit
GitHub - collin80/esp32_can: Arduino ESP32 library supporting the on-chip CAN module
MrDIY / CANaBus · GitLab
collin80/can_common@^0.3.0
espressif/WROVER KIT LCD@^1.0.3
and this code
** MrDIY - CAN Shield - https://youtu.be/gtVQeTRps7o**
** Notes:**
** - The Power/Red LED on the shield is not enabled my default. A jumper next to **
** the LED needs to be soldered**
** - The voltage divider is not enabled by default on v1.1. A jumper on the back**
** needs to be soldered**
** - the ACT LED is connected to pin 26 (SHIELD_LED_PIN in the code)**
** ATTENTION:**
** - If you are facing an assert failed error. Try getting the esp_can library **
** from my repo instead ( the file is called: libraries.zip on the root folder)**
** or check assert failed: spinlock_acquire spinlock.h:122 · Issue #48 · collin80/esp32_can · GitHub**
#include “esp32_can.h” / GitHub - collin80/esp32_can: Arduino ESP32 library supporting the on-chip CAN module /
#include <can_common.h>
#include <SPI.h>
#define SHIELD_LED_PIN 26
void setup()
** Serial.begin(115200);**
** Serial.println(“------------------------”);**
** Serial.println(" MrDIY CAN SHIELD");**
** Serial.println(" CAN…INIT");**
** CAN0.setCANPins(GPIO_NUM_5, GPIO_NUM_4);**
** CAN0.begin(500000); // 500Kbps**
** CAN0.watchFor();**
** Serial.println(" CAN…500Kbps");**
void loop()
** CAN_FRAME can_message;**
** if (CAN0.read(can_message))**
** Serial.print(“CAN MSG: 0x”);**
** Serial.print(can_message.id, HEX);**
** Serial.print(" [“);**
** Serial.print(can_message.length, DEC);**
** Serial.print(”] <“);**
** for (int i = 0; i < can_message.length; i++)**
** if (i != 0) Serial.print(”:“);**
** Serial.print(can_message.data.byte[i], HEX);**
** Serial.println(”>");**
I get
- Executing task: C:\Users\simon.platformio\penv\Scripts\platformio.exe run
Processing esp-wrover-kit (platform: espressif32; board: esp-wrover-kit; framework: arduino)
--------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------Verbose mode can be enabled via-v, --verboseoption
CONFIGURATION: Redirecting...
PLATFORM: Espressif 32 (6.4.0) > Espressif ESP-WROVER-KIT
DEBUG: Current (ftdi) On-board (ftdi) External (cmsis-dap, esp-bridge, esp-prog, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa)
- framework-arduinoespressif32 @ 3.20011.230801 (2.0.11)
Found 37 compatible libraries
Scanning dependencies…
|-- ESP32_CAN @ 0.2.5+sha.c6bc416
|-- canabus @ 0.0.0+20240103153907.sha.e338ca2
|-- can_common @ 0.3.0
|-- WROVER KIT LCD @ 1.0.3
|-- SPI @ 2.0.0
Compiling .pio\build\esp-wrover-kit\libf51\ESP32_CAN\esp32_can_builtin.cpp.o
Compiling .pio\build\esp-wrover-kit\libf51\ESP32_CAN\mcp2517fd.cpp.o
Compiling .pio\build\esp-wrover-kit\lib13e\WROVER KIT LCD\WROVER_KIT_LCD.cpp.o
Archiving .pio\build\esp-wrover-kit\libFrameworkArduino.a
.pio/libdeps/esp-wrover-kit/ESP32_CAN/src/mcp2517fd.cpp: In function ‘void task_ResetWatcher(void*)’:
.pio/libdeps/esp-wrover-kit/ESP32_CAN/src/mcp2517fd.cpp:42:25: error: ‘class MCP2517FD’ has no member named ‘debuggingMode’
if (mcpCan->debuggingMode) Serial.println(“!!!RESTRICTED MODE!!!”);
.pio/libdeps/esp-wrover-kit/ESP32_CAN/src/mcp2517fd.cpp:48:25: error: ‘class MCP2517FD’ has no member named ‘debuggingMode’
if (mcpCan->debuggingMode) Serial.println(“Reset 2517FD hardware”);
.pio/libdeps/esp-wrover-kit/ESP32_CAN/src/mcp2517fd.cpp:54:25: error: ‘class MCP2517FD’ has no member named ‘debuggingMode’
if (mcpCan->debuggingMode) Serial.println(“Reset TX FIFO”);
.pio/libdeps/esp-wrover-kit/ESP32_CAN/src/mcp2517fd.cpp: In member function ‘void MCP2517FD::resetHardware()’:
.pio/libdeps/esp-wrover-kit/ESP32_CAN/src/mcp2517fd.cpp:69:9: error: ‘debuggingMode’ was not declared in this scope
if (debuggingMode)
.pio/libdeps/esp-wrover-kit/ESP32_CAN/src/mcp2517fd.cpp: In member function ‘void MCP2517FD::initializeResources()’:
.pio/libdeps/esp-wrover-kit/ESP32_CAN/src/mcp2517fd.cpp:199:9: error: ‘debuggingMode’ was not declared in this scope
if (debuggingMode) Serial.println(“initializeResources()”);
.pio/libdeps/esp-wrover-kit/ESP32_CAN/src/mcp2517fd.cpp:207:9: error: ‘debuggingMode’ was not declared in this scope
if (debuggingMode) Serial.println(“Initialized hardware pins”);
.pio/libdeps/esp-wrover-kit/ESP32_CAN/src/mcp2517fd.cpp:224:9: error: ‘debuggingMode’ was not declared in this scope
if (debuggingMode) Serial.println(“Initialized queues”);
.pio/libdeps/esp-wrover-kit/ESP32_CAN/src/esp32_can_builtin.cpp: In member function ‘virtual int ESP32CAN::_setFilter(uint32_t, uint32_t, bool)’:
.pio/libdeps/esp-wrover-kit/ESP32_CAN/src/esp32_can_builtin.cpp:211:9: error: ‘debuggingMode’ was not declared in this scope
if (debuggingMode) Serial.println(“Could not set filter!”);
In file included from .pio/libdeps/esp-wrover-kit/WROVER KIT LCD/src/WROVER_KIT_LCD.cpp:16:
.pio/libdeps/esp-wrover-kit/WROVER KIT LCD/src/WROVER_KIT_LCD.h:13:10: fatal error: FS.h: No such file or directory
- Looking for FS.h dependency? Check our library registry!
- CLI > platformio lib search “header:FS.h”
- Web > PlatformIO Registry
#include “FS.h”
compilation terminated.
.pio/libdeps/esp-wrover-kit/ESP32_CAN/src/mcp2517fd.cpp:231:9: error: ‘debuggingMode’ was not declared in this scope
if (debuggingMode) Serial.println(“Done with resource init”);
.pio/libdeps/esp-wrover-kit/ESP32_CAN/src/esp32_can_builtin.cpp: In member function ‘void ESP32CAN::_init()’:
.pio/libdeps/esp-wrover-kit/ESP32_CAN/src/esp32_can_builtin.cpp:217:9: error: ‘debuggingMode’ was not declared in this scope
if (debuggingMode) Serial.println(“Built in CAN Init”);
.pio/libdeps/esp-wrover-kit/ESP32_CAN/src/mcp2517fd.cpp: In member function ‘void MCP2517FD::initSPI()’:
.pio/libdeps/esp-wrover-kit/ESP32_CAN/src/mcp2517fd.cpp:278:9: error: ‘debuggingMode’ was not declared in this scope
if (debuggingMode) Serial.println(“MCP2517FD SPI Inited”);
.pio/libdeps/esp-wrover-kit/ESP32_CAN/src/esp32_can_builtin.cpp:228:13: error: ‘debuggingMode’ was not declared in this scope
if (debuggingMode) printf(“Initializing resources for built-in CAN\n”);
.pio/libdeps/esp-wrover-kit/ESP32_CAN/src/mcp2517fd.cpp: In member function ‘int MCP2517FD::Init(uint32_t, uint8_t, uint8_t)’:
.pio/libdeps/esp-wrover-kit/ESP32_CAN/src/mcp2517fd.cpp:302:9: error: ‘debuggingMode’ was not declared in this scope
if (debuggingMode) Serial.println(“Initializing MCP2517FD”);
*** [.pio\build\esp-wrover-kit\lib13e\WROVER KIT LCD\WROVER_KIT_LCD.cpp.o] Error 1
.pio/libdeps/esp-wrover-kit/ESP32_CAN/src/esp32_can_builtin.cpp:233:13: error: ‘debuggingMode’ was not declared in this scope
if (debuggingMode) Serial.println(“Created queues.”);
.pio/libdeps/esp-wrover-kit/ESP32_CAN/src/mcp2517fd.cpp: In member function ‘void MCP2517FD::txQueueSetup()’:
.pio/libdeps/esp-wrover-kit/ESP32_CAN/src/mcp2517fd.cpp:432:9: error: ‘debuggingMode’ was not declared in this scope
if (debuggingMode)
.pio/libdeps/esp-wrover-kit/ESP32_CAN/src/esp32_can_builtin.cpp:237:13: error: ‘debuggingMode’ was not declared in this scope
if (debuggingMode) Serial.println(“task rx created.”);
.pio/libdeps/esp-wrover-kit/ESP32_CAN/src/mcp2517fd.cpp: In member function ‘void MCP2517FD::commonInit()’:
.pio/libdeps/esp-wrover-kit/ESP32_CAN/src/mcp2517fd.cpp:444:9: error: ‘debuggingMode’ was not declared in this scope
if (debuggingMode) Serial.println(“commonInit()”);
.pio/libdeps/esp-wrover-kit/ESP32_CAN/src/esp32_can_builtin.cpp:238:13: error: ‘debuggingMode’ was not declared in this scope
if (debuggingMode) Serial.println(“task low level rx created.”);
.pio/libdeps/esp-wrover-kit/ESP32_CAN/src/mcp2517fd.cpp:455:9: error: ‘debuggingMode’ was not declared in this scope
if (debuggingMode)
.pio/libdeps/esp-wrover-kit/ESP32_CAN/src/esp32_can_builtin.cpp:240:13: error: ‘debuggingMode’ was not declared in this scope
if (debuggingMode) Serial.println(“task watchdog created.”);
.pio/libdeps/esp-wrover-kit/ESP32_CAN/src/mcp2517fd.cpp: In member function ‘bool MCP2517FD::_init(uint32_t, uint8_t, uint8_t, bool)’:
.pio/libdeps/esp-wrover-kit/ESP32_CAN/src/mcp2517fd.cpp:480:9: error: ‘debuggingMode’ was not declared in this scope
if (debuggingMode) Serial.println(“_init()”);
.pio/libdeps/esp-wrover-kit/ESP32_CAN/src/esp32_can_builtin.cpp:243:9: error: ‘debuggingMode’ was not declared in this scope
if (debuggingMode) Serial.println(“init done");
.pio/libdeps/esp-wrover-kit/ESP32_CAN/src/mcp2517fd.cpp:493:13: error: ‘debuggingMode’ was not declared in this scope
if (debuggingMode) Serial.println(“Could not enter configuration mode”);
.pio/libdeps/esp-wrover-kit/ESP32_CAN/src/esp32_can_builtin.cpp: In member function ‘virtual uint32_t ESP32CAN::init(uint32_t)’:
.pio/libdeps/esp-wrover-kit/ESP32_CAN/src/esp32_can_builtin.cpp:250:9: error: ‘debuggingMode’ was not declared in this scope
if (debuggingMode)
.pio/libdeps/esp-wrover-kit/ESP32_CAN/src/mcp2517fd.cpp:519:13: error: ‘debuggingMode’ was not declared in this scope
if (debuggingMode) Serial.println(“Nominal TSeg1 outside of limits. Invalid baud rate!”);
.pio/libdeps/esp-wrover-kit/ESP32_CAN/src/esp32_can_builtin.cpp: In member function ‘bool ESP32CAN::processFrame(twai_message_t&)’:
.pio/libdeps/esp-wrover-kit/ESP32_CAN/src/esp32_can_builtin.cpp:422:17: error: ‘debuggingMode’ was not declared in this scope
if (debuggingMode) Serial.write('‘);
.pio/libdeps/esp-wrover-kit/ESP32_CAN/src/mcp2517fd.cpp:524:13: error: ‘debuggingMode’ was not declared in this scope
if (debuggingMode) Serial.println(“Nominal TSeg2 outside of limits. Invalid baud rate!”);
.pio/libdeps/esp-wrover-kit/ESP32_CAN/src/esp32_can_builtin.cpp: In member function ‘virtual bool ESP32CAN::sendFrame(CAN_FRAME&)’:
.pio/libdeps/esp-wrover-kit/ESP32_CAN/src/esp32_can_builtin.cpp:444:13: error: ‘debuggingMode’ was not declared in this scope
if (debuggingMode) Serial.write(’<‘);
.pio/libdeps/esp-wrover-kit/ESP32_CAN/src/mcp2517fd.cpp:532:13: error: ‘debuggingMode’ was not declared in this scope
if (debuggingMode)
.pio/libdeps/esp-wrover-kit/ESP32_CAN/src/esp32_can_builtin.cpp:447:13: error: ‘debuggingMode’ was not declared in this scope
if (debuggingMode) Serial.write(‘T’);
.pio/libdeps/esp-wrover-kit/ESP32_CAN/src/mcp2517fd.cpp:553:9: error: ‘debuggingMode’ was not declared in this scope
if (debuggingMode)
.pio/libdeps/esp-wrover-kit/ESP32_CAN/src/esp32_can_builtin.cpp:453:13: error: ‘debuggingMode’ was not declared in this scope
if (debuggingMode) Serial.write(’!');
.pio/libdeps/esp-wrover-kit/ESP32_CAN/src/mcp2517fd.cpp:574:17: error: ‘debuggingMode’ was not declared in this scope
if (debuggingMode) Serial.println(“Could not enter normal mode”);
.pio/libdeps/esp-wrover-kit/ESP32_CAN/src/mcp2517fd.cpp:583:17: error: ‘debuggingMode’ was not declared in this scope
if (debuggingMode) Serial.println(“Could not enter listen only mode”);
.pio/libdeps/esp-wrover-kit/ESP32_CAN/src/mcp2517fd.cpp:594:13: error: ‘debuggingMode’ was not declared in this scope
if (debuggingMode) Serial.println(“MCP2517 Init Success”);
.pio/libdeps/esp-wrover-kit/ESP32_CAN/src/mcp2517fd.cpp:607:13: error: ‘debuggingMode’ was not declared in this scope
if (debuggingMode)
.pio/libdeps/esp-wrover-kit/ESP32_CAN/src/mcp2517fd.cpp: In member function ‘bool MCP2517FD::_initFD(uint32_t, uint32_t, uint8_t, uint8_t, bool)’:
.pio/libdeps/esp-wrover-kit/ESP32_CAN/src/mcp2517fd.cpp:628:9: error: ‘debuggingMode’ was not declared in this scope
if (debuggingMode) Serial.println(”_initFD()");
*** [.pio\build\esp-wrover-kit\libf51\ESP32_CAN\esp32_can_builtin.cpp.o] Error 1
.pio/libdeps/esp-wrover-kit/ESP32_CAN/src/mcp2517fd.cpp:652:13: error: ‘debuggingMode’ was not declared in this scope
if (debuggingMode) Serial.println(“Nominal TSeg1 outside of limits. Invalid baud rates!”);
.pio/libdeps/esp-wrover-kit/ESP32_CAN/src/mcp2517fd.cpp:657:13: error: ‘debuggingMode’ was not declared in this scope
if (debuggingMode) Serial.println(“Nominal TSeg2 outside of limits. Invalid baud rates!”);
.pio/libdeps/esp-wrover-kit/ESP32_CAN/src/mcp2517fd.cpp:665:9: error: ‘debuggingMode’ was not declared in this scope
if (debuggingMode) Serial.printf(“Nomimal Settings: TSEG1: %u TSEG2: %u\n”, tseg1, tseg2);
.pio/libdeps/esp-wrover-kit/ESP32_CAN/src/mcp2517fd.cpp:675:13: error: ‘debuggingMode’ was not declared in this scope
if (debuggingMode) Serial.println(“Data TSeg1 outside of limits. Invalid baud rates!”);
.pio/libdeps/esp-wrover-kit/ESP32_CAN/src/mcp2517fd.cpp:680:13: error: ‘debuggingMode’ was not declared in this scope
if (debuggingMode) Serial.println(“Data TSeg2 outside of limits. Invalid baud rates!”);
.pio/libdeps/esp-wrover-kit/ESP32_CAN/src/mcp2517fd.cpp:692:9: error: ‘debuggingMode’ was not declared in this scope
if (debuggingMode) Serial.printf(“Data Settings: TSEG1: %u TSEG2: %u\n”, tseg1, tseg2);
.pio/libdeps/esp-wrover-kit/ESP32_CAN/src/mcp2517fd.cpp:718:17: error: ‘debuggingMode’ was not declared in this scope
.pio/libdeps/esp-wrover-kit/ESP32_CAN/src/mcp2517fd.cpp:727:17: error: ‘debuggingMode’ was not declared in this scope
.pio/libdeps/esp-wrover-kit/ESP32_CAN/src/mcp2517fd.cpp:737:13: error: ‘debuggingMode’ was not declared in this scope
if (debuggingMode) Serial.println(“MCP2517 InitFD Success”);
.pio/libdeps/esp-wrover-kit/ESP32_CAN/src/mcp2517fd.cpp:746:13: error: ‘debuggingMode’ was not declared in this scope
if (debuggingMode)
.pio/libdeps/esp-wrover-kit/ESP32_CAN/src/mcp2517fd.cpp: In member function ‘virtual int MCP2517FD::_setFilter(uint32_t, uint32_t, bool)’:
.pio/libdeps/esp-wrover-kit/ESP32_CAN/src/mcp2517fd.cpp:775:9: error: ‘debuggingMode’ was not declared in this scope
if (debuggingMode) Serial.println(“Err: No filter set!”);
.pio/libdeps/esp-wrover-kit/ESP32_CAN/src/mcp2517fd.cpp: In member function ‘void MCP2517FD::LoadFrameBuffer(uint16_t, CAN_FRAME_FD&)’:
.pio/libdeps/esp-wrover-kit/ESP32_CAN/src/mcp2517fd.cpp:1209:9: error: ‘debuggingMode’ was not declared in this scope
if (debuggingMode)
.pio/libdeps/esp-wrover-kit/ESP32_CAN/src/mcp2517fd.cpp:1227:9: error: ‘debuggingMode’ was not declared in this scope
if (debuggingMode)
.pio/libdeps/esp-wrover-kit/ESP32_CAN/src/mcp2517fd.cpp: In member function ‘bool MCP2517FD::Mode(byte)’:
.pio/libdeps/esp-wrover-kit/ESP32_CAN/src/mcp2517fd.cpp:1242:9: error: ‘debuggingMode’ was not declared in this scope
if (debuggingMode) Serial.println(“Mode”);
.pio/libdeps/esp-wrover-kit/ESP32_CAN/src/mcp2517fd.cpp:1249:9: error: ‘debuggingMode’ was not declared in this scope
if (debuggingMode)
.pio/libdeps/esp-wrover-kit/ESP32_CAN/src/mcp2517fd.cpp: In member function ‘void MCP2517FD::handleTXFifoISR(int)’:
.pio/libdeps/esp-wrover-kit/ESP32_CAN/src/mcp2517fd.cpp:1447:13: error: ‘debuggingMode’ was not declared in this scope
if (debuggingMode)
.pio/libdeps/esp-wrover-kit/ESP32_CAN/src/mcp2517fd.cpp:1473:13: error: ‘debuggingMode’ was not declared in this scope
if (debuggingMode) Serial.write(‘"’);
.pio/libdeps/esp-wrover-kit/ESP32_CAN/src/mcp2517fd.cpp: In member function ‘void MCP2517FD::handleTXFifo(int, CAN_FRAME_FD&)’:
.pio/libdeps/esp-wrover-kit/ESP32_CAN/src/mcp2517fd.cpp:1507:13: error: ‘debuggingMode’ was not declared in this scope
if (debuggingMode) Serial.write(‘+’);
.pio/libdeps/esp-wrover-kit/ESP32_CAN/src/mcp2517fd.cpp:1513:13: error: ‘debuggingMode’ was not declared in this scope
if (debuggingMode)
.pio/libdeps/esp-wrover-kit/ESP32_CAN/src/mcp2517fd.cpp: In member function ‘void MCP2517FD::handleTXFifo(int, CAN_FRAME&)’:
.pio/libdeps/esp-wrover-kit/ESP32_CAN/src/mcp2517fd.cpp:1546:13: error: ‘debuggingMode’ was not declared in this scope
.pio/libdeps/esp-wrover-kit/ESP32_CAN/src/mcp2517fd.cpp:1550:13: error: ‘debuggingMode’ was not declared in this scope
if (debuggingMode)
*** [.pio\build\esp-wrover-kit\libf51\ESP32_CAN\mcp2517fd.cpp.o] Error 1
====================================================================================== [FAILED] Took 4.19 seconds ======================================================================================
- The terminal process “C:\Users\simon.platformio\penv\Scripts\platformio.exe ‘run’” terminated with exit code: 1.
- Terminal will be reused by tasks, press any key to close it.
What am I missing?
