Hey I am writing a platformIO wrapper for neovim.
I wanted to ask is there a way to get data for all the library available in josn format like you get data for all available board by using the command pio pkg --json-output
You mean you want to retrieve all existing libraries in the PlatformIO registry (https://registry.platformio.org/)? Which are like… a lot?
Or the ones installed in the project?
Yeah I wanted to retrieve all existing libraries, but now it sounds stupid. Do you know how to get the data in json by giving a search query, like I want output of this pio pkg search
in json
See core code.
Example:
curl 'https://api.registry.platformio.org/v3/search?query="ArduinoJson"&page=1&limit=1'
"page": 1,
"limit": 1,
"total": 145,
"items": [
"id": 64,
"type": "library",
"tier": "community",
"owner": {
"username": "bblanchon"
"name": "ArduinoJson",
"description": "A simple and efficient JSON library for embedded C++. ArduinoJson supports ✔ serialization, ✔ deserialization, ✔ MessagePack, ✔ fixed allocation, ✔ zero-copy, ✔ streams, ✔ filtering, and more. It is the most popular Arduino library on GitHub ❤❤❤❤❤. Check out arduinojson.org for a comprehensive documentation.",
"keywords": [
"json",
"rest",
"http",
"web"
"license": "MIT",
"updated_at": "2022-04-05T17:41:31Z",
"stars_count": 5656,
"popularity_rank": 3,
"popularity_trend": -1,
"version": {
"id": 43399,
"name": "6.19.4",
"unpacked_size": 395536,
"released_at": "2022-04-05T08:53:11Z",
"files": [
"name": "ArduinoJson-6.19.4.tar.gz",
"size": 87187,
"checksum": {
"sha256": "88fd7a943529d4ceb1106addcba04660e61bce65670237226212da5fa82dedd3"
"system": "*",
"download_url": "https://dl.registry.platformio.org/download/bblanchon/library/ArduinoJson/6.19.4/ArduinoJson-6.19.4.tar.gz"
(The output is paginated with a limit of 50 max items for each page).
that would be enough, thanks a lot
