pavel
July 5, 2021, 12:37pm
1
I’m using extraScript to generate some sources before build.
All works fine if I’m putting all generated sources inside src/
dir.
Actually, it is better to place for generated sources is inside build dir:
build_path = env.GetBuildPath("$BUILD_DIR")
generated_src_dir = os.path.join(build_path, 'mylib', 'generated')
env.Append(CPPPATH=[generated_src_dir])
All include headers, located in generated
from this example can be seen by the project. Main problem is that .c/.cpp
files not compiled in this case.
I tried to add them with SRC_FILTER
but failed (seems because it accepts only relative paths):
env.Append(SRC_FILTER=[f"+<{generated_src_dir}/*>"])
So, how to add generated sources located inside build directory to the project?
pavel
July 7, 2021, 8:27pm
2
So, can somebody tell me, is it possible to place generated sources outside src folder?
Exactly, the path here is relative the src_dir
I’m not sure if it’s possible what you want to do, adding source files from the build output directory in the build system. You can also open issue at Issues · platformio/platformio-core · GitHub for clarification.
pavel
July 7, 2021, 9:19pm
4
I found another solution to add custom sources dir:
build_path = env.subst("$BUILD_DIR")
generated_build_dir = os.path.join(build_path, 'mylib', 'generated', 'build')
env.BuildSources(generated_build_dir, generated_src_dir)
This works.
