Hello, I’ve been on a journey attempting to test my code just to see if it works. in this scenario I am just trying to make a class the store the data for an IR sensor and I just can’t seem to get it to compile the way I want it to.
There are 3 files in question, IRSensor.h, IRSensor.cpp, and test.cpp. Here are the contents of each.
IRSensor.h
#ifndef IRSENSOR_H
#define IRSENSOR_H
class IRSensor {
private:
int leftIRSensor;
int middleIRSensor;
int rightIRSensor;
public:
IRSensor();
int getLeftIRSensor();
int getMiddleIRSensor();
int getRightIRSensor();
void setLeftIRSensor(int sensorValue);
void setMiddleIRSensor(int sensorValue);
void setRightIRSensor(int sensorValue);
int leftIRSensor;
int middleIRSensor;
int rightIRSensor;
IRSensor.cpp
#include "Sensors/IRSensor.h"
int leftIRSensor;
int middleIRSensor;
int rightIRSensor;
IRSensor::IRSensor() {
leftIRSensor = 0;
middleIRSensor = 0;
rightIRSensor = 0;
int IRSensor::getLeftIRSensor() {
return leftIRSensor;
int IRSensor::getMiddleIRSensor() {
return middleIRSensor;
int IRSensor::getRightIRSensor() {
return rightIRSensor;
void IRSensor::setLeftIRSensor(int sensorValue) {
leftIRSensor = sensorValue;
void IRSensor::setMiddleIRSensor(int sensorValue) {
middleIRSensor = sensorValue;
void IRSensor::setRightIRSensor(int sensorValue) {
rightIRSensor = sensorValue;
test.cpp
#include "unity.h"
#include <stdbool.h>
IRSensor irSensor = IRSensor();
void setUp(void) {
// set stuff up here
void tearDown(void) {
// clean stuff up here
void test_function_should_doBlahAndBlah(void) {
TEST_ASSERT_TRUE(true);
void test_IRSensor_set(void) {
irSensor.setLeftIRSensor(0);
TEST_ASSERT_EQUAL_INT(0, irSensor.getLeftIRSensor());
irSensor.setRightIRSensor(100);
TEST_ASSERT_EQUAL_INT(100, irSensor.getRightIRSensor());
irSensor.setMiddleIRSensor(1000);
TEST_ASSERT_EQUAL_INT(1000, irSensor.getMiddleIRSensor());
// not needed when using generate_test_runner.rb
int main(void) {
UNITY_BEGIN();
RUN_TEST(test_function_should_doBlahAndBlah);
RUN_TEST(test_IRSensor_set);
return UNITY_END();
This is the command and output
PS C:\Users\xridd\OneDrive\Documents\PlatformIO\Projects\Teddi> pio test -e native
Verbosity level can be increased via `-v, -vv, or -vvv` option
Collected 1 tests
Processing test_tester in native environment
Building...
C:/msys64/ucrt64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: .pio\build\native\test\test_tester\test.o:test.cpp:(.text+0x2d): undefined reference to `IRSensor::setLeftIRSensor(int)'
C:/msys64/ucrt64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: .pio\build\native\test\test_tester\test.o:test.cpp:(.text+0x3c): undefined reference to `IRSensor::getLeftIRSensor()'
C:/msys64/ucrt64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: .pio\build\native\test\test_tester\test.o:test.cpp:(.text+0x73): undefined reference to `IRSensor::setRightIRSensor(int)'
C:/msys64/ucrt64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: .pio\build\native\test\test_tester\test.o:test.cpp:(.text+0x82): undefined reference to `IRSensor::getRightIRSensor()'
C:/msys64/ucrt64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: .pio\build\native\test\test_tester\test.o:test.cpp:(.text+0xb9): undefined reference to `IRSensor::setMiddleIRSensor(int)'
C:/msys64/ucrt64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: .pio\build\native\test\test_tester\test.o:test.cpp:(.text+0xc8): undefined reference to `IRSensor::getMiddleIRSensor()'
C:/msys64/ucrt64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: .pio\build\native\test\test_tester\test.o:test.cpp:(.text+0x14f): undefined reference to `IRSensor::IRSensor()'
*** [.pio\build\native\program.exe] Error 1
Building stage has failed, see errors above. Use `pio test -vvv` option to enable verbose output.
Interestingly enough, I was able to make it compile and run the tests when I moved all of the implementation of IRSensor.h into the header file directly. However, I believe this is against best practice and would like to keep implementation in the .cpp file.
also, here is my project structure in case it helps
I appreciate any help I can get on this problem, Thanks.
Edited by @sivar2311: Changed from blockquote to preformatted text for better readability
