I’ve got a medium-size platformio library project, and I’m trying to get set up do work on it from my beloved emacs. I found that I can generate a compile_commands.json file to give to clangd, and I can successfully generate one in another project that builds binaries, but not in this library-only project. We have tests that build the library, but doing $ pio run -t compiledb
yields a json file with only []
in it… Is there any way I can get a useful compilation db out of this? Thanks!
Here’s the whole platformio.ini
[native]
platform = native
test_transport = native
build_flags = -std=c++17
debug_build_flags = -g -DDEBUG
lib_ldf_mode = deep
[env:release]
extends = native
build_type = release
[env:debug]
extends = native
build_type = debug
I get the same behavior on a regular platform = native
project.
C:\Users\Max\temp\native_c17>pio run -t compiledb
Processing native (platform: native)
Found 0 compatible libraries
Building compilation database .pio\build\native\compile_commands.json
============================================= [SUCCESS] Took 1.11 seconds =============================================
C:\Users\Max\temp\native_c17>cat .pio\build\native\compile_commands.json
please report this as a bug in Issues · platformio/platformio-core · GitHub. When doing this in any other prjoect (e.g. a ststm32 project) I’m getting a much larger file with actual content.
As a workaround you may try to put the library in a mostly empty dummy project that has just enough code to get the firmware compiling (e.g., with the Arduino framework an empty setup()
and loop()
Thanks! I’ll make the bug report.
edit: issue #3988
