who can have any ideas how to get free stack size on Raspberry Pi Pico2 (RP2350)?
On RP2040 we can call rp2040.getFreeStack() and get proper value. On RP2350 the method returns 270272 and it does not seem to be true.
Platform.ini is:
[env:5500_evb_pico2]
platform = https://github.com/maxgerhardt/platform-raspberrypi.git
board = wiznet_5500_evb_pico2
board_build.core = earlephilhower
board_build.filesystem_size = 0.5m
test_framework = unity
test_build_src = yes
'-D SHIELD="W5500-EVB-Pico2"'
build_unflags = -fno-rtti
Then plesse open an issue in https://github.com/earlephilhower/arduino-pico/issues, not here.
The getFreeStack() function assumes 0x20040000 is the end of memory.
And assumes RAM is 256 kB plus 2*4 KB scratch memory in
@maxgerhardt ok, the issue was created there.
Thanks for quick fix!
pio pkg update -g -p raspberrypi didn’t help, so I had to clean up and get again .platformio folder
Weird. Then
pio pkg update -g -p https://github.com/maxgerhardt/platform-raspberrypi.git
might do it next time.
Worked for me for the Olimex Pico2XXL board. Thanks!
